SIMK7.5 Posted October 4, 2017 Report Share Posted October 4, 2017 21 minutes ago, Privatedoc said: I what is driving school mode????? Pinched from internet: Quote Link to comment Share on other sites More sharing options...
podpod Posted October 4, 2017 Report Share Posted October 4, 2017 quick question does video work on the non pro headunit? Quote Link to comment Share on other sites More sharing options...
SIMK7.5 Posted October 4, 2017 Report Share Posted October 4, 2017 6 minutes ago, podpod said: quick question does video work on the non pro headunit? Nope, not that I know of. podpod 1 Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted October 4, 2017 Report Share Posted October 4, 2017 Got mine last week (turned up way quicker than I expected) and have already performed the following: Auto Coming Home Lights Comfort Blinks to 4 Off Road Display added Driving School Mode added Fan Level in AUTO Flashing Hazard when hard braking (used App 10 credits for this) Couple of them are a bit gimmicky but so easy to do its worth 5mins of your time Planning on doing: Rear Indicators come on when boot open (will probably use APP) Soundaktor Adjustment - will try 65% and go from there I think Anybody else found something cool for the MK7.5?What’s off road display and is it pro nav / standard nav / digital dash ?Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
8YARWY Posted October 4, 2017 Report Share Posted October 4, 2017 What’s off road display and is it pro nav / standard nav / digital dash ?Sent from my iPhone using Tapatalk ProThis Rob Rob2k68 and SIMK7.5 1 1 Quote Link to comment Share on other sites More sharing options...
SIMK7.5 Posted October 4, 2017 Report Share Posted October 4, 2017 You can also swipe the gauges to get water/oil temp gauges and re-arrange them etc just like you can on the standard Perfomance Monitor. Mark 46, 8YARWY and Rob2k68 3 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted October 4, 2017 Report Share Posted October 4, 2017 DRL's as coming home / leaving home lights is another good one......... As is activating rear clusters as DRL's too. Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted October 4, 2017 Report Share Posted October 4, 2017 10 minutes ago, veneeringman said: This Rob Ah cool - thanks ! Didn't expect to see that guess it exists for the Tiguan ? Going to have to find a list of 7.5 codings ;o) 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted October 4, 2017 Report Share Posted October 4, 2017 Ah cool - thanks ! Didn't expect to see that guess it exists for the Tiguan ? Going to have to find a list of 7.5 codings ;o)If you get stuck you have my email Rob Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
ARi Posted October 4, 2017 Author Report Share Posted October 4, 2017 4 hours ago, podpod said: quick question does video work on the non pro headunit? Yes but it's a little tricky at the moment I have mirror linked my Samsung and was able to have Netflix on my unit (non pro) I will upload video shortly but am searching for a better way to view videos like the old pre fl via iPod and red collar cable Dr.R 1 Quote Link to comment Share on other sites More sharing options...
Managh Posted November 1, 2017 Report Share Posted November 1, 2017 Just to clear something up for me, the auto coming home lights...is that so when you park up and remove the key lights automatically come on? Rather than having to pull the stalk? Also, is it possible to use the dynamic indicators on a mk7.5 estate? Quote Link to comment Share on other sites More sharing options...
jebjeb Posted November 1, 2017 Report Share Posted November 1, 2017 Anyone know how to turn off the alert sound for low outside temperature? Had it bing bong on me about 4 times on a 5 mile drive the other day as the temp fluctuated. I have my ODBeleven set arriving soon. Millsn 1 Quote Link to comment Share on other sites More sharing options...
SIMK7.5 Posted November 1, 2017 Report Share Posted November 1, 2017 1 hour ago, Managh said: Just to clear something up for me, the auto coming home lights...is that so when you park up and remove the key lights automatically come on? Rather than having to pull the stalk? Yep 👍 Managh 1 Quote Link to comment Share on other sites More sharing options...
dv52 Posted November 10, 2017 Report Share Posted November 10, 2017 On 11/2/2017 at 04:08, jebjeb said: Anyone know how to turn off the alert sound for low outside temperature? Had it bing bong on me about 4 times on a 5 mile drive the other day as the temp fluctuated. I have my ODBeleven set arriving soon. I have both good and a bad news regarding your question: The good news answer is, yes. If you select the Dashboard module @ address hex17 and then select adaptation and then search for "outside_temperature" , you should see the following channels p_ice_warning_entry_temperature, which has a default value of 4 °C (i.e.39 °F) p_ice_warning_exit_temperature,which has a default value of 6 °C (i.e. 43 °F) Not sure if you are familiar with the term 'hysteresis" (it's a method of dynamic-lag that is sometimes used in control systems), but this is how these two channels operate. The entry channel value is the threshold temperature at which the black-ice alarm will be set and the exit channel is the threshold temp. at which the alarm will clear (i.e. at the warmer temperature). If only one threshold temperature is used, the alarm would "hunt" (i.e. continuously turn ON/OFF) as the car traveled through different temperature zones. But with hysteresis control, the black-ice alarm remains more constant with changing ambient temperature. So, if you are going to change the value in one of these channels, I suggest that you also change the other channel value so that there is ALWAYS 2°C difference -this maintains the size of the hysteresis differential. OK, so now for the bad news answer! To change the value in the 2 x adaptation channels above, you will need a security access code. This code was 20103 in early versions of the dashboard module, but I'm not aware that the code has been found for newer modules. Happy to be proven wrong Don Quote Link to comment Share on other sites More sharing options...
BobbyT Posted November 10, 2017 Report Share Posted November 10, 2017 Is there a brake light mod for the facelift estate? Quote Link to comment Share on other sites More sharing options...
