CinnamonRage Posted July 9, 2014 Report Share Posted July 9, 2014 I always have esc off. Unless the roads are wet, then I turn it on. Very unusual normally most leave it on might just help one day when you forget your Stig Blomqvist baseball hat and racing gloves It improves throttle response. Try it. You might like it! Doesn't it also invalidate your insurance, turning it off? Sent from my iPhone using Tapatalk Matt H 1 Quote Link to comment Share on other sites More sharing options...
Rconvert Posted July 13, 2014 Report Share Posted July 13, 2014 I've set the Rain sensor to ON in the car menu. Do I have to have the stalk set to a particular position to have it operate correctly. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rconvert Posted July 13, 2014 Report Share Posted July 13, 2014 I've set the Rain sensor to ON in the car menu. Do I have to have the stalk set to a particular position to have it operate correctly. Sent from my iPad using Tapatalk One up from off Thank you sir. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Popular Post JonnyG Posted July 4, 2015 Popular Post Report Share Posted July 4, 2015 I thought about starting a thread like this, but found this old one ! I'm surprised it fizzled out as they can be really useful for new users to get up to speed with all the tech of the Mk 7 R. A few tips I've found from the forums (some old .. some new for the Mk 7) are : 1. Race Mode : The consensus from other threads is that full Race Mode does not activate after turning your engine off and restarting : DSG cars : When restarting, Race mode is still selected but the DSG has reverted back to normal D mode. In D mode the exhaust flaps do not appear to open as fully or readily as in S mode. So to get back to full blown race mode you either need to cycle through the engine modes again to Race mode (which puts the DSG into Sport mode too) OR you just select Sport mode again with the DSG. This is consistent with my findings too. Manual Cars : Most people have said that on restarting, Race mode is still selected but the exhaust note seems a lot quieter and in order to get back to full open flaps / exhaust note you need to reselect race mode again. 2. Hill Hold / Stop Start - DSG ONLY - As Fruit says above - Hill Hold and Stop / Start can both be controlled by a sensitive foot on the brake pedal. Very light braking will activate neither, a light foot on the brake will activate hill hold and a firmer press will activate Stop / Start (subject to conditions). My tip for DSG owners is just be careful with your right foot when Stop / Start has turned you engine off - an accidental stab of the accelerator will start your engine and get you moving forward again quite quickly. 3. Windscreen Wiper Wash Position - When washing the car you can put the windscreen wipers in service mode by turning the ignition on, turning it off again and then pressing the wiper stalk down within around 5 seconds. The wipers will go up and stay up, enabling you to lift them off the windscreen without the risk of chipping your bonnet edge ! 4. Scrolling Up/Down Touch Screen - The right hand dial under the central screen (i.e. the opposite side to the volume control) can be used to scroll up and down the screen, rather than using your finger on the touch screen. 5. Silencing Park Control Temporarily. If your park control beeper comes on when stuck in a queue of traffic you can mute the sound of the beeps (so that your music comes back at normal volume) by pressing the symbol with a loudspeaker and diagonal line on it (bottom right of screen I think). Pressing the cross X (top right) does not work as I found out several times). This is temporary and the beeps will return next time. 6. DSG Manual Mode - OK this is an obvious one and 99% will know this, but I do wonder whether all "new to DSG" owners realise this having read a few threads on here, as it's not that obvious from just sitting in the car and looking at the marked DSG lever positions which don't even hint at this IMHO, and if you haven't read the manual of course !. To get into proper manual DSG mode and stay in manual mode permanently you need to physically move the gear stick to the left. It can't be done by just using the paddles as this just overrides it for a short temporary period. I'm surprised VW didn't label this more clearly on the console. 7. Instrumental panel lighting levels can be dimmed / brightened from the car settings menu. Unfortunately there is no quick and easy dial next to the light switch any more. Lets have a load more tips / tricks as I still seem to be learning new stuff after 4 months Gards, Cdj3.2, kolev17 and 52 others 9 46 Quote Link to comment Share on other sites More sharing options...
VW7R Posted July 4, 2015 Report Share Posted July 4, 2015 JonnyG: I would like to like your post 10 times at least but can't! Hung_Tran and Lancslad 2 Quote Link to comment Share on other sites More sharing options...
karlie88 Posted July 4, 2015 Report Share Posted July 4, 2015 Most of you probably know this but for those who don't: Auto-lock feature - doors lock when you reach a speed of about 10mph. Can be done through the MDI settings and become saved. One of the first things I did - Auto-braking/front assist - sometimes this comes on despite the fact that you know you're in control of the given situation. Usually a red warning appears on the dash followed by an audible warning. Can be manually switched off every time you enter the car via MDI settings. Other options are to press 'OK' on the steering wheel and/or press the accelerator slightly when the warning appears. Another option is to apply the brake gently when you think the warning light is about to appear - thus, letting the car know you're aware of the situation in front of you at that time. Kickdown/DSG - there is a discernible difference when putting your foot down to do a quick overtake - medium/high pressure applied quickly on the throttle gives you kickdown, but push the throttle pedal a little further and you feel an extra 'click' to give you super kickdown. An example, you're in D (Race mode - of course) doing 50mph and in 6th gear. You go for kickdown, car changes to 3rd gear - whooosh. Same example, but this time, apply the same amount of pressure to the throttle pedal and then apply a bit more pressure at the end until you feel an extra 'click'. Car changes to 2nd gear and you get super kickdown and super whoosh. JonnyG, Irvine, KianA320 and 4 others 1 6 Quote Link to comment Share on other sites More sharing options...
Bigfletch49 Posted July 4, 2015 Report Share Posted July 4, 2015 I love super wooosh!!! Alan, RyanB, Slippa and 1 other 4 Quote Link to comment Share on other sites More sharing options...
Little Jack Posted July 4, 2015 Report Share Posted July 4, 2015 Cruise Control - adjust the speed by 1mph increments (rather than 5mph with the + - rocker switch ) by using the RES and SET buttons on the steering wheel. Demise, xSCYTHERx, Stricky239 and 17 others 4 16 Quote Link to comment Share on other sites More sharing options...
springbrucesteen Posted July 4, 2015 Report Share Posted July 4, 2015 yeah super whoosh sounds good. will try super whoosh tomorrow , I havent tried launch control yet ! some good tips here , didnt know brake lights stayed on with auto hold cheers harry Quote Link to comment Share on other sites More sharing options...
Dextergregor Posted July 5, 2015 Report Share Posted July 5, 2015 To deactivate the cars internal movement sensors when you lock the car (for example if you leave your dog in it while at the shops). Press the button located at the base of the driver's side b-pillar. It's easily accessible when the driver's door is opened. The button glows orange when depressed. Once done and the car doors locked with the key fob, movements within the car do not set off the car's alarm. TheAlbionist, dexter, Soche and 5 others 2 1 5 Quote Link to comment Share on other sites More sharing options...
Stubsy Posted July 5, 2015 Report Share Posted July 5, 2015 To deactivate the cars internal movement sensors when you lock the car (for example if you leave your dog in it while at the shops). Press the button located at the base of the driver's side b-pillar. It's easily accessible when the driver's door is opened. The button glows orange when depressed. Once done and the car doors locked with the key fob, movements within the car do not set off the car's alarm.Useful channel tunnel/ferry crossings too. I've noticed when in D mode going down an incline, in traffic and speed needs to be restrained. That you can select lower gears with left paddle and the car will hold this gear for the duration of the incline. Saves riding the brakes (I think this is a brilliant piece of engineering and planning) Wagon R, Mjbrooke, PeteSoulDeep and 3 others 1 5 Quote Link to comment Share on other sites More sharing options...
TechieAli Posted July 5, 2015 Report Share Posted July 5, 2015 ... 6. DSG Manual Mode - OK this is an obvious one and 99% will know this, but I do wonder whether all "new to DSG" owners realise this having read a few threads on here, as it's not that obvious from just sitting in the car and looking at the marked DSG lever positions which don't even hint at this IMHO, and if you haven't read the manual of course !. To get into proper manual DSG mode and stay in manual mode permanently you need to physically move the gear stick to the left. It can't be done by just using the paddles as this just overrides it for a short temporary period. I'm surprised VW didn't label this more clearly on the console. .... A further note to this is that if the gearbox is in S it leaves the exhausts open too. So you can drive like normal with the better exhaust note. Quote Link to comment Share on other sites More sharing options...
JonnyG Posted July 5, 2015 Report Share Posted July 5, 2015 A further note to this is that if the gearbox is in S it leaves the exhausts open too. So you can drive like normal with the better exhaust note. Good point, yes .... if you move the gear stick to the left into manual mode from S mode, the exhaust note does sound better than if you move it left from D mode. Quote Link to comment Share on other sites More sharing options...
markymark34 Posted July 5, 2015 Report Share Posted July 5, 2015 A further note to this is that if the gearbox is in S it leaves the exhausts open too. So you can drive like normal with the better exhaust note.This is a great point and one i didnt realise for a while. IMO it's the one irritating feature with the dsg box. I want flaps open but not S mode as I don't want to be sitting in stupidly low gears all the time. Why is there not an exhaust flap setting in the in board computer? GoalsGoneWild 1 Quote Link to comment Share on other sites More sharing options...
mikeoz Posted July 5, 2015 Report Share Posted July 5, 2015 If you use the paddels and it goes in to manual mode and you want to get it back to D with out using the gear stick (dsg) press and hold the right paddel. The D symbol will then pop up in the display. Matt Blink, GolfCaddy, dexter and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
