Booth11 Posted October 18, 2016 Report Share Posted October 18, 2016 ??? Ash, does one have the rim protector? Phone them and ask. Get the one without as ironically they actually offer better rim protection than the ones with! Quote Link to comment Share on other sites More sharing options...
ashleyman Posted October 18, 2016 Report Share Posted October 18, 2016 Er....other than a delivery timing difference depending on order time in the day none and frankly I would of expected the second one to be more expensive as it's next day if ordered before 2.30 pm whereas the first is order before 4.00 pm and delivery in 2 working days, makes no sense but I pick option 2 It makes no sense! I've been through them side by side and there's no difference at all. My local tyre guy can't beat the price but will fit them for 20 cash money units. £136 - LINK £127 - LINK EDIT - I phoned and asked. If you own a Golf R you want the cheaper one as the £136 tyre was designed specifically for the Civic Type R. Meercat and Booth11 2 Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted October 18, 2016 Report Share Posted October 18, 2016 They must be missing additional code as you see plenty of tyres with the exact same specification and a different price but the code at the end is different because it is specific to a car manufacturer. Quote Link to comment Share on other sites More sharing options...
Loconinja Posted October 18, 2016 Report Share Posted October 18, 2016 I'm curious. Eco mode will coast with the engine at idle, but won't that use more fuel than being in-gear with no throttle (as the fuel will cut)? Is it because the engine braking effect, even in a high gear, costs more fuel than running at idle? Quote Link to comment Share on other sites More sharing options...
ashleyman Posted October 18, 2016 Report Share Posted October 18, 2016 Will my wheel caps, bolts and covers from my 18' wheels fit on my 19' wheels? Quote Link to comment Share on other sites More sharing options...
Stobsie Posted October 18, 2016 Report Share Posted October 18, 2016 Will my wheel caps, bolts and covers from my 18' wheels fit on my 19' wheels? Bolts and covers will be fine, caps should be ok but not 100% sure. ashleyman 1 Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted October 18, 2016 Report Share Posted October 18, 2016 I'm curious. Eco mode will coast with the engine at idle, but won't that use more fuel than being in-gear with no throttle (as the fuel will cut)? Is it because the engine braking effect, even in a high gear, costs more fuel than running at idle? Yes, when coasting you are using more fuel than when you are in gear and foot off the throttle (in a modern car that cuts fuel off). However, you will coast further along a flat section than you will under engine braking so it sort of works out similar in the end. The coast feature really comes into it's own on slight downhill stretches that are steep enough to keep your speed up but not enough to prevent engine braking from slowing you down. The trick to ECO mode is to use all the tools, so you accelerate on a slight incline until you reach the crest, lift off and coast downhill until you get to the point where your speed begins to increase, then tap the brake to disengage coast and begin engine braking. Then as you approach the bottom of the hill and the car starts to slow under engine braking tap the throttle to re-engage coast. Disengage coast again and use throttle when you begin to slow on the following flat or incline. Rinse and repeat and use in conjunction with stop start to save yourself 10-12% fuel or £6-7 a tank in the city...but...only if you remain dedicated to ECO driving, sport will quickly undo everything. As I cannot go 20mins in an R without spotting an "S" opportunity, much less be able to resist it, ECO mode is completely pointless for me. I would also argue that stop/start and ECO mode together (used the majority of the time) will lead to earlier engine wear and DSG mechatronic wear etc. The Stop/start system I can make a good logical case for actually costing more long term (as I have done in other threads). The DSG mechatronics wear is just using the case that you are engaging and disengaging the clutch many more times than under normal driving so you'd think that would factor long term, what I don't know is how long term it will need to be as to whether it will ever be a factor in the cars normal working life. rbel5553 1 Quote Link to comment Share on other sites More sharing options...
Lustral Posted October 18, 2016 Report Share Posted October 18, 2016 Is there a way to make the dials on the dash room light up when the headlight switch is at the off and sidelight position at all ? Or is this a job for a VCDS cable ? Cheers Quote Link to comment Share on other sites More sharing options...
ashleyman Posted October 18, 2016 Report Share Posted October 18, 2016 Is there a way to make the dials on the dash room light up when the headlight switch is at the off and sidelight position at all ? Or is this a job for a VCDS cable ? Cheers I'm also searching for exactly the same answer. I think it's a VCDS only tweak but haven't been able to find the coding yet. Quote Link to comment Share on other sites More sharing options...
Lustral Posted October 18, 2016 Report Share Posted October 18, 2016 I'm also searching for exactly the same answer. I think it's a VCDS only tweak but haven't been able to find the coding yet. Cool let me know if you do find one , reason is that leaving the lights on auto is a tad sensitive and comes on far too early , prolly due to the dashcam slightly blocking the sensor behind the rear view mirror. Quote Link to comment Share on other sites More sharing options...
Boj27 Posted October 18, 2016 Report Share Posted October 18, 2016 I'm also searching for exactly the same answer. I think it's a VCDS only tweak but haven't been able to find the coding yet. If the coding from the SEAT forum is applicable, i can probably help you out there. I don't know if the same coding is needed for the golf though and it's coding so I wouldn't want to mis-inform. ashleyman 1 Quote Link to comment Share on other sites More sharing options...
Boj27 Posted October 18, 2016 Report Share Posted October 18, 2016 Does anyone have a photo of a lapiz blue with a blue badgeskin on the front and rear R badge? Quote Link to comment Share on other sites More sharing options...
ashleyman Posted October 18, 2016 Report Share Posted October 18, 2016 If the coding from the SEAT forum is applicable, i can probably help you out there. I don't know if the same coding is needed for the golf though and it's coding so I wouldn't want to mis-inform. Can you link it please mate and I'll have a look. Quote Link to comment Share on other sites More sharing options...
Boj27 Posted October 18, 2016 Report Share Posted October 18, 2016 http://www.seatcupra.net/forums/showthread.php?t=393714 About 1/3 of the way down. Following that guide, my "0" position on the headlight switch leaves my front DRL's turned on at full brightness, NOT half brightness like they are on the side light position, also all my interior lights on the dash are on at all times, and the rear lights also now act as DRL. I'm not sure how this would work with the golf as the rear DRL lights are also the brake lights (albeit at a lower light intensity), whereas the cupra I have as of now has separate rear lights and brake lights. So activating this, I'm not sure if the rear lights will be on full intensity at all times in the 0 position on the golf? Only thing that isn't on with this coding is the dipped beam and main beam, it's pretty cool. Was going to try this on the golf when mine is delivered, so hope this works! Quote Link to comment Share on other sites More sharing options...
Boj27 Posted October 18, 2016 Report Share Posted October 18, 2016 are the windscreen washer jets the spray type or jet type? Quote Link to comment Share on other sites More sharing options...
