Daveleach Posted April 29, 2018 Report Share Posted April 29, 2018 4 minutes ago, slider09 said: That’s Haldex, not DSG. Yeah easy, plenty of guides on YouTube. You need access to a scan tool such as VCDS or OBDeleven to monitor the fluid temp before checking the level. Sent from my iPhone using Tapatalk Need a designated filling system? what one do you have? Quote Link to comment Share on other sites More sharing options...
slider09 Posted April 29, 2018 Report Share Posted April 29, 2018 Need a designated filling system? what one do you have?Official way to fill is from the drain point, but you need an adapter to screw in so the new fluid can be pumped in (or gravity fed in). I saw a few videos on you tube which used the top fill method via the filter housing. I used this. Just requires a funnel and a length of plastic tube. 1. Remove air box, battery and battery tray as the filter is under this. 2. Remove filter to allow it to drain easier 3. Remove drain plug and about half a litre or less will drain out. There is a fill tube in the drain hole which needs unscrewing. Once removed the fluid in the dsg sump will drain out. Think I dropped around 4.5 / 4.7 litres. 4. Refit both fill tube and drain plug. 5. Add 5 litres via the filter housing. 6. Refit filter, air box and battery. 7. Start car and run the dsg through the gears (P > R > D etc) a couple of times. Let the fluid get up to the required temp (can’t remember the exact number), then remove drain plug only (not the full tube) and the excess fluid will drain out. 8. Refit drain plug with new seal. Think that’s roughly the steps I used. Sent from my iPhone using Tapatalk shandyman 1 Quote Link to comment Share on other sites More sharing options...
DCav Posted May 8, 2018 Report Share Posted May 8, 2018 (edited) Hi Guys. Can I ask any UK based owners where you guys are buying you spares? seems these are the parts to get the Haldex done- 1- Haldex fluid 850ml: G-060-175-A2 (x1)2- Drain plug: N-910-827-01 (x1)3- Fill Plug: N-902-818-02 (x1) 4- Pump o-rings and bolts kit (optional): 0CQ-598-305 (x1) most searches are coming up with US sites with very overpriced shipping.. Thanks Edited May 8, 2018 by DCav Quote Link to comment Share on other sites More sharing options...
Converse Posted May 8, 2018 Report Share Posted May 8, 2018 Does anyone know of a good independent in North Yorkshire that can do the Haldex service properly ? Quote Link to comment Share on other sites More sharing options...
shandyman Posted May 8, 2018 Report Share Posted May 8, 2018 4 hours ago, DCav said: Hi Guys. Can I ask any UK based owners where you guys are buying you spares? seems these are the parts to get the Haldex done- 1- Haldex fluid 850ml: G-060-175-A2 (x1)2- Drain plug: N-910-827-01 (x1)3- Fill Plug: N-902-818-02 (x1) 4- Pump o-rings and bolts kit (optional): 0CQ-598-305 (x1) most searches are coming up with US sites with very overpriced shipping.. Thanks Haldex fluid looks right - I got mine from VW at £40 inc VAT The other three parts I didn't purchase and used existing - I think they are only available as part of a kit; it's been mentioned elsewhere on this forum I think. Quote Link to comment Share on other sites More sharing options...
shandyman Posted May 8, 2018 Report Share Posted May 8, 2018 3 hours ago, Converse said: Does anyone know of a good independent in North Yorkshire that can do the Haldex service properly ? No but I took mine to a local garage and asked them to supply the labour if I supplied the instructions and fluid! They also supplied the fluid tall drain tray and syringe to re-fill. Quote Link to comment Share on other sites More sharing options...
EcosseGolfR Posted May 30, 2018 Report Share Posted May 30, 2018 I'm getting the Haldex pump o-rings and the 2 bolts from local VW dealership for £18.26, part number 0CQ598305. I'll enquire about the other parts ( Haldex fluid, drain and fill plugs) when i pick up the seals later on this week. On another note: got a price from an independent VW garage for Haldex pump removal, filter clean and oil change...came in at £112, oil change alone was £75. Quote Link to comment Share on other sites More sharing options...
Micky 32 Posted June 12, 2018 Report Share Posted June 12, 2018 Jaysus! I know it's not a Golf but i have a diesel 2017 Passat 240 remapped to 290bhp but it has the same Haldex unit. Mine is at 40k and never touched! I'm dreading opening mine, i'm going to do mine on Thursday. I have the 0 rings and the oil. I can post the photo's of the 40k build up, that's if nobody minds on here because it's not a Golf R? Jon R306, E-V-A-N-S and gregozedobe 3 Quote Link to comment Share on other sites More sharing options...
BobbyT Posted June 13, 2018 Report Share Posted June 13, 2018 go for it Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 13, 2018 Report Share Posted June 13, 2018 I'm getting the Haldex pump o-rings and the 2 bolts from local VW dealership for £18.26, part number 0CQ598305. I'll enquire about the other parts ( Haldex fluid, drain and fill plugs) when i pick up the seals later on this week. On another note: got a price from an independent VW garage for Haldex pump removal, filter clean and oil change...came in at £112, oil change alone was £75.Haldex oil is £40 from VW (£36 ish from TPS). If they are saying £75, I would double check they are using the correct oil. You need HALDEX oil not rear diff oil (they are different). Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
EcosseGolfR Posted June 13, 2018 Report Share Posted June 13, 2018 cheers @slider09 i'll double check before performing the service but its a Audi RS & VW Independent dealer so i'd be shocked if they didn't know the difference. Even for VW to do the Haldex its £70 for the oil change (just checked their site)....no filter clean. So what i stated above seems correct? Quote Link to comment Share on other sites More sharing options...
slider09 Posted June 13, 2018 Report Share Posted June 13, 2018 cheers [mention=21083]slider09[/mention] i'll double check before performing the service but its a Audi RS & VW Independent dealer so i'd be shocked if they didn't know the difference. Even for VW to do the Haldex its £70 for the oil change (just checked their site)....no filter clean. So what i stated above seems correct?Apologies....I read your comment as ‘oil alone is £75’ (ie just to buy the oil)It’s been a long day Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
EcosseGolfR Posted June 13, 2018 Report Share Posted June 13, 2018 1 minute ago, slider09 said: Apologies....I read your comment as ‘oil alone is £75’ (ie just to buy the oil) It’s been a long day Sent from my iPhone using Tapatalk I know what those long days are like.......😀 slider09 1 Quote Link to comment Share on other sites More sharing options...
Micky 32 Posted June 14, 2018 Report Share Posted June 14, 2018 Here goes! 39,330 miles: Jon R306 1 Quote Link to comment Share on other sites More sharing options...
Micky 32 Posted June 14, 2018 Report Share Posted June 14, 2018 2 minutes ago, Micky 32 said: Here goes! 39,330 miles: P.S mine is a F unit. Quote Link to comment Share on other sites More sharing options...
