Guy Incognito
It would appear I have a slow puncture in my left hand rear tyre. Needed a top up of air (2 psi) about two weeks ago and warning reappeared this morning. If the puncture is repairable, should I get it done or should I go down the route of new rear tyres??
The car has only covered 5k from new. Never had an issue like this before so unsure of best practice.
Whereabouts is the puncture, do you know? If it's not a leaky valve and the damage is not too near the sidewall it may well be repairable. I had a screw in my rear tyre earlier this year and that was repaired and no issues with it at all after that. - cost only a few pounds to sort, opposed to £££ for a new tyre. Worth taking to a tyre place for an assessment. Try to choose a reputable tyre place as, as Ash says, some will tell you it needs replacing no matter what, but a decent place should be upfront about it if it can be repaired. I once took a tyre with a nail in it into ATS who said it needed a new tyre, then took it down the road to the place I now use, and they repaired it there and then. Saved me lot of cash.
Not related to Mk7's at all but, who's the guy that has a 7R and also got a McLaren recently??
I'm looking to work on some personal photography projects for my portfolio over winter. I wanted to speak to the owner to find out if we could organise a time to shoot some pictures.
I'm away at the moment with the car secured in a lockup. I'll check the tyre over on Sunday when I return. Don't like using the national tyre companies as they tend to pay peanuts which results in my OCD going into overdrive. I'll try a new local Independant Porsche garage, which has opened recently, hopefully they'll take care when handling the wheel.
When parking with auto-hold, is it OK to to move the selector to P and just turn-off?  Or should I manually apply the handbrake?
As above.  No need to engage the handbrake manually when parking up and switching ignition off.  If you need some visual reassurance that the handbrake is properly on when the car is in P then a quick glance at the DIS will show the red P in red circle symbol which indicates the handbrake is applied.
Being totally honest, the DSG is a very smooth box and adds a lot to the R. BUT. I've currently got a diesel Passat on loan with DSG and paired with the 2.0TDI engine it's horrible, slow, sluggish and a little gutless. A real contrast from the fast, snappy nature of the DSG in the R! Wether that's the engine difference, I don't know but I do feel the DSG box works SO much better in the R.
Not necessarily the same DSG gearbox and/or software/mapping though, in the 7R application, it is excellent though.
Answer after test drive:
Disable Front Assist.
A warning light shows up... No ACC but cruise control available.
At least I can do that if I insist. So I'll leave it.
My last VW was the first R32: no bloody anything in that - pure pleasure;-)
Interesting, I will try this later in my 65 plate car and see if that's the same, but I actually like ACC and use it a lot.
Quite funny in a DSG car when you let it bring you to a stop and set off again, takes some trusting though ha ha!
Had enough of the Passat Estate already?
Yes & No. It's not the same fun as the R but it has it's moments of being a hoot. The boot is large and will take ALL of my photography gear with ease unlike the R and having to use the load through on the arm-rest. The wife hates it and has refused to drive it so I'm being taxi at the moment!!
On each door frame there is a couple of holes on the top of each , on the front two there is a black plug or something on one of holes on each of the front doors , but on the back doors both holes are uncovered ... is this normal ?
Actually on closer inspection the fronts have 3 holes and the middle one is covered .. ill load pics if needed
Quick question:
You can use cruise control without ACC right? I.e. Keep speed, disregard traffic?
The closest analogy I can think of is that this is like insisting the lights are turned off and that you double bag when you are about the nail the biggest hottie of your life.  It makes zero sense  :tease:  :tongue:
