Rozkipz Posted December 17, 2017 Report Share Posted December 17, 2017 (edited) On 12/15/2017 at 23:38, dv52 said: Rozkipz: So - in your part of the world, what happens when you press the TRAFFIC button on the MIB escutcheon plate? Down here in the Antipodes, we have traffic reports that are sent over a sub-harmonic frequency of our FM radio. We can enable this facility by entering a code into the TMC adaptation channel on the MIB module. If we have RDS (Radio Data Service) enabled, this gives us a list of traffic reports in real time which appears as a list when we press the TRAFFIC button, and the reports also appear on the SATNAV screen Don The facelift model doesn't have a traffic button on the MIB, but it does seem to use RDS (at least here in the UK) but that only (seems to) report major crashes on major roads, and not things like roadworks or queue build ups on smaller ones, like google maps does. Edited December 17, 2017 by Rozkipz Quote Link to comment Share on other sites More sharing options...
dv52 Posted December 17, 2017 Report Share Posted December 17, 2017 4 hours ago, Rozkipz said: The facelift model doesn't have a traffic button on the MIB, but it does seem to use RDS (at least here in the UK) but that only (seems to) report major crashes on major roads, and not things like roadworks or queue build ups on smaller ones, like google maps does. Rozkipz: OK - you could go to the Information Elect. module @ address hex5F and try setting the adaptation channel Fee Based Traffic Information (TMC) to 32771 , which is the code for online traffic + VW TMCPro in UK (I think). You shouldn't need an access code for this tweak. Then, reset the MIB - with the radio switched-on, hold down the OFF/ON button until the MIB turns-OFF and then turns-ON again . Don Quote Link to comment Share on other sites More sharing options...
JB-R Posted December 30, 2017 Report Share Posted December 30, 2017 On 22/09/2017 at 10:12, JB-R said: So are the instructions for the Mk7.5 the same as the instructions for the Mk7 for the inner rear brake lights? i don't / won't be having the rears as drl's Bumped this as I pick up my 7.5 next week. Has anyone carried out this brake light mod on a 7.5 to get all outer and inner lights working as brake lights and if so are the instructions the same as the Mk7 ?? Thanks 👍 Quote Link to comment Share on other sites More sharing options...
goRt Posted December 30, 2017 Report Share Posted December 30, 2017 Bumped this as I pick up my 7.5 next week. Has anyone carried out this brake light mod on a 7.5 to get all outer and inner lights working as brake lights and if so are the instructions the same as the Mk7 ?? Thanks YesSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
JB-R Posted December 30, 2017 Report Share Posted December 30, 2017 1 hour ago, goRt said: Yes Sent from my SM-G950F using Tapatalk Thanks will give it a go then 👍 Quote Link to comment Share on other sites More sharing options...
JB-R Posted January 6, 2018 Report Share Posted January 6, 2018 Tried to do the brake lights on my Mk7.5 using the Mk 7 instructions but it doesn’t work. I have reset the light functions in the MIB2 settings too but absolutely no change whatsoever ☹️ Any ideas ??? Quote Link to comment Share on other sites More sharing options...
goRt Posted January 6, 2018 Report Share Posted January 6, 2018 Tried to do the brake lights on my Mk7.5 using the Mk 7 instructions but it doesn’t work. I have reset the light functions in the MIB2 settings too but absolutely no change whatsoever ️ Any ideas ???No issue for me using VCDSSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
discolegend73 Posted February 7, 2018 Report Share Posted February 7, 2018 The Five brake light mod that works on the 7 also works on the Facelift. However.... If the rears are used as DRLs the 2 won’t work together I’ve got the rears as DRLs and the brake lights are the 6 squares on the outside. Are the rear lights set as drls as default or do you need to set it up ?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
SIMK7.5 Posted February 7, 2018 Report Share Posted February 7, 2018 53 minutes ago, discolegend73 said: Are the rear lights set as drls as default or do you need to set it up ? Sent from my iPhone using Tapatalk No, you have to enable them as DRL's using obd11 (or vcds) Quote Link to comment Share on other sites More sharing options...
discolegend73 Posted February 7, 2018 Report Share Posted February 7, 2018 No, you have to enable them as DRL's using obd11 (or vcds) Do you know the coding for that I have obd11??Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
SIMK7.5 Posted February 7, 2018 Report Share Posted February 7, 2018 11 minutes ago, discolegend73 said: Do you know the coding for that I have obd11?? Sent from my iPhone using Tapatalk See Page 1 of this very thread............ (or use 10 credits and use the App function on OBD11) Quote Link to comment Share on other sites More sharing options...
discolegend73 Posted February 7, 2018 Report Share Posted February 7, 2018 See Page 1 of this very thread............ (or use 10 credits and use the App function on OBD11)Oh so the drl option in mib?Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
SIMK7.5 Posted February 7, 2018 Report Share Posted February 7, 2018 3 minutes ago, discolegend73 said: Oh so the drl option in mib? Sent from my iPad using Tapatalk errrrm.......nope! This: Scandinavian DRL 09 - Central Electrics AdaptationsSelect – Aussenlicht_Front- Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht – Set to Active EcosseGolfR and discolegend73 2 Quote Link to comment Share on other sites More sharing options...
discolegend73 Posted February 7, 2018 Report Share Posted February 7, 2018 errrrm.......nope! This: Scandinavian DRL 09 - Central Electrics AdaptationsSelect – Aussenlicht_Front- Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht – Set to ActiveThank youSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Kris_L Posted April 8, 2018 Report Share Posted April 8, 2018 Some great info here . Had a good read so most of my queries have been answered. Can I still do things like rear DRL and VIM using credits if I do not have the ODB eleven Pro version? Cheers Quote Link to comment Share on other sites More sharing options...
