Race Mode
davetherave
7 hours ago, SpursMadDave said:
Dave it doesn't change the mode from drive to race just the gearbox setting afaik, it's all a bit confusing but I just have the mode in individual with everything set to race ie steering etc except the soundaktor and then switch between gearbox setting via the gear selector then no need to keep changing modes. Only time I might change mode is if I have a long motorway run and out it in to eco maybe...
Pretty much same here, have individual setup and that pathetic teenager Soundaktor set to Eco, then just switch between, D/S and Manual S.
i do not really see the point of Race mode over Individual, possibly if it was renamed Xbox or PS4 mode, then it would be more accurate.
driver profiles are also worth setting up and using for long trips, as you can have various Comfort or eco setups with more sports feel.
also on the this thing of flooring it when up to temperature.. I tend to wait until the road I am on will give that fun factor, flooring it on a dual carriageway is bland, almost boring, unless of course it's very tight and lots of bends.
Can you do this on the mk7? I had a quick look for it in the head unit but couldn’t find it
You can on the 7.5, don't know about the 7.
its basically making use of different driver profiles that usually come with the key.
I drive in individual most of the time, but it’s a lot quicker to hit the mode switch three times and watch the screen to get to race than to hit the mode switch, use screen to get change settings, scroll down to race, select race, select close... and if driving you will most likely change the wrong setting anyway.
16 hours ago, SpursMadDave said:
Did mine via OBDEleven you turn it down as a % I've got mine at 30%
I've got mine at 60% but thinking of dropping to 35-40%. Question - is this just for race or does it also affect normal?
Oh Gavras, come come. The soundaktor goes hand in hand with the quad pipes. OK I have turned mine down and will do so a bit more, but it seems I am able to change from 100% to 225%. I'm curious about that 😛
Fortunately I have a drive leading on to small roads so no chance of flooring things for a few miles.
Absolutely, I'm not a traffic light racer, I would much rather have a blast on a nice twisty road than in a boring straight line too
Thought as much, my individual setting is the same as Race except that dreaded soundaktor, but if I switch from normal to individual the gear stays as D, if I switch from Race to Individual it will stay as S. not sure whats up but seems a bit buggy/faulty.
I like to get one fart if there is space in the road ahead, some dual carriageways can be fun for weaving in a out, but its hit and miss, depends on the traffic flow. Going off any smaller road off most of the M25 you will find some decent roads you can have fun on.
On 25/08/2018 at 01:31, PJD said:
The 7.5 already displays the driving mode in the virtual cockpit. When I press the mode button repeatedly it will scroll through the selected mode displaying it right in front of me, so hardly taking your eyes of the road.
Thanks for pointing that out to me.  👍
I have never noticed it was also displayed there because I have always been looking at the infotainment screen to see which mode I am selecting.  Having it in the virtual cockpit screen is a way better place (but a HUD would be even better ).  I think I might put a couple of very small blobs of hot melt glue on the Drive Mode button to make it easier to locate by touch. This will make switching between Normal, Individual and Race much easier.  RESULT !
Every day can be a learning day (if you let it)   I've had my R for nearly a year and am still learning things (much of it thanks to the many helpful people on this forum).   :)
Unplug the soundaktor took me literally only a few minutes to do!
Sent from my SM-G955U using Tapatalk
I tend to do both....(sometimes):lol:.........................:ph34r:
