gregozedobe Posted August 24, 2018 Report Share Posted August 24, 2018 16 minutes ago, Mainframe said: Illegal tyres are a deffo no no. But even legal tyres at edge of tread depth indicators, can have markedly reduced ability to displace standing water. I agree, which is why I always replace my tyres well before they get to the legal limit. You were the one who mentioned bald tyres in the first place. It is worth noting that the front tyres do the majority of displacing water, the rear wheels follow the same path so usually encounter much less surface water (unless the car is travelling sideways or is negotiating a very tight turn). I find it is prudent to reduce speed whenever there is significant standing water on the road (admittedly this happens much less often in Oz than in the UK, and particularly as we have had a serious drought here since October 2017). Quote Link to comment Share on other sites More sharing options...
Mainframe Posted August 25, 2018 Report Share Posted August 25, 2018 6 hours ago, gregozedobe said: I agree, which is why I always replace my tyres well before they get to the legal limit. You were the one who mentioned bald tyres in the first place. I also mentioned "Ayrtons". 'Twas a figure of speech for illustrative purposes. 6 hours ago, gregozedobe said: It is worth noting that the front tyres do the majority of displacing water, the rear wheels follow the same path so usually encounter much less surface water (unless the car is travelling sideways or is negotiating a very tight turn). My example was a high speed turn standing water, when the rears can't follow dry line created by fronts. I.e. It back fills instantly, so tread displacement of rears assumes greater role in stability. 6 hours ago, gregozedobe said: I find it is prudent to reduce speed whenever there is significant standing water on the road (admittedly this happens much less often in Oz than in the UK, and particularly as we have had a serious drought here since October 2017). Goes without saying. But if you misjudged it, it would be one of those times when some additional rear tread would be welcomed in stabilising things Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted August 25, 2018 Report Share Posted August 25, 2018 Personally I change all 4 tyres together every time - having roatated them over their life. Saves these discussions - plus also the heinous crime of mixing brandsF/R on the car. Aquaplaning in a high speed turn is the one scenario I can envisage where some front end slip is far easier to recover from from, than is the rapid oversteer, followed by over corrected tank slapper from bald rears (for the non- Ayrtons out there). I count myself in that group btw. Yeah always good to change all 4 together, unfortunately previous owner of mine didn't... have to get back in that habit as last 2 cars have had staggered wheels ans RWD so didn't have that choice!Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted August 25, 2018 Report Share Posted August 25, 2018 3 hours ago, Mainframe said: My example was a high speed turn standing water, when the rears can't follow dry line created by fronts. I.e. It back fills instantly, so tread displacement of rears assumes greater role in stability. ....... But if you misjudged it, it would be one of those times when some additional rear tread would be welcomed in stabilising things I'll reply for the purposes of discussion (which has remained civil, thank you 👍 I suspect that if someone is going to drive at high speed into standing water then their rear wheels WILL be following in the path of the fronts. Have a good look at the "cleared" patterns left on a wet road next time you are driving in the rain, you never see 4 separate tracks when driving at any speed on a highway unless you are doing some serious drifting. However, if the speed is high and the turn is so sharp they aren't following the path cleared by the fronts, then tread depth at either end isn't really going to matter and it is a question of turn radius, and road angle/camber as to where the car will end up (usually exiting the road to the outside of the bend). Neither the tyres nor the driver will have much influence on the result at that point, and I hope the sides of the road are clear of any substantial trees or other hard objects, and there is no-one coming from the other way (particularly if it is a left hand bend). It may be possible to apply the brakes hard and push the front tyres through the standing water if conditions are on the margin of grip (ie only just starting to aquaplane), but not with a high probability of success. At that point you would be relying very heavily on your ABS & ESC to help you maintain (some) control. Quote Link to comment Share on other sites More sharing options...
baz657 Posted August 28, 2018 Report Share Posted August 28, 2018 I put a set of (235/35R19) Michelin PS4S's on my previous car - Focus ST Mk 3.5 with a few Mountune mods. Just changing from the factory fitted PS3's the difference was immediate - especially after I ruined the PS3's on a wet morning and dry afternoon track day at Donington - they'd already done a couple of track days and a couple of Eurotrips so it wasn't a complete disaster. As I've got the 19's again it'll have to be the PS4S again, anything to get rid of the noisy Conti's on the back (I'm really hoping it's all tyre noise) and the cheap Avon's put on the front by the owner before me. I'm in the motor (and tyre) trade so I'm now waiting for a tyre rep to come in and agree to a deal on a set of PS4S's which I'll find difficult to refuse. It'll be interesting to compare the over/understeer between FWD and active AWD. Quote Link to comment Share on other sites More sharing options...
camelsac2002 Posted August 28, 2018 Report Share Posted August 28, 2018 Change All four for wear. Chance to switch brands as per OP. Change in pairs for punctures- but stay in brand. ...would be logical deduction. I’ve had Contis on rear and Michelins on front when I changed to the Michelins - car drove fine although I was a little more wary when cornering - just as for weather, change your driving to suit the situation. No way that I was going to waste plenty of good miles that were left on the 5Ps.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted August 28, 2018 Report Share Posted August 28, 2018 Out of interest do fronts or rears wear harder on the R, just wondered if anyone who is swapping them around has noticed?Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted August 28, 2018 Report Share Posted August 28, 2018 I’ve had Contis on rear and Michelins on front when I changed to the Michelins - car drove fine although I was a little more wary when cornering - just as for weather, change your driving to suit the situation. No way that I was going to waste plenty of good miles that were left on the 5Ps.Sent from my iPad using TapatalkExactly what I have got on mine at the moment tooSent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Gavras Posted August 28, 2018 Report Share Posted August 28, 2018 I have Pzeros on mine. i have been pleasantly suprised over last 12 months of very diverse weather on just how well they have performed. they handled the deep snow and temperatures down to -11c without missing a beat. they were great in heavy rain with lots of confidence. the recent scorchio weather was nothing for them and did not miss a beat. they have been up to the North of Scotland and some very tasty roads. a few trips are Wales and Pennines left them just wanting more. on tyre changing, I always change well in advance of legal limit, you can feel the tyres are getting close to limit from braking and handling especially in wet weather. i do try to avoid mixing tyres on a car as each type has its own tolerances and cohabiting can be an issue or they make you very aware of it goodbadboy and SpursMadDave 2 Quote Link to comment Share on other sites More sharing options...
goodbadboy Posted August 29, 2018 Author Report Share Posted August 29, 2018 9 hours ago, Gavras said: I have Pzeros on mine. i have been pleasantly suprised over last 12 months of very diverse weather on just how well they have performed. they handled the deep snow and temperatures down to -11c without missing a beat. they were great in heavy rain with lots of confidence. the recent scorchio weather was nothing for them and did not miss a beat. they have been up to the North of Scotland and some very tasty roads. a few trips are Wales and Pennines left them just wanting more. on tyre changing, I always change well in advance of legal limit, you can feel the tyres are getting close to limit from braking and handling especially in wet weather. i do try to avoid mixing tyres on a car as each type has its own tolerances and cohabiting can be an issue or they make you very aware of it Well said Gav...I have a very similar experience on my P Zero's also...Great tire...No issues Gavras 1 Quote Link to comment Share on other sites More sharing options...
Daviecee Posted August 29, 2018 Report Share Posted August 29, 2018 17 hours ago, SpursMadDave said: Out of interest do fronts or rears wear harder on the R, just wondered if anyone who is swapping them around has noticed? Sent from my SM-G935F using Tapatalk I have my wheels rotated/swapped round every service for even wear. A more expensive hit for a complete set, but longer intervals in between. gregozedobe and Trentside 2 Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted August 30, 2018 Report Share Posted August 30, 2018 15 hours ago, Daviecee said: I have my wheels rotated/swapped round every service for even wear. A more expensive hit for a complete set, but longer intervals in between. An excellent approach 👍 goodbadboy 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted August 30, 2018 Report Share Posted August 30, 2018 I have my wheels rotated/swapped round every service for even wear. A more expensive hit for a complete set, but longer intervals in between.Yes definitely the way to go but just wondered if F or R wear quicker?Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Bob Posted August 30, 2018 Report Share Posted August 30, 2018 59 minutes ago, SpursMadDave said: Yes definitely the way to go but just wondered if F or R wear quicker? Sent from my SM-G935F using Tapatalk My ps4s tyres are wearing evenly so haven't bothered rotating. Probably my heavy foot and not much motorway driving! Quote Link to comment Share on other sites More sharing options...
Charles M Posted August 30, 2018 Report Share Posted August 30, 2018 Going to see if dealer has a set of PS4 as will change tomorrow. Took a dual carriageway corner at a decent speed and just felt that the Bridgestones were driving around the corner well enough. And anyway, the front axle is mixed with B'stone's plus one is new and the other near worn. Quote Link to comment Share on other sites More sharing options...
