gregozedobe Posted August 28, 2018 Report Share Posted August 28, 2018 1 hour ago, goodbadboy said: I tend to do both....(sometimes)......................... Yep, gotta take your fun where you can 👍 If you wait until everything is perfect you restrict your opportunities unnecessarily and miss out. goodbadboy and Booth11 2 Quote Link to comment Share on other sites More sharing options...
goodbadboy Posted August 29, 2018 Report Share Posted August 29, 2018 22 hours ago, gregozedobe said: Yep, gotta take your fun where you can 👍 If you wait until everything is perfect you restrict your opportunities unnecessarily and miss out. Agreed gregozedobe 1 Quote Link to comment Share on other sites More sharing options...
Baldchap Posted August 30, 2018 Report Share Posted August 30, 2018 I disabled my soundaktor via OBDEleven in my old GTI PP and my current R. Sounds far better without it. Turned the pesky Stop/Start off at the same time! 😂 ItsJustaR and Nile 2 Quote Link to comment Share on other sites More sharing options...
ItsJustaR Posted August 30, 2018 Report Share Posted August 30, 2018 I disabled my soundaktor via OBDEleven in my old GTI PP and my current R. Sounds far better without it. Turned the pesky Stop/Start off at the same time! Yeah waste of time for a performance vehicle lolSent from my SM-G955U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Natasha Posted October 22, 2018 Report Share Posted October 22, 2018 On 24/08/2018 at 16:42, Natasha said: Question - may be a silly one and I can't be faffed to read the Owners Manual Is there a method to change to driving modes from the steering wheel consul (rather than the button by gearstick) mine is a DSG this is really helpful thanks guys! Quote Link to comment Share on other sites More sharing options...
Nile Posted October 22, 2018 Report Share Posted October 22, 2018 On 30/08/2018 at 14:27, Baldchap said: I disabled my soundaktor via OBDEleven in my old GTI PP and my current R. Sounds far better without it. Turned the pesky Stop/Start off at the same time! 😂 Ditto 👍 Quote Link to comment Share on other sites More sharing options...
B1GMAC Posted October 22, 2018 Report Share Posted October 22, 2018 How do you display engine oil temp? Quote Link to comment Share on other sites More sharing options...
RWJ Posted October 22, 2018 Report Share Posted October 22, 2018 It's under driving data on the dashboard display on my Mk7. Next to mpg etc. Get to it through the button on the right hand side of the steering wheel. Quote Link to comment Share on other sites More sharing options...
B1GMAC Posted October 22, 2018 Report Share Posted October 22, 2018 Ok thanks, I've got a mk7 so I'll have to try it Quote Link to comment Share on other sites More sharing options...
Renegade1975 Posted October 23, 2018 Report Share Posted October 23, 2018 15 hours ago, B1GMAC said: Ok thanks, I've got a mk7 so I'll have to try it You might have to turn it on via the infotainment set up and then press the up arrow on the steering wheel when it is showing speed and it should be there. 106 the max temp I've recorded so far lol!! Quote Link to comment Share on other sites More sharing options...
R-Estate Posted October 23, 2018 Report Share Posted October 23, 2018 You might have to turn it on via the infotainment set up and then press the up arrow on the steering wheel when it is showing speed and it should be there. 106 the max temp I've recorded so far lol!!You can also get it on the mib unit if you code in the off-road menu via VCDS or OBD11. Quote Link to comment Share on other sites More sharing options...
MassMassa Posted October 23, 2018 Report Share Posted October 23, 2018 On 27/08/2018 at 08:37, gregozedobe said: ....I think I might put a couple of very small blobs of hot melt glue on the Drive Mode button to make it easier to locate by touch. This will make switching between Normal, Individual and Race much easier. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F273280811176 Stick one of these on the mode button for easy location of the switch gregozedobe 1 Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted October 23, 2018 Report Share Posted October 23, 2018 26 minutes ago, MassMassa said: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F273280811176 Stick one of these on the mode button for easy location of the switch Thanks for the hint. Postage to Oz from the UK on the above was way too expensive, but I found these which I have ordered: https://www.ebay.com/itm/232484474762 MassMassa 1 Quote Link to comment Share on other sites More sharing options...
