MK 7 R OPERATING TIPS/TRICKS
Kickdown/DSG - there is a discernible difference when putting your foot down to do a quick overtake - medium/high pressure applied quickly on the throttle gives you kickdown, but push the throttle pedal a little further and you feel an extra 'click' to give you super kickdown.  :cheesy:  An example, you're in D (Race mode - of course) doing 50mph and in 6th gear. You go for kickdown, car changes to 3rd gear - whooosh.
Same example, but this time, apply the same amount of pressure to the throttle pedal and then apply a bit more pressure at the end until you feel an extra 'click'. Car changes to 2nd gear and you get super kickdown and super whoosh.  :nerd:
i find pulling the dsg stick towards you enabling s mode from d is a bit less jerky when going to overtake,still drops down a few gears,i use this way a lot!! :cool:
If you don't like the Soundaktor noise on the motorway, when it can become a bit of a drone; customise individual mode for quieter motorway driving.
Set everything in individual mode to sport or race so that the ACC etc. is as aggressive as VW permits and then put the engine in ECO. This turns off the Soundaktor and closes two exhaust flaps. (Don't worry... if you press past the kick down switch the engine will open those flaps and give you the full experience, to quickly pass a car or fill a gap).
Having never had a german car before someone told me this cool feature (which im sure everyone knows but hey):
Turn on Coutsey windows In the car menu and choose either front windows or front and rear and then whenever its a hot day when you unlock your car using the fob hold it down for 3-5 seconds and the windows will go down. Same goes when you lock your car, just hold the lock button and the windows will shut.
By request a post where you can post your way of finding the best way to operate R Gizmos :afro:
To start with, If you don't like stop/start get into the habit of hitting the override button as you come out of
park or select a gear :afro: .
When using auto hold your brake light stay on so if in traffic just flick the handbrake switch and they go out .
Re the handbrake keeping the brake lights on, this is a ridiculous feature and must be maddening for cars behind especially since we've all got three brake lights now instead of two. I know I've been noticing more and more cars sat at junctions or traffic lights with their brake lights on lately. Seems I'm one of them  :sad:
Thanks for the tip Harry, but I'll prob forget to use it!
Autohold isn't the handbrake though, its just 'autohold'ing the standard brakes. You can feel it in the pedal when its activated.
If you are really that bothered apply the hand brake manually by hitting the switch.
I personally love this feature
I don't get no Bad Boy Boost when flooring it as described here.
Even on the closest, most aggressive setting ACC starts to slow you down a fraction earlier than I like. I.e. Just before I'm about to move out into an overtaking lane.
However, as soon as you indicate right to pull out the car recognises that you're avoiding the slower vehicle in front and doesn't slow. My advice is; indicate to overtake early.
