Guy Incognito
With DSG, is there any way to go from S-Manual straight into D-Auto?
I frequently have a bit of a thrash in S-Manual, but then end up in traffic or a 30mph zone.  At that point I'm usually in 4/5/6 and low revs, but to get back into auto I have to go through S-Auto which drops it straight into 2 (or something equally stupid) before I can go back into D-Auto.
Haven't been able to figure that one out BUT by turning cruise on it'll override the gears for you.
Example, driving at 30 in Gear 3 in Sports Manual. You come to a 30 zone and want to go back to standard D-Auto.
First scenario:
Flick back to S-Auto, car drops to Gear 2, flick to D-Auto, car changes up to Gear 4.
Second Scenario:
Remain in Sports-Manual. Activate cruise at 30mph. Flick to S-Auto and the car will change up gears. Then you can flick to D-Auto.
(When in cruise the gearbox usually runs in the D-Auto box, so won't drop the box down so its in Sports mode. Also, if you're in the Manual gearbox mode, the car won't change gear for you unless you're going to damage the box by not changing.)
I find by doing the second set of instructions I skip that annoying step of it dropping down to Gear 2 when going back to S-Auto. Then changing to D-Auto and it changing up. Activating cruise skips that step! This is probably badly written, I'm tired but hopefully you get the point!
First scenario:
Second Scenario:
That's a good idea actually, I'd forgotten about ACC using higher ratios.  Probably won't cover me in all situations (e.g. slowing down into a 30mph with no traffic) but will do for most.
But I'm not in S-Auto to start with, I'm in S-Manual.
I have to go back into S-Auto before I can do anything else, and it's that change that instantly drops the car several gears.
If I leave it in S-Auto, but temporarily go manual by using the paddles, it'll change back into full auto after a while if I don't change gear? That's exactly what I'm trying to avoid!
Yes I know you are in S-manual to start but just saying that if you keep the stick at S-auto and use the paddles to go into S-manual then do a certain sequence quickly, although it has to go back to S-auto first, you can fool it to retain gear, or drop only one gear when going into D-auto.
I was making the presumption that you would be using the gears in S-manual -?paddles and not allowing it to back to auto by itself.
If I understand you correctly, this is what I normally do in that situation: I'm in S-Manual (and probably Race mode) but I have changed up to a higher gear, so I press the Mode button and select "Normal". This should put the gearbox in D-Manual. Move the stick over to D-Auto and it will usually just stay in the same gear.
Is it not like the raised bars on the 'F' and the 'J' on a keyboard, i.e. to let you tell which dial you're on by feel?
yes I guess so ... I just thought it was a bit superfluous, with the dials being so big, I find I can usually locate the correct one by feel anyway ....
It's for blind drivers, so that they or their guide dog, can tell which dial they are adjustng
lol
To stop the car steaming up?  If you only use recirculated air the humidity will go up very quickly otherwise.
I always used to use the recirculated air in my last car to keep the temperature up without needing to be warming up fresh colder air. Just a bit annoying that this won't do the same. Surely it takes more energy to heat up fresh air than it does to just pump the hot air back in.
I've yet to have my car steam up at all once the initial mist is cleared...
Doesn't use any energy to heat up the air does it?  I thought it just took the heat from the coolant loop that was otherwise going to waste (out through the radiator).
I know what Ash means, when the car interior is warming up, if you recirculate the air which is gradually getting warmer inside the cabin through the heater unit, it stops the much colder air from being dragged in from outside cooling down the heater matrix. This aids a quicker warm up for both the engine and inside the car in theory. However, I am amazed at how quickly the "R" warms up, even at very low temperatures you can feel warm air coming through about one mile from start up.
Two things of note. Phil C. I think that the welcome heat that you feel so quickly after start up on a cold morning is not water/engine derived but a heater element ( electrical).
Ash and Co. I was of the opinion that the button that you refer to is to "close off" the air intake from outside when you are sitting behind a big diesel truck or close to some noxious external source. Of course this would ultimately make the cabin very stuffy but would only be necessary on the odd occasion. I suppose it would aid cabin warm up in the first instance though.
