discolegend73 Posted January 11, 2019 Report Share Posted January 11, 2019 17 plate 10k 2 year service is it minor or a main service? Says oil service in 21days on the dash? Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
vagnum Posted January 15, 2019 Report Share Posted January 15, 2019 Inspection with oil service inc pollen filter and air conditioning service is more than likely due being 2 years old. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
grahamstevo123 Posted January 16, 2019 Report Share Posted January 16, 2019 As long as you use your air con a little bit all year round you will never need the air con service. Don’t pay them £70 to refresh it if it still blowing out cold air! Bob and Booth11 1 1 Quote Link to comment Share on other sites More sharing options...
vagnum Posted January 16, 2019 Report Share Posted January 16, 2019 As long as you use your air con a little bit all year round you will never need the air con service. Don’t pay them £70 to refresh it if it still blowing out cold air! If that’s what you want to think Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
MassMassa Posted January 16, 2019 Report Share Posted January 16, 2019 Air con doesn't need servicing if it's used regularly. You're more likely to suffer issues if serviced incorrectly. Ask VW Harrogate who had to pay for my new compressor a few years ago! grahamstevo123 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 16, 2019 Report Share Posted January 16, 2019 12 hours ago, grahamstevo123 said: As long as you use your air con a little bit all year round you will never need the air con service. Don’t pay them £70 to refresh it if it still blowing out cold air! 5 minutes ago, MassMassa said: Air con doesn't need servicing if it's used regularly. You're more likely to suffer issues if serviced incorrectly. Ask VW Harrogate who had to pay for my new compressor a few years ago! This. Use aircon year round and it looks after itself. In 14 years of Golf ownership I’ve never had to have aircon serviced at two years. If it’s still doing it’s job then it’s fine. grahamstevo123, Shug, jrw and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
NP46 Posted January 17, 2019 Report Share Posted January 17, 2019 On the subect of services, phoned a main dealer to quote me for a year 3 service and worryingly they asked me if it was minor or major i required......so Is a year 3 service minor or major, Lookers think minor with a haldex but only after I told them the haldex was due ffs.... Quote Link to comment Share on other sites More sharing options...
Bob Posted January 17, 2019 Report Share Posted January 17, 2019 3 hours ago, NP46 said: On the subect of services, phoned a main dealer to quote me for a year 3 service and worryingly they asked me if it was minor or major i required......so Is a year 3 service minor or major, Lookers think minor with a haldex but only after I told them the haldex was due ffs.... Brake fluid needs changing too. Me and my indie dont call them minor or major and I usually do engine oil changes out of sinc and more often. You need engine oil change, inspection, haldex oil and brake fluid change. Year 4 is DSG oil change. I use a fully VAG equipped indie. Car not been near a dealer since purchased. After 3 years need brake fluid changing every two years. No idea why initially lasts 3 years from the factory. https://www.volkswagen.co.uk/owners/servicing/what-we-check-and-why Have a look at above link. Actually says dsg oil change every 40k miles. Cam belt 5 years and spark plugs every major service whatever that means (If every other service I think not!) Haldex oil used to be every 4 years but now every 3. Many dealers haven't realised... Quote Link to comment Share on other sites More sharing options...
slider09 Posted January 17, 2019 Report Share Posted January 17, 2019 Brake fluid needs changing too. Me and my indie dont call them minor or major and I usually do engine oil changes out of sinc and more often. You need engine oil change, inspection, haldex oil and brake fluid change. Year 4 is DSG oil change. I use a fully VAG equipped indie. Car not been near a dealer since purchased. After 3 years need brake fluid changing every two years. No idea why initially lasts 3 years from the factory. https://www.volkswagen.co.uk/owners/servicing/what-we-check-and-why Have a look at above link. Actually says dsg oil change every 40k miles. Cam belt 5 years and spark plugs every major service whatever that means (If every other service I think not!) Haldex oil used to be every 4 years but now every 3. Many dealers haven't realised...Brake fluid due at year 3, then every 2 yearsHaldex every 3 years / 30kDSG is at 40k milesNo cambelt on the R, it’s a chainSpark plugs / air filter is 60k miles / 6 yearsSent from my iPhone using Tapatalk Bob 1 Quote Link to comment Share on other sites More sharing options...
2slow Posted January 17, 2019 Report Share Posted January 17, 2019 Dsg and Haldex should be done. Well befor dealers. Recommendations it’s unreasonable to expect. Oil that helps lubricate and cool the cluches down. To last 30.000 miles had mine done at 10.000 and they didn’t even reset the gearbox service miles as the mileage from the box is stored on its own ecu brake fluid should be done every 2 years due. To degraded fluid my opinion. For. Those among us that have tuned engines the service interval should be a lot sooner. Quote Link to comment Share on other sites More sharing options...
vagnum Posted January 17, 2019 Report Share Posted January 17, 2019 Nice to see all the professional air conditioning engineers on here sharing there knowledge about air conditioning system and why they don’t need servicing. golf7.5r 1 Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted January 17, 2019 Report Share Posted January 17, 2019 10 minutes ago, vagnum said: Nice to see all the professional air conditioning engineers on here sharing there knowledge about air conditioning system and why they don’t need servicing I make no claims about being an a/c professional, but my 12 year old T5 van has had zero work done on the a/c and it is still producing sufficient cold air to cope with hot Oz conditons (41C today), same goes for my 10 year old Octavia vRS. Based on this long term real world experience I'm quite willing to forgo the dealer profit-motivated regular servicing until my a/c actually has a problem. Perhaps you can share your professional a/c engineering expertise with us and tell us exactly what needs to be done and why, plus what will happen if we don't - maybe I have been flirting with disaster all these years ? Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 17, 2019 Report Share Posted January 17, 2019 1 hour ago, vagnum said: Nice to see all the professional air conditioning engineers on here sharing there knowledge about air conditioning system and why they don’t need servicing. Just shared views from some real world users who take more than the average interest in their cars and collectively have a fair amount of experience of Golfs and their aircon behaviour on a daily basis and over a number of years operation. 1 hour ago, gregozedobe said: Based on this long term real world experience I'm quite willing to forgo the dealer profit-motivated regular servicing until my a/c actually has a problem. Me too. Quote Link to comment Share on other sites More sharing options...
LapizzR Posted January 17, 2019 Report Share Posted January 17, 2019 how does servicing work on the r then? condition based? what prices are we talking about here as i've heard some ludicrous prices Quote Link to comment Share on other sites More sharing options...
MassMassa Posted January 17, 2019 Report Share Posted January 17, 2019 2 hours ago, vagnum said: Nice to see all the professional air conditioning engineers on here sharing there knowledge about air conditioning system and why they don’t need servicing. You're welcome Booth11 1 Quote Link to comment Share on other sites More sharing options...
