Facelift Mods
ARi
11 hours ago, dv52 said:
I have both good and a bad news regarding your question:
The good news answer is, yes.
If you select the Dashboard module @ address hex17 and then select adaptation and then search for "outside_temperature" , you should see the following channels
p_ice_warning_entry_temperature, which has a default value of 4 °C (i.e.39 °F)
p_ice_warning_exit_temperature,which has a default value of 6 °C (i.e. 43 °F)
Not sure if you are familiar with the term 'hysteresis" (it's a method of dynamic-lag that is sometimes used in control systems), but this is how these two channels operate. The entry channel value is the threshold temperature at which the black-ice alarm will be set and the exit channel is the threshold temp. at which the alarm will clear (i.e. at the warmer temperature). If only one threshold temperature is used, the alarm would "hunt" (i.e. continuously turn ON/OFF) as the car traveled through different temperature zones. But with hysteresis control, the black-ice alarm remains more constant with changing ambient temperature.
So, if you are going to change the value in one of these channels, I suggest that you also change the other channel value so that there is ALWAYS 2°C difference -this maintains the size of the hysteresis differential.
OK, so now for the bad news answer!
To change the value in the 2 x adaptation channels above, you will need a security access code. This code was 20103 in early versions of the dashboard module, but I'm not aware that the code has been found for newer modules. Happy to be proven wrong
Legend! Thanks mate. I will have a go and see if I can get through the security side.
  • 3 weeks later...
Hi all, appreciate a little help here.
I tried adding both lock/unlock sound and auto coming home lights, but I can't seem to see the menu on the car settings.  I turn the ignition on, plug in my obdeleven and connect.  I've made the changes and pressed and held the green tick till it asks me to enter in the security code which is 31347, then it said changes have been saved.
I turned the ignition off, unplugged the obdeleven locked and unlocked the car but the settings haven't appeared in my car menu nor any of the functions working.  I've gone back into the app to check to see if the settings were saved and they have been, is there something I'm missing?
You need to enable the chirp
Then enable the option in the Pro
Can’t remember if you have to go into the pro and reset the relevant system setting to factory for the option to show up or just press the on/off for 10 secs plus to reset it.
Either way I had it set up on my 7.5 R.
17 minutes ago, Privatedoc said:
would love my chirp to work too but it is exactly as Panda88 describes....any help folks???
I just realised there was one option I didn't select and overlooked and it was enabling the selection to be visible on the car settings menu, seems to be visible in the car menu and chirp works on lock and unlock, double check that you enabled this option too?
Select ACTIVE for Menuesteuerung akustische Rueckmeldung (Acoustic lock menu)
Still can't get my auto come home lights to work though!
Have you tried resetting the lighting section in MIB? I vaguely remember mine not working straight away.....
Also, what time do you have them set to stay on for in the settings? Try adjusting it and see what happens, try at least 15seconds or more.
I'll have a go at doing that, I have them set for 15 seconds on the settings, tried turning both off, coming out of the settings and going back in and putting them to 15 seconds - didn't work
21 minutes ago, Privatedoc said:
Panda88, I'm still using OBD11, can it be done with this rather than full vag-com????
Yea, it's on the same menu as the other two changes you need to make under acknowledgement signals - it's just a bit further down if you scroll down you should see it, once I did that it appeared on my car settings and I was able to enable it.
Try setting them to 20 secs or more. I'm sure I had to do that to make them first work.
Once working you can put them back down to 15secs no problem and they will still work.
Just went back to the car to have another play and they seem to work when I unlocked, must have needed to be left alone to compute the changes!
Thanks!
On ‎12‎/‎08‎/‎2017 at 11:32, ARi said:
VW Golf MK 7.5 Facelift
Scandinavian DRL
09 - Central Electrics
Adaptations
Select – Aussenlicht_Front- Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht – Set to Active
Thanks for the helpful post. I can't find this line of coding in mine for rear DRL's only this :-
ENG116593 Außenlicht_Front- Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
Which also illuminates the number plate lights so in effect just enables the side lights.
  • 2 weeks later...
The funny looking B is the scharfes s or double s - so the same
Sent from my Nexus 7 using Tapatalk
On 12/14/2017 at 22:32, Rozkipz said:
Can OBDEleven put android auto on the digital dash? The lack of proper traffic data drives me insane with the built in nav, but love it being directly in my line of sight.
Rozkipz: So - in your part of the world, what happens when you press the TRAFFIC button on the MIB escutcheon plate?
Down here in the Antipodes, we have traffic reports that are sent over a sub-harmonic frequency of our FM radio. We can enable this facility by entering a code into the TMC adaptation channel on the MIB module. If we have RDS (Radio Data Service) enabled, this gives us a list of traffic reports in real time which appears as a list when we press the TRAFFIC  button, and the reports also appear on the SATNAV screen
