Booth11 Posted November 8, 2016 Report Share Posted November 8, 2016 This isn't so much a Golf question, but a question about tyre pressures. I don't really know how to word it so bear with me!! I have to drive for 5 minutes to pump up my tyres, meaning by the time I get to the garage there is some warmth on the rubber. The tyre pressure displayed on the Air machine isn't 100% correct. I can check my tyre pressures at home, but obviously by the time I get to the garage they'll be different. How do I work out what to put in the tyre when I get to the garage? For example, If I check my tyre pressure at home when the tyres are cold (which I have the facility to do), the PSI is 35. That means I need to pump them up to my ideal of 41 (+6 PSI). When I get to the garage and check the pressure it might say 37 for example. If I wanted 41 PSI (now +4PSI) do I literally just input +4 PSI or +6PSI based on the difference when cold? OR is it a little more complicated than that and I should spend out on a pump for home? I checked and amended my tyre pressures today to 41 but the tyres were warm so I'm concerned that they're not technically 41PSI, more likely less when the tyres get cold. If you are a couple of psi out, I don't think it will be a problem, especially if you are checking them very regularly, but as above, get yourself an air compressor and do it yourself. I use this one. I went for one with an additional inflator function for other home/fish keeping duties. Does a good job all round. https://www.amazon.co.uk/dp/B002Q54D78/ref=pe_1909131_77697001_tnp_email_TE_AMZLdp_1 And check tyre pressures with the. https://www.amazon.co.uk/Michelin-Digital-Tyre-Pressure-Gauge/dp/B000V5F0XQ PHILC 1 Quote Link to comment Share on other sites More sharing options...
Bigman Posted November 8, 2016 Report Share Posted November 8, 2016 How do i turn off the passenger air bags? Quote Link to comment Share on other sites More sharing options...
TweedsideR Posted November 8, 2016 Report Share Posted November 8, 2016 How do i turn off the passenger air bags? In my Owner's Manual, it's on page 96. Switch on the side of the glove box. Bigman 1 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted November 8, 2016 Report Share Posted November 8, 2016 If you are a couple of psi out, I don't think it will be a problem, especially if you are checking them very regularly, but as above, get yourself an air compressor and do it yourself. I use this one. I went for one with an additional inflator function for other home/fish keeping duties. Does a good job all round. https://www.amazon.co.uk/dp/B002Q54D78/ref=pe_1909131_77697001_tnp_email_TE_AMZLdp_1 And check tyre pressures with the. https://www.amazon.co.uk/Michelin-Digital-Tyre-Pressure-Gauge/dp/B000V5F0XQ Got a pressure gauge. Just trying to figure out if there was a way to calculate what should be going in when the tyres were warmed. I'll look into a home inflator thingy though, can never have too many car bits!! Thanks! Quote Link to comment Share on other sites More sharing options...
Booth11 Posted November 8, 2016 Report Share Posted November 8, 2016 home inflator thingy A what? Sorry, I don't understand these scientific terms. ashleyman 1 Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted November 8, 2016 Report Share Posted November 8, 2016 Got a pressure gauge. Just trying to figure out if there was a way to calculate what should be going in when the tyres were warmed. I'll look into a home inflator thingy though, can never have too many car bits!! Thanks! Run your car in each season until you are sure the tyres will be at their nominal temperature, the temperature you will be doing the most miles under. So basically if all your journeys are less than 10 minutes (god save your R) then set them cold, if your average journey is longer, set them warm. The key point is to adjust for the seasons, in winter if you do not change to a winter tyre, then consider running at lower pressures so you can offset the colder operating temperature by having a bit more grip. General rule of thumb is lower pressure = more grip (but more rolling resistance), higher pressure = less grip (but less rolling resistance). AWD will help offset summer tyres in winter over rear/front drive but, as goRt alludes to, the right choice of tyre for the right conditions is king as you approach the weather extremes. Quote Link to comment Share on other sites More sharing options...
ashleyman Posted November 8, 2016 Report Share Posted November 8, 2016 Run your car in each season until you are sure the tyres will be at their nominal temperature, the temperature you will be doing the most miles under. So basically if all your journeys are less than 10 minutes (god save your R) then set them cold, if your average journey is longer, set them warm. The key point is to adjust for the seasons, in winter if you do not change to a winter tyre, then consider running at lower pressures so you can offset the colder operating temperature by having a bit more grip. General rule of thumb is lower pressure = more grip (but more rolling resistance), higher pressure = less grip (but less rolling resistance). AWD will help offset summer tyres in winter over rear/front drive but, as goRt alludes to, the right choice of tyre for the right conditions is king as you approach the weather extremes. Thanks! Not going into a tyre debate... Are you sure about setting tyre pressures at the operating temperature though? It makes sense to me but contradicts what I found online elsewhere. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted November 9, 2016 Report Share Posted November 9, 2016 Thanks! Not going into a tyre debate... Are you sure about setting tyre pressures at the operating temperature though? It makes sense to me but contradicts what I found online elsewhere. Yes, if that is the condition you are driving at most of the time then that is where you set the pressure to be. Assuming you have no leaks/defects of course. If you set your tyre to a pressure when cold, but, you run your tyres warm then your pressure increases slightly so you are not running at the desired pressure, the reverse is also true. There may be exceptions with certain tyres and conditions but as a rule of thumb, you want to set the pressure when your tyre is running in the range it will be running for the majority of its journey. As a debate in usual UK conditions, under normal everyday driving, it is really not a big deal a few psi either way (unless trying to home in on optimum fuel efficiency, even a few psi can make a difference then with modern tyres). As you start to get more to the extreme ranges though, start to look at any credited motor sport team tyre tactics and you will see it is all about getting the tyres right for the conditions. Quote Link to comment Share on other sites More sharing options...
ashleyman Posted November 9, 2016 Report Share Posted November 9, 2016 Yes, if that is the condition you are driving at most of the time then that is where you set the pressure to be. Assuming you have no leaks/defects of course. If you set your tyre to a pressure when cold, but, you run your tyres warm then your pressure increases slightly so you are not running at the desired pressure, the reverse is also true. There may be exceptions with certain tyres and conditions but as a rule of thumb, you want to set the pressure when your tyre is running in the range it will be running for the majority of its journey. As a debate in usual UK conditions, under normal everyday driving, it is really not a big deal a few psi either way (unless trying to home in on optimum fuel efficiency, even a few psi can make a difference then with modern tyres). As you start to get more to the extreme ranges though, start to look at any credited motor sport team tyre tactics and you will see it is all about getting the tyres right for the conditions. So basically as per usual with anything related to anything it's all a can of worms and there's no 'best practice'. Even the stickers in the car saying put your tyres at X are pretty much useless as it's more a case of, it should be around X but obviously it's never going to be X because it depends on how hot your tyres are, how long your journeys are and how hard you drive. I appreciate the advice but I don't think the answer I'm looking for exists. Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted November 9, 2016 Report Share Posted November 9, 2016 So basically as per usual with anything related to anything it's all a can of worms and there's no 'best practice'. Even the stickers in the car saying put your tyres at X are pretty much useless as it's more a case of, it should be around X but obviously it's never going to be X because it depends on how hot your tyres are, how long your journeys are and how hard you drive. I appreciate the advice but I don't think the answer I'm looking for exists. Welcome to physics This is why they are recommendations as there is no absolute, just a certain recommended pressure will generally suit "most" conditions. In the UK you are fine in a fair amount either side of that too as we are not exactly extreme most of the time. Quote Link to comment Share on other sites More sharing options...
ashleyman Posted November 9, 2016 Report Share Posted November 9, 2016 Welcome to physics I swear, the past 10 days have really ignited in me a desire to be more like Elon Musk. A man who can actually understand these things and work towards fixing them. From cameras with USB ports that aren't nearly good enough to perform efficiently for the task they're required to do, to brand new MacBooks being an utter disappointment if not a huge step back. Needing solutions to client problems where the technology to actually to do the job does not exist. Then also having double glazed window units not sealing because 'air' and tyres that require a certain PSI that will never actually be at that PSI no matter how hard you try. It makes me wish I'd have gone into a career that hadn't fried my brain being a fancy pants 'artist'. The Elon Musk reference was just an example, but basically somebody smart. I hate being dumb AND IM NOT EVEN DUMB!!! (if that makes sense) P-P-P-PirateGolf_ARRR! 1 Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted November 9, 2016 Report Share Posted November 9, 2016 I swear, the past 10 days have really ignited in me a desire to be more like Elon Musk. A man who can actually understand these things and work towards fixing them. From cameras with USB ports that aren't nearly good enough to perform efficiently for the task they're required to do, to brand new MacBooks being an utter disappointment if not a huge step back. Needing solutions to client problems where the technology to actually to do the job does not exist. Then also having double glazed window units not sealing because 'air' and tyres that require a certain PSI that will never actually be at that PSI no matter how hard you try. It makes me wish I'd have gone into a career that hadn't fried my brain being a fancy pants 'artist'. The Elon Musk reference was just an example, but basically somebody smart. I hate being dumb AND IM NOT EVEN DUMB!!! (if that makes sense) Don't overthink it, most of the time as long as your tyres are there, or there abouts, you are fine, you are simply dealing in fractions towards optimal, where optimal is an ever changing yard stick. Honestly, it's only because we all love our cars so much that we chase perfection, seeking an edge that motor sport traditionally chases. I blame Amazon reviews (ultimately the internet), before that sh*t, everyone just bought something they wanted without trying to find out if it was the 0.00001% better than the next product dexter 1 Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted November 9, 2016 Report Share Posted November 9, 2016 I hate being dumb AND IM NOT EVEN DUMB!!! (if that makes sense) Not at all, you are good at what you do otherwise you wouldn't be here owning a nice motor and questioning things. Things are only simple when you know the answer, seeking that answer is what separates you from those whom would settle for ignorance. ashleyman 1 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted November 9, 2016 Report Share Posted November 9, 2016 Don't overthink it, most of the time as long as your tyres are there, or there abouts, you are fine, you are simply dealing in fractions towards optimal, where optimal is an ever changing yard stick. Honestly, it's only because we all love our cars so much that we chase perfection, seeking an edge that motor sport traditionally chases. I blame Amazon reviews, before that sh*t, everyone just bought something they wanted without trying to find out if it was the 0.00001% better than the next product It's just annoying! I'm sure I'll get there, I'll buy a home tyre inflator and do my pressures cold, then I'm in line with the industry standard. That's close enough. Long rant that I deleted. leonmac 1 Quote Link to comment Share on other sites More sharing options...
SevenR Posted November 9, 2016 Report Share Posted November 9, 2016 Really easy question here on the DSG fluid change interval. I'm on track to be racking up a huge 2500 miles a year, how long (in years) should I be changing the DSG fluid? I'm away from home for a few days so I cant check my owners manual Quote Link to comment Share on other sites More sharing options...
