ARi Posted August 12, 2017 Report Share Posted August 12, 2017 VW Golf MK 7.5 Facelift Auto Coming Home Lights09 Central ElectronicsAdaptationSelect – Aussenlicht_Uebergreifend Coming Home Verbaustatus - From manual to automaticComfort Blinker Cycles09 - Central Electronics AdaptationSelect – Aussenlicht_BlinkerKomfortblinken Blinkzyklen – From 3 to Your chosen valueNote that the acceptable range is 1 to 5 and the default value is 3*Reset MIB Lighting Setting to Complete Off Road Display 5F - Information Electronics AdaptationSelect - Car_Function_Adaptations_Gen2menu_display_compass - set to active (default not active)menu_display_compass_over_threshold_high - set to active (default not active)Select - Car_Function_List_BAP_Gen2compass_0x15 - set to active (default not active)Reset the MIB unit - Press and hold the ON/OFF button on the infotainment unit for greater than 10 seconds.Driving School Mode in MIB5F- Information Electronics. AdaptationSelect – Car_Function_Adaptations_Gen2menu_ display_ driving_ school - Activatemenu _display _driving _school _over _threshold _high – ActivateDRL Option in MIB[09] Central ElectronicsAdaptationSelect – Aussenlicht_FrontTagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich - ActivateLock/Unlock Sound[09] Central ElectronicsSelect - ACKNOWLEDGEMENT SIGNALS Select ACTIVE for Akustische Rueckmeldung entriegen if you want acoustic feedback for unlockSelect YES for Akustische Rueckmeldung verriegeln if you want acoustic feedback for lockSelect ACTIVE for Menuesteuerung akustische Rueckmeldung (Acoustic lock menu)In-car procedure:Press the CAR button on the RHS of the infotainment screenSelect SETUP on the bottom RHS of the screen (looks like a cog)Select Opening & closing panelPlace a tick in Acoustic confirmation box. The facility can be turned ON/OFF via this switch Fan Level in AUTO 08 Air condition A/C Coding Select - Blower Display In Auto Operation – Set to Active Scandinavian DRL 09 - Central Electrics AdaptationsSelect – Aussenlicht_Front- Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht – Set to Active I will continue to check and add Wagon R, Naz7r, sss555 and 9 others 8 1 3 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted August 12, 2017 Report Share Posted August 12, 2017 @ARi I've stickied this. Good thread. 👍 Rob2k68 and 8YARWY 2 Quote Link to comment Share on other sites More sharing options...
PraggersK Posted August 12, 2017 Report Share Posted August 12, 2017 Well done you! Glad someone has done this for the 7.5! I will add anything I find with mine here. 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted August 14, 2017 Report Share Posted August 14, 2017 Agree good thread To reset the MMI after the comfort blinken change you need to go into Car settings, scroll down to factory reset, in factory reset select Lighting and then the Adaptation change will take effect. Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
Privatedoc Posted August 14, 2017 Report Share Posted August 14, 2017 great thread.....does the led on auto fan setting work yet? Quote Link to comment Share on other sites More sharing options...
8YARWY Posted August 14, 2017 Report Share Posted August 14, 2017 Rob2k68 and Mark 46 2 Quote Link to comment Share on other sites More sharing options...
ARi Posted August 14, 2017 Author Report Share Posted August 14, 2017 5 hours ago, Privatedoc said: great thread.....does the led on auto fan setting work yet? updated with requested mod Privatedoc 1 Quote Link to comment Share on other sites More sharing options...
PraggersK Posted August 15, 2017 Report Share Posted August 15, 2017 Any idea how to get the blue interior lights to stay on? Quote Link to comment Share on other sites More sharing options...
ARi Posted August 16, 2017 Author Report Share Posted August 16, 2017 13 hours ago, PraggersK said: Any idea how to get the blue interior lights to stay on? Do you mean the door strips? Privatedoc 1 Quote Link to comment Share on other sites More sharing options...
Shug Posted August 16, 2017 Report Share Posted August 16, 2017 17 hours ago, PraggersK said: Any idea how to get the blue interior lights to stay on? Thought they were on if lights on. Brightness changed through central screen - car settings sub menu - lights? Quote Link to comment Share on other sites More sharing options...
PraggersK Posted August 16, 2017 Report Share Posted August 16, 2017 Yes on the door strips. They come on at full brightness in the dark but are off during the day. I wondered if they could just be on full time? Quote Link to comment Share on other sites More sharing options...
ARi Posted August 16, 2017 Author Report Share Posted August 16, 2017 5 hours ago, PraggersK said: Yes on the door strips. They come on at full brightness in the dark but are off during the day. I wondered if they could just be on full time? I will look into this for you but I'm pretty sure you wouldn't see the blue strip in the day Try put your beams on during the day and see if you can see the strip Quote Link to comment Share on other sites More sharing options...
JonnyG Posted August 16, 2017 Report Share Posted August 16, 2017 Thanks for the input. Is there a rear brake light mod for the facelift ... similar to the Mk 7 ... so that the inner lights show the brake light as well ? Quote Link to comment Share on other sites More sharing options...
Privatedoc Posted August 18, 2017 Report Share Posted August 18, 2017 On 14/08/2017 at 13:53, veneeringman said: OK...how???? possible with OBDeleven???? Mark 46 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted August 18, 2017 Report Share Posted August 18, 2017 Thanks for the input. Is there a rear brake light mod for the facelift ... similar to the Mk 7 ... so that the inner lights show the brake light as well ?The Five brake light mod that works on the 7 also works on the Facelift. However.... If the rears are used as DRLs the 2 won’t work together I’ve got the rears as DRLs and the brake lights are the 6 squares on the outside. JonnyG and Rob2k68 1 1 Quote Link to comment Share on other sites More sharing options...
