P-P-P-PirateGolf_ARRR! Posted November 11, 2016 Report Share Posted November 11, 2016 Gave the car a quick check today for fluids and stuff. Everything was fine except the oil. Back down near the bottom end of the dipstick extremely close to being dangerously low. We topped it up on October 17 when it was below the minimum and since then it's done over 1000 miles. I put just under 2L in it today to bring it back to 3/4 full. I know that VW say about a litre every 1000 miles but that seems quite excessive. Should I be worried that it's burning or just keep checking it and topping it up? It does sound a little excessive, but, when you say you topped it up in October, did you then check it the exact same way as this time around? I ask because I recently got a warning that oil was low, I checked it and the dipstick showed it was 3/4, now that time I checked it I had the engine up to temp, on level ground and went in, made a cup of tea, then came out and checked it 4-5 mins later. I obviously presumed from that reading the warning was an anomaly. The next day I got the same warning reappear so decided to check it out again, only this time I did exactly the same but used a stop watch to wait exactly 3 mins (closest definition of a "few minutes" stated in the manual). Much different story, I was down on the 1/4 mark (The inconsistency here though is if you take the manual as gospel it says "if the reading is in "C" engine oil is "OK" but the warning light/message triggered when the oil level was at least a 1/4 into the "C" area???). So in short, I think you need to ignore previous observations and take note of exactly the process you are using to measure the oil level so that you can directly compare like for like each time. It may just be that you under filled last time around and your oil usage is well within spec. If you actually look in the manual it specifically says only to top up with oil when it reaches point "D" which is actually below the hash markings on the dipstick in the picture! For me, from here on out, I will run engine to normal temp, shut off the car on level ground and prepare the bits whilst a stop watch counts 3mins, then take a reading and top up as needed. Given the warning at 1/4 "C" I will ignore that bit of the manual and top up if my reading is below the half way mark on the hashed part of the dipstick "C". The R is a complex beast to care for, she needs your full attention and appreciates you (and rewards) for noticing the details LARRSON58 1 Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted November 12, 2016 Report Share Posted November 12, 2016 Out of curiosity I just checked the digital manual downloaded from here and the advice is different and makes much more sense than my paperback manual. First is my paperback manual, second is the digital manual...to me it looks like they updated to the correct procedure after realising it was misleading in the printed version: Paperback manual (mine): Digital Manual downloaded from VWRoC supplied link: 75Type2 and roberth 2 Quote Link to comment Share on other sites More sharing options...
DibblyDobbler Posted November 12, 2016 Report Share Posted November 12, 2016 Hi All. Two quick and hopefully easy ones: 1. What oil is recommended/the preferred option for a G7R ? 2. I have acquired a large-ish stone chip on the middle of the bonnet. I'm not that bothered about cosmetics but would like to do something with it - are the DIY kits a waste of time? Better off with Chipsaway? (It's metallic black btw). Any help appreciated, thanks Quote Link to comment Share on other sites More sharing options...
Booth11 Posted November 12, 2016 Report Share Posted November 12, 2016 Hi All. Two quick and hopefully easy ones: 1. What oil is recommended/the preferred option for a G7R ? 2. I have acquired a large-ish stone chip on the middle of the bonnet. I'm not that bothered about cosmetics but would like to do something with it - are the DIY kits a waste of time? Better off with Chipsaway? (It's metallic black btw). Any help appreciated, thanks 1. Castrol Edge Professional Longlife III 5W-30 (504.00) is the recommended oil, or Quantum equivalent - Quantum Longlife III 5W-30 (504.00) 2. Depends. You can get a kit and have a go yourself, or get a smart repairer to do it, or live with it, or wait till you have more and get a bodyshop to sort them. DibblyDobbler 1 Quote Link to comment Share on other sites More sharing options...
DibblyDobbler Posted November 12, 2016 Report Share Posted November 12, 2016 Brilliant, thanks Rebecca! Quote Link to comment Share on other sites More sharing options...
Taz23-R Posted November 12, 2016 Report Share Posted November 12, 2016 Hi All. Two quick and hopefully easy ones: 1. What oil is recommended/the preferred option for a G7R ? 2. I have acquired a large-ish stone chip on the middle of the bonnet. I'm not that bothered about cosmetics but would like to do something with it - are the DIY kits a waste of time? Better off with Chipsaway? (It's metallic black btw). Any help appreciated, thanks Chipex is good stuff for stone chips. http://www.chipex.co.uk/ Sent from my iPhone using Tapatalk DibblyDobbler 1 Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted November 12, 2016 Report Share Posted November 12, 2016 Chipex is good stuff for stone chips. http://www.chipex.co.uk/ I just watched the youtube vid that shows the process, once the paint bit had been applied the camera changed angles and zoomed out etc to avoid giving an exact frame vs frame look. Maybe just marketing stirring the pot but I really am loathe to videos that do this as it is a pure "before" "after" scam tactic to shift lighting and reference to enhance the after shot. Maybe just paranoid as a natural sceptic though Have you used this yourself a few times? Quote Link to comment Share on other sites More sharing options...
75Type2 Posted November 13, 2016 Report Share Posted November 13, 2016 I've been quoted £150 from an associate for a stone chip (dent) on the DBP which is basically fill and prep 3 dents on the bonnet from a single stone whilst travelling down a duel carriage way. It's a complete respray of the front bonnet, as it's not a touch in/up kinda job. Don't rate smart repairs as there never going to 100%. Quote Link to comment Share on other sites More sharing options...
gfarmer Posted November 13, 2016 Report Share Posted November 13, 2016 I'll need to try checking my oil that way I always just checked it when I got a chance as my driveway ain't level so car could be cold or have had sat for a while when I Check it when cold it's always bang on top mark Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted November 17, 2016 Report Share Posted November 17, 2016 Did anybody get back to answer my question about turning off the Nav Lady if you decide not to go on a route that you selected or simply changed your mind? Sent from my iPad using Tapatalk If you have a destination ongoing and the MFD is showing the directions on it. All you have to do is press on either the up or down arrow on the right of the steering wheel. This then displays "Do you want to cancel route navigation" on the MFD and then just press the OK button which is next to the up and down arrows on the steering wheel. rbel5553 1 Quote Link to comment Share on other sites More sharing options...
Blackpug Posted November 21, 2016 Report Share Posted November 21, 2016 How many batteries are in the key fob? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Lustral Posted November 21, 2016 Report Share Posted November 21, 2016 How many batteries are in the key fob? Sent from my iPhone using Tapatalk 1 X CR2025 battery Quote Link to comment Share on other sites More sharing options...
Blackpug Posted November 21, 2016 Report Share Posted November 21, 2016 Thanks. Got a warning on the display today telling me to change key fob battery. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gigolo456 Posted November 27, 2016 Report Share Posted November 27, 2016 Everything All, am I right in saying that the AC should be kept on in the R? I am switching from Mk V GTi this week to an R, but the only times I have ever had AC on are when its very hot, or when wanting to de-mist windows! Many thanks Quote Link to comment Share on other sites More sharing options...
Booth11 Posted November 27, 2016 Report Share Posted November 27, 2016 Everything All, am I right in saying that the AC should be kept on in the R? I am switching from Mk V GTi this week to an R, but the only times I have ever had AC on are when its very hot, or when wanting to de-mist windows! Many thanks Uh-oh! You will never find a definition answer to that question. There are countless threads dedicated to it and different things work for people. For me, running air in all the time, year round works - no condensation, no misting, but not the case for everyone. Here's a recent thread, but if you do a search for condensation or misting, more will come up. http://www.vwroc.com/forums/topic/15838-condensation-on-inside-of-windscreen-this-morning-wtf/ Quote Link to comment Share on other sites More sharing options...
