Guy Incognito
Quick question....
I have just purchased the vwr high-flow 90 turbo inlet, vwr hose and a panel filter from regal Motorsport. I plan on running the standard air box. (Still awaiting delivery of the car). Do I HAVE to dremel out the closed panel on the standard air intake, or will it be fine as it is? I don't really want to cut it out, but I also don't want to of spent over £250 for it not to work properly. Is anybody else running this set up? Many thanks.
No it will be fine without Dremelling out the front of the intake
How do you do that?
1. Go to [09] Central Electronics
2. STG access permissions -> Function 16
3. Enter access code 31347
4. Go to adaptation channels (Function 10)
5. Select channel 1 - Select "Number of operations front windsceen wiper washer per SRA activation" (in German - Frontscheibenwischer Anzahl Betätigungen Frontwaschanlage pro SRA Aktivierung auswählen)
6. Adjust value to preference (no of times you can operate the windscreen washer stalk before the headlight washer activate).
7. Select channel 3, and adjust the activate time for folding the switch to enable headlight washers in the first place
I'm told that module 9 byte 20 controls the headlight washers, haven't tested this one myself though
Or my previous answer!
Sent from my E6653 using Tapatalk
It's risky, but I believe I can trust you so if you wanted to borrow my cable for the week whilst my R is away then I'm happy to post it to you.
Thanks for that offer Ash, much appreciated  :afro:  I'm honoured that you think I'm not going to make off with your VCDS cable - your instincts are correct, I would guard it with my life, lol.  When would your car be going in for surgery?
I have had a previous offer of borrowing someone elses VCDS cable too but am so crap at getting it together for some reason.  Maybe we can work something out.  :smiley:
