Booth11 Posted September 25, 2020 Report Share Posted September 25, 2020 22 minutes ago, Chris7.5R said: Fully agree with the replies above. Don't mess until you have a clue. Using the apps is OK for the clueless until something doesn't work, then because you don't know exactly what the app did you don't have a way back. There is no 'revert' option. The Pro version with long coding may look a bit daunting but there's plenty of experienced guidance available, and you can almost always undo what you did. Even if you didn't do the obvious and write everything down, there is a History option that will usually help you out of the s**t, but you still need to understand the what and the why. This. Whilst the apps are easy, you don’t know what’s actually been changed in the coding. Long coding is far better as you can retrace steps should you need to and it is recorded in the history. Coding with OBDeleven Pro is not difficult but if you do something wrong or inquisitiveness takes you off down some rabbit hole and you’re not really aware of what you’re doing, then it can get you (or rather the car) into some difficulty. There are one or two threads in this section where people ‘tinkered’ without having researched beforehand and in their own words “messed up my car!”. In fact one person posted up their OBDeleven nightmare as a warning to others. Do some reading up and research into the tweaks you want to do before letting loose - make a list of the coding (plenty of it in this section and on the OBDeleven Pro forum https://obdeleven.proboards.com. Forewarned is forearmed. Quote Link to comment Share on other sites More sharing options...
trancem Posted September 26, 2020 Report Share Posted September 26, 2020 S'all good guys. Thanks for the warnings and help. I will have a look into the long coding business, I have the majority of the tweaks already done via the app. Just trying to get the ambient lighting and the chirp on lock done, but I have found a couple of how to videos for them 👍🏻 Quote Link to comment Share on other sites More sharing options...
trancem Posted September 26, 2020 Report Share Posted September 26, 2020 Happy to report, have carried out the following mods via long coding: Chirp on lock/unlock DRL option in menu Animated display on dash 10 colour ambient lighting All done without hiccup and cars not broken 🤣 ... yet Booth11 and NRW 2 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 26, 2020 Report Share Posted September 26, 2020 2 minutes ago, trancem said: Happy to report, have carried out the following mods via long coding: Chirp on lock/unlock DRL option in menu Animated display on dash 10 colour ambient lighting All done without hiccup and cars not broken 🤣 ... yet Phew! 😂 No stopping you now.....😁 Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted September 26, 2020 Report Share Posted September 26, 2020 One warning that could save you immense grief, NEVER select any item in OBDeleven (or in VCDS for that matter) that offers to reset adaptions or to reset to factory setup. You may find yourself with a car that will sit and sulk until it goes back to the dealer for a full and expensive reprogramming. I'm not including the need to reset the MIB by pressing the ON button, e.g. to implement changing the number of indicator flashes, or some of the reset options in the car settings menus; these are harmless. In the BMW coding world the VCDS equivalent software has an innocent-sounding reset button that returns everything to the newly-assembled state off the production line before each controller has been specifically programmed. Not a pretty sight. Booth11 1 Quote Link to comment Share on other sites More sharing options...
NRW Posted September 26, 2020 Report Share Posted September 26, 2020 9 hours ago, trancem said: Animated display on dash 10 colour ambient lighting Tempting.....but then again, think I’ll not😂 Quote Link to comment Share on other sites More sharing options...
trancem Posted September 26, 2020 Report Share Posted September 26, 2020 8 minutes ago, NRW said: Tempting.....but then again, think I’ll not😂 Why not? Quote Link to comment Share on other sites More sharing options...
NRW Posted September 26, 2020 Report Share Posted September 26, 2020 1 minute ago, trancem said: Why not? Not sure enough of my skills (such as they are) to fiddle with my car. The discoverable features and variations don’t, for me, outweigh the risks. Doesn’t mean I can’t like what people do. 👍 Quote Link to comment Share on other sites More sharing options...
trancem Posted September 26, 2020 Report Share Posted September 26, 2020 I followed a vid on YouTube step by step guide, pausing every few seconds to ensure I keyed everything in correctly 😅 SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 27, 2020 Report Share Posted September 27, 2020 I followed a vid on YouTube step by step guide, pausing every few seconds to ensure I keyed everything in correctly You should try running a self tune on the ECU and watching every single error code possible pop up on the dash Am I a toaster? Am I a washing machine, oh hang on I'm a gearbox Sent from my VOG-L09 using Tapatalk NRW 1 Quote Link to comment Share on other sites More sharing options...
NRW Posted September 27, 2020 Report Share Posted September 27, 2020 1 hour ago, SpursMadDave said: You should try running a self tune on the ECU and watching every single error code possible pop up on the dash Am I a toaster? Am I a washing machine, oh hang on I'm a gearbox Sent from my VOG-L09 using Tapatalk Exactly my fears Dave. I’d end up with clean 7 speed toasted socks. Quote Link to comment Share on other sites More sharing options...
trancem Posted September 27, 2020 Report Share Posted September 27, 2020 1 hour ago, SpursMadDave said: You should try running a self tune on the ECU and watching every single error code possible pop up on the dash Am I a toaster? Am I a washing machine, oh hang on I'm a gearbox Sent from my VOG-L09 using Tapatalk Haha I can imagine, I would **** my pants. This is as far as I'm willing to go interms of the electronics tinkering 😁 SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 27, 2020 Report Share Posted September 27, 2020 Haha I can imagine, I would **** my pants. This is as far as I'm willing to go interms of the electronics tinkering I've reset my Haldex which went fine and done a lot of tweaks especially on my CP removed mib2, just need to be careful with certain things reallySent from my VOG-L09 using Tapatalk Quote Link to comment Share on other sites More sharing options...
crowers Posted October 5, 2020 Report Share Posted October 5, 2020 Has anyone managed to activate the 30 colour pallet on their 7.5. My Obdeleven app just says function unavailable but lets me code the tube and the red/blue/gold dash colours etc I've tried MIB on and off but it just won't let me Thanks in advance Quote Link to comment Share on other sites More sharing options...
Clarkie48 Posted February 14, 2021 Report Share Posted February 14, 2021 Is this the right code for changing the dash styles? Dashboard Adaptation Scroll to the bottom to tube_version 0 default 1-5 different clocks 6-F looked the same as default Quote Link to comment Share on other sites More sharing options...
