TurboTrev Posted March 25, 2025 Report Share Posted March 25, 2025 I was looking at these smoked dynamics for £20.51 - https://www.ebay.co.uk/itm/355619596459?fits=Car+Make%3AVW|Plat_Gen%3AMK+VIII|Model%3AGolf&_skw=vw+golf+mk8+mirror+indicators&itmmeta=01JQ728RV02SAXTDRRWFSY7AQ6&hash=item52cc9468ab:g:zfEAAOSwOt5mFT1a&itmprp=enc%3AAQAKAAAA4FkggFvd1GGDu0w3yXCmi1eJ9zT9VEqZMJMwyM7nZZhvfOwm%2BG3laM%2Fj%2BXKAdeUL81nY88rbCfLOGHx6ZdaSA8scAArA5TLrxj8ZUv14XyGHn4JT40NJ7304cA6cYBvPqpaL6NajJ9EjfVTztodzfDH1gZ9r%2F6RN8K2WDE9SEQPfAMYlqMsvhXn3jpYL6PyZJmIpe%2FJiS1lHthrrK7SD%2FjA1hkQTEdhUvsJ6tMiFg594FUC%2BEl%2BEcYKpJxPmXhu8%2BDVr5UfAAv07CehDXCDBJyzR66AjYjQ3A4ki1CVeoE9A|tkp%3ABk9SR9yNo-K5ZQ Quote Link to comment Share on other sites More sharing options...
AHG Posted March 25, 2025 Report Share Posted March 25, 2025 It would look cool if that bright stripe would disappear when the blinkers are not used … Oh, man, this forum is always making me spend money. Bad, bad forum 🙂 Quote Link to comment Share on other sites More sharing options...
scuderiafolene Posted March 25, 2025 Report Share Posted March 25, 2025 Well. 9" 245/40 contisport7 is pushing it. lol This is clearance with 5mm spacer. Would not recommend running it on the street. Rears, with 10mm spacer cause with 5 they where rubbing and without they cant fit. It will be 10mm all around cause fronts are bit wee tight to my liking. All on standard suspension, and if you pick/picked DCC you see the valve on the middle picture being danger close. Nighthawk and Booth11 2 Quote Link to comment Share on other sites More sharing options...
chillly Posted March 25, 2025 Report Share Posted March 25, 2025 On 23/03/2025 at 17:38, AHG said: No luck for me with suction cup just fingers and tool and lots of force Yes using trim tool with the suction cup works a treat. Less stress on the glass when pulling with the suction cup👍 I have used fingers, fingers and trim tool and trim tool with suction cup. The later is so much easier and safer👍👍 also much easier to replace the mirror using the suction cup👌 Quote Link to comment Share on other sites More sharing options...
JoeGTI7 Posted March 25, 2025 Report Share Posted March 25, 2025 11 minutes ago, chillly said: Yes using trim tool with the suction cup works a treat. Less stress on the glass when pulling with the suction cup👍 I have used fingers, fingers and trim tool and trim tool with suction cup. The later is so much easier and safer👍👍 also much easier to replace the mirror using the suction cup👌 what “suction cup” do you have @chillly? Quote Link to comment Share on other sites More sharing options...
Nighthawk Posted March 25, 2025 Report Share Posted March 25, 2025 41 minutes ago, scuderiafolene said: Well. 9" 245/40 contisport7 is pushing it. lol This is clearance with 5mm spacer. Would not recommend running it on the street. Rears, with 10mm spacer cause with 5 they where rubbing and without they cant fit. It will be 10mm all around cause fronts are bit wee tight to my liking. All on standard suspension, and if you pick/picked DCC you see the valve on the middle picture being danger close. OMG that's super close 😳 looks mad 😂👍🏼 Quote Link to comment Share on other sites More sharing options...
Nighthawk Posted March 25, 2025 Report Share Posted March 25, 2025 44 minutes ago, scuderiafolene said: Well. 9" 245/40 contisport7 is pushing it. lol This is clearance with 5mm spacer. Would not recommend running it on the street. Rears, with 10mm spacer cause with 5 they where rubbing and without they cant fit. It will be 10mm all around cause fronts are bit wee tight to my liking. All on standard suspension, and if you pick/picked DCC you see the valve on the middle picture being danger close. As mentioned before I'm running 245 35 19 on 8” with no spacer and it's a little closer to dampers than with 235 but not that much, In theory a half a centimeter closer. I'll try take some pics tomorrow so we can compare. scuderiafolene 1 Quote Link to comment Share on other sites More sharing options...
nn7man Posted March 25, 2025 Report Share Posted March 25, 2025 Just totting up my purchases, fitted so far: Full detail with G-Techniq Ultra and paint correction Meta Trak S5 with Deadlock R Valve Caps Kopacek Footrest OEM Door Sill Vinyls OEM Boot Liner OEM Boot Net OEM Warning Triangle OEM First Aid Kit OEM Hi Viz Vest OEM Lanyard OEM LED Torch RL Oil Cap RL Fuel Cap RL Brake Fluid Cap RL Coolant Cap RL Washer Fluid Cap RL Bonnet Gas Strut RL Wheel Change Pin On Order: OEM Osram Dynamic Mirror Cap Lights, White Edition OEM R Dynamic Hub Caps OEM Load Sill Protection Kevinb and chillly 2 Quote Link to comment Share on other sites More sharing options...
chillly Posted March 26, 2025 Report Share Posted March 26, 2025 7 hours ago, nn7man said: Just totting up my purchases, fitted so far: Full detail with G-Techniq Ultra and paint correction Meta Trak S5 with Deadlock R Valve Caps Kopacek Footrest OEM Door Sill Vinyls OEM Boot Liner OEM Boot Net OEM Warning Triangle OEM First Aid Kit OEM Hi Viz Vest OEM Lanyard OEM LED Torch RL Oil Cap RL Fuel Cap RL Brake Fluid Cap RL Coolant Cap RL Washer Fluid Cap RL Bonnet Gas Strut RL Wheel Change Pin On Order: OEM Osram Dynamic Mirror Cap Lights, White Edition OEM R Dynamic Hub Caps OEM Load Sill Protection And a partridge in a pear tree 😁😎 that’s some list 👍 Nighthawk 1 Quote Link to comment Share on other sites More sharing options...
chillly Posted March 26, 2025 Report Share Posted March 26, 2025 8 hours ago, JoeGTI7 said: what “suction cup” do you have @chillly? I have this and the 50mm ones from Amazon. The lazer one is half the price compared to the Wurth. https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwjqvbqih6eMAxVoj1AGHXbZDsAYABAaGgJkZw&co=1&gclid=EAIaIQobChMI6r26ooenjAMVaI9QBh122Q7AEAQYASABEgIx0_D_BwE&cit=EAIaIQobChMI6r26ooenjAMVaI9QBh122Q7AEAQYASABEgIx0_D_BwE&ei=T5bjZ6bJGsjPhbIPp6Ow0QE&ohost=www.google.com&cid=CAASJeRoDE2seGOCBYge7Q8szPtUTgA1HKDu-mQj9EmSxklYMd44JDY&sig=AOD64_2sDQ95KuVr1SXrZj1HZDW3GZUPKw&ctype=5&q=&sqi=2&ved=2ahUKEwjmrLaih6eMAxXIZ0EAHacRLBoQwg8oAHoECAkQDQ&adurl= JoeGTI7 1 Quote Link to comment Share on other sites More sharing options...
Tethias Posted March 26, 2025 Report Share Posted March 26, 2025 On 24/03/2025 at 11:37, JoeGTI7 said: Great job with the spoiler @Tethias! Huge improvement. Its interesting that it can be purchased pre-painted too, which makes the whole thing easier. Can you elaborate on how simple it was to fit? Is the old one simply bolted on or is there any adhesive involved? And new one is a direct swap with no faff required to make it fit? Pretty easy to do really, probably took 30 minutes. Followed the video here: It's a complete bolt on replacement, completely replaces the standard spoiler, so no adhesive needed. Just 5 nuts, 2 bolts and a bunch of trim clips JoeGTI7 and scuderiafolene 2 Quote Link to comment Share on other sites More sharing options...
AndyNo1 Posted March 26, 2025 Report Share Posted March 26, 2025 17 hours ago, TurboTrev said: I was looking at these smoked dynamics for £20.51 - https://www.ebay.co.uk/itm/355619596459?fits=Car+Make%3AVW|Plat_Gen%3AMK+VIII|Model%3AGolf&_skw=vw+golf+mk8+mirror+indicators&itmmeta=01JQ728RV02SAXTDRRWFSY7AQ6&hash=item52cc9468ab:g:zfEAAOSwOt5mFT1a&itmprp=enc%3AAQAKAAAA4FkggFvd1GGDu0w3yXCmi1eJ9zT9VEqZMJMwyM7nZZhvfOwm%2BG3laM%2Fj%2BXKAdeUL81nY88rbCfLOGHx6ZdaSA8scAArA5TLrxj8ZUv14XyGHn4JT40NJ7304cA6cYBvPqpaL6NajJ9EjfVTztodzfDH1gZ9r%2F6RN8K2WDE9SEQPfAMYlqMsvhXn3jpYL6PyZJmIpe%2FJiS1lHthrrK7SD%2FjA1hkQTEdhUvsJ6tMiFg594FUC%2BEl%2BEcYKpJxPmXhu8%2BDVr5UfAAv07CehDXCDBJyzR66AjYjQ3A4ki1CVeoE9A|tkp%3ABk9SR9yNo-K5ZQ I think they look similar to the other ones I had that didnt fit perfectly. Quote Link to comment Share on other sites More sharing options...
chillly Posted March 26, 2025 Report Share Posted March 26, 2025 Just ordered one of these, https://www.google.com/url?q=https://maxshine.co.uk/products/maxshine-wheel-tyre-cleaning-stand&sa=U&sqi=2&ved=2ahUKEwjjgZPshJmMAxVGX0EAHahpKXwQFnoECB4QAQ&usg=AOvVaw2RIYqHFO3QMwJp9eRpxJmf However to possibly save you money, im sure this is the same just without the sticker? https://www.google.co.uk/aclk?sa=L&ai=DChcSEwi0prfT56eMAxX1llAGHRUxJ6AYABAiGgJkZw&co=1&gclid=EAIaIQobChMItKa30-enjAMV9ZZQBh0VMSegEAQYASABEgKpUfD_BwE&sig=AOD64_2X3LA0YjEfVO1V0LcbJxxpVietRA&ctype=5&q=&ved=2ahUKEwia4rHT56eMAxXWQkEAHfxqHD0Q9aACKAB6BAgHEBU&adurl= Nighthawk, luton-stu and Booth11 3 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted March 26, 2025 Author Report Share Posted March 26, 2025 As per the detailing purchase thread…. Decided it was time to upgrade my ageing Metrovac car dryer, as the car dryer game has moved on in the last 10 years with much more powerful models around now. Narrowed it down to between the Blo Air-GT and the Rokit Resolution 2. Decided to go for the Rokit as it’s slightly better on CFM/CFM than the Blo, but otherwise they are much the same. chillly, Nighthawk and AHG 3 Quote Link to comment Share on other sites More sharing options...
scuderiafolene Posted March 26, 2025 Report Share Posted March 26, 2025 On 19/03/2025 at 08:10, Tethias said: PP Spoiler has arrived! That's a job for this weekend then... Do you mind me asking where did you order it from? Looks mint, OEM? Quote Link to comment Share on other sites More sharing options...
