Facelift Mods
ARi
  • 2 months later...
  • 2 weeks later...
  • 8 months later...
  • 9 months later...
Hi guys..  I have also posted the below on the obdeleven forum.. hoping any of you can help with the below..
I have taken delivery of OBD Eleven Pro today and attempted a few tweaks to my car and also ran a scan... I have a few questions regarding some unsuccessful tweaks and the fault codes that showed up
Firstly, I couldn't find the option to enable the background lighting menu via the Apps? Can somebody show me how to do this? Is this even possible with obdeleven? Does it need to be long coded or is there somewhere else within the Apps menu that I can do this?
I also changed Mirror Light to ON so the puddle lights are meant to light up when mirrors fold/unfold but that didn't seem to work?
I also changed the lock acoustic sound to ON when locking and Unlocking the vehicle but again it didn't work? And after successfully applying the change via the Apps I have looked through the car menus but couldn't seem to find it anywhere to enable?
On the 7.5s - from research i know that in Individual mode if the Soundaktor (Engine Sound) is set to Eco - you do not get pops and burbles on Overrun. I changed the Soundaktor to 0% from Apps, since making this change I seem to be getting less pops and burbles in Individual mode even though the Engine Sound is set to Race? I don't know if this is just in my head but it seems less pronounced than before i switched the Soundaktor off? Can somebody explain this? Does the Soundaktor need to be ON in order to get pops and burbles?
All the above changes were made through Apps instead of long coding if that makes any difference?
When running a Scan i also got the following codes:
Adaptive Cruise Control - Database error value received - U112300 - Intermittent
Wheel Dampening - Right front level control sensor - C103515 - Static
Dashboard - Database error value received - U112300 - Intermittent
Driver assistance - Camera Malfunction - C110400 - Intermittent
LED Module Left - Supply for low beam - C11FD13 - Intermittent
LED Module Right - Supply for low beam - C11FD13 - Intermittent
Can anybody help with the above fault codes? Car is under VW Extended Warranty so is it worth booking in for them to get it looked at?
Car is a 2017 Golf R 7.5 in the UK
Many thanks for any help in advance
Sorry to dampen your parade my friend, but get VW to sort your car out, back to standard.  Even if you pay for diagnosis.
Then I suggest you read and learn about OBD11 mods and how to do them before going full on meddling. If you don’t know what you’re doing, how will you know how to correct it?
Your car. Your choices.  But you seem out of your depth. 🙏
That’s a lot of codes that could be related.
Has the car been repaired recently ?
Hi mate, just seen this.
I don't think I can do any damage to the car by going through obd11 apps? If I don't like anything I can just revert back to how it was :)
All the fault codes haven't returned since I cleared them apart from the one I mentioned above
Appreciate the reply though
I know the potential damage I’d be able to do with an OBD11 and cringe.
sorry for the Curt response. Hope it sorts for you quickly & easily. 👍
Fully agree with the replies above. Don't mess until you have a clue. Using the apps is OK for the clueless until something doesn't work, then because you don't know exactly what the app did you don't have a way back. There is no 'revert' option. The Pro version with long coding may look a bit daunting but there's plenty of experienced guidance available, and you can almost always undo what you did. Even if you didn't do the obvious and write everything down, there is a History option that will usually help you out of the s**t, but you still need to understand the what  and the why.
As far as the ridiculous SoundAktor is concerned it's only for the "pleasure" of the driver. Any pops and burbles are the internally generated fake sound and have no effect outside the car.
