Guy Incognito
Shower thoughts:
My car comes from the factory with the 18" Cadiz wheels. When I put on the 19" Pretoria wheels will my speedo be correct?
Probably not, but only by about 3%
19" wheel = 482.6mm diameter
235/35 tyre = 82.25mm sidewall
=564.9mm diameter
18" wheel = 457.2mm diameter
225/40 tyre = 90mm sidewall
=547.2mm diameter
564.9/547.2 = 3% difference, so hardly noticeable given the usual error on speedos.
Shower thoughts:
They don't calibrate them any differently for either wheel option, there will be a very minor change, as shown above.
In reality your speedo is already not 100% accurate anyway, so is still within acceptable tolerances.
=564.9mm diameter
=547.2mm diameter
Thanks guys.
70MPH + a difference of 3% = 72mph. I regularly drive on motorways at a speedo indicated 79 (GPS is about 76). So when I put on the 19"s will I need to be driving at less than that to make sure I'm still within tolerance? Or is 79 on the speedo - 81ish at the wheels going to be ok?
Thanks guys.
Without the rounding, 79mph on the speedo (if it was 100% accurate on 18s) would be 81.6mph on the road.
Your Maths looks wrong difference is smaller:
Wheel diam. (inches) 18 19 Wheel diam. (M) 0.457 0.483       Tyre width (mm) 225 235 Tyre aspect 40 35 Tyre (M) 0.09 0.08225       Total diam. (M) 0.6372 0.6471       Tyre Circum. (M) 2.0018 2.0329       % of R18 Cadiz 100.00% 101.55%
Dammit, I only added one sidewall to the diameter....
How do you stop them activating?
A trick I used to do on my Mk 5 (not tried it on the R yet) is pull the stalk towards you as if you're going to clean the screen, but do it as quickly as you can.  This tricks the car into thinking you're cleaning the screen but doesn't give enough time for the washers to activate.  Then do it again normally.  As the headlight washers only activate on the first and fifth wash (well, that's what it was on the Mk 5) it won't wash the headlights as it thinks it's the second wash as the first one was too brief for the washers to activate, if that makes sense.
Edited by _Golfgirl_
