Pehen22 Posted August 15, 2017 Report Share Posted August 15, 2017 So the Mrs has now decided after 6 month I can start modifying the golf r. The only condition is I can't spend a fortune all in one go and need to treat myself every month or so which so i can't complain really. So the plan over the next 6 months engine wise will be r600 intake, down pipe and dsg/engine remap. Now for the first modification I wanted to get the turbo inlet elbow as I have been told that this is quite an easy install and the standard part is quite restrictive. Which turbo elbow is best with the r600 intake? And is there any other modifications someone would recommend after this. Thanks Quote Link to comment Share on other sites More sharing options...
Lew Posted August 15, 2017 Report Share Posted August 15, 2017 Pedal box lol 😄😄 TLining 1 Quote Link to comment Share on other sites More sharing options...
Obakong Posted August 15, 2017 Report Share Posted August 15, 2017 Rear sway bar, Michelin PSS or ps4 tires. Some ceramic coating to protect the paint. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Pehen22 Posted August 15, 2017 Author Report Share Posted August 15, 2017 2 hours ago, Lew said: Pedal box lol Haha well I'm hoping to get the dsg remapped in the next few months so hopefully that will help Quote Link to comment Share on other sites More sharing options...
Pehen22 Posted August 15, 2017 Author Report Share Posted August 15, 2017 56 minutes ago, Obakong said: Rear sway bar, Michelin PSS or ps4 tires. Some ceramic coating to protect the paint. Sent from my iPhone using Tapatalk A local tyre company half half price sale in September so was unsure between michelin pss or good year asymetric. How does the rear sway bar change the dynamics of the handling? Quote Link to comment Share on other sites More sharing options...
seadragon Posted August 15, 2017 Report Share Posted August 15, 2017 Tyres definitely, Goodyear Eagle or Michelin PS4. I have the other VWR bits with the R600, so might as well stick with the same Can do exhaust, intercooler, remap, dsg tune etc. I have done all of those and the difference is like night and day. Start with tyres would be my suggestion, especially if you have the awful Bridgestones. http://www.ebay.co.uk/itm/Racingline-Induction-Intake-Pipe-Elbow-Muffler-Pack-Vw-Golf-MK7-2-0-Turbo-R-GTI-/162588455072?hash=item25db06f0a0:g:JH8AAOSwlRpZZiN6 Quote Link to comment Share on other sites More sharing options...
Obakong Posted August 15, 2017 Report Share Posted August 15, 2017 A local tyre company half half price sale in September so was unsure between michelin pss or good year asymetric. How does the rear sway bar change the dynamics of the handling?A stiffer rear sway bar will improve handling by reducing understeer when cornering, allowing you to take corners faster. Sent from my iPhone using Tapatalk Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
Ash-Regal-Autosport Posted August 17, 2017 Report Share Posted August 17, 2017 On 15/08/2017 at 19:27, Pehen22 said: So the Mrs has now decided after 6 month I can start modifying the golf r. The only condition is I can't spend a fortune all in one go and need to treat myself every month or so which so i can't complain really. So the plan over the next 6 months engine wise will be r600 intake, down pipe and dsg/engine remap. Now for the first modification I wanted to get the turbo inlet elbow as I have been told that this is quite an easy install and the standard part is quite restrictive. Which turbo elbow is best with the r600 intake? And is there any other modifications someone would recommend after this. Thanks The best first upgrade to do is almost certainly to remove the factory turbo elbow. Either with the turbo technics intake hose which goes right up to the stock airbox. Or you can install the R600 inlet elbow which replaces the elbow only. If you want to run the R600 to make a complete intake you'd need R600 Intake Elbow > R600 Intake Hose > R600 Intake System TT Intake Hose > R600 Intake System This will give you a tangible increase in power and also complement an ECU remap, when you go for it. Checkout all of the intakes which we've tested and work really well right here http://www.regalautosport.com/shop/Shop_by_Vehicle.html/volkswagen/vw-golf-mk7-gti-r.html/vw-golf-mk7-gti-r-engine/air-intake-hoses.html On my Stage 1 and stock car I used the factory intake with a TT intake hose. Then upgraded to the IE Carbon intake, it;s currently running about 415HP & 430TQ with other upgrades too. Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
Pehen22 Posted August 17, 2017 Author Report Share Posted August 17, 2017 3 hours ago, Ash-Regal-Autosport said: The best first upgrade to do is almost certainly to remove the factory turbo elbow. Either with the turbo technics intake hose which goes right up to the stock airbox. Or you can install the R600 inlet elbow which replaces the elbow only. If you want to run the R600 to make a complete intake you'd need R600 Intake Elbow > R600 Intake Hose > R600 Intake System TT Intake Hose > R600 Intake System This will give you a tangible increase in power and also complement an ECU remap, when you go for it. Checkout all of the intakes which we've tested and work really well right here http://www.regalautosport.com/shop/Shop_by_Vehicle.html/volkswagen/vw-golf-mk7-gti-r.html/vw-golf-mk7-gti-r-engine/air-intake-hoses.html On my Stage 1 and stock car I used the factory intake with a TT intake hose. Then upgraded to the IE Carbon intake, it;s currently running about 415HP & 430TQ with other upgrades too. That's perfect ash, thats all the info that I need. I just didn't want to buy parts separately and them all not fitting together. Do forum members get any sort of discount on the regal website? Quote Link to comment Share on other sites More sharing options...
Racinghero Posted August 21, 2017 Report Share Posted August 21, 2017 On 17/08/2017 at 18:29, Pehen22 said: That's perfect ash, thats all the info that I need. I just didn't want to buy parts separately and them all not fitting together. Do forum members get any sort of discount on the regal website? Hi Ash, you say "Checkout all of the intakes which we've tested and work really well " Do you have before and after stats to show the benefits/power gained from each of these intakes/options? I'd love to know which one give most bang for buck and if the similarly priced options provide different levels of improvement? Quote Link to comment Share on other sites More sharing options...
Beast Posted August 21, 2017 Report Share Posted August 21, 2017 Hi i have a TT intake hose and well worth it. Also modified standard air box by cutting out the right hand side intake vent . removed the snow flake thing. Thinking about panel filter , then pedal box, tuning box etc Rob2k68 and Jon R306 2 Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted August 21, 2017 Report Share Posted August 21, 2017 I started with the CTS elbow (on my S3) then went for the full Revo Carbon series with large bore exit at the air box lid and integrated elbow with the hose so very similar to the TT hose but for the ‘R’ (when it arrives) I’ve gone for the APR cast elbow the the Racingline hose. Painted the elbow first though ..... 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
Mother Theresa Posted August 22, 2017 Report Share Posted August 22, 2017 JB4 coz you can sell it later for not much of a hit and get 40+hp increase. You won't get that with an elbow. 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
Pehen22 Posted August 27, 2017 Author Report Share Posted August 27, 2017 On 22/08/2017 at 16:22, Mother Theresa said: JB4 coz you can sell it later for not much of a hit and get 40+hp increase. You won't get that with an elbow. I'm getting the car remapped after Christmas so wanted to get a few parts ready for that. Ended up getting the racing line elbow and going to get the intake pipe next month. I'm just not sure whether to just get the remap and dsg map with just the elbow and intake pipe or get the r600 intake and then down pipe. I know every car is different but what figures would i be looking at with just elbow, intake pipe and remap? Quote Link to comment Share on other sites More sharing options...
Mother Theresa Posted August 29, 2017 Report Share Posted August 29, 2017 I'm going to guess at a conservative 380, but it's the exhaust that usually frees up the most ponies. Quote Link to comment Share on other sites More sharing options...
