Guy Incognito
Really easy question here on the DSG fluid change interval.
I'm on track to be racking up a huge 2500 miles a year, how long (in years) should I be changing the DSG fluid?
I'm away from home for a few days so I cant check my owners manual :hello:
VW state every 40,000 miles for both DSG and haldex.
I will probably be in a similar situation to yourself regarding annual mileage, maybe a touch more and plan to do them both at 3 years regardless of mileage - it's cheap enough
This isn't so much a Golf question, but a question about tyre pressures. I don't really know how to word it so bear with me!!
I have to drive for 5 minutes to pump up my tyres, meaning by the time I get to the garage there is some warmth on the rubber. The tyre pressure displayed on the Air machine isn't 100% correct. I can check my tyre pressures at home, but obviously by the time I get to the garage they'll be different.
How do I work out what to put in the tyre when I get to the garage?
For example, If I check my tyre pressure at home when the tyres are cold (which I have the facility to do), the PSI is 35. That means I need to pump them up to my ideal of 41 (+6 PSI). When I get to the garage and check the pressure it might say 37 for example. If I wanted 41 PSI (now +4PSI) do I literally just input +4 PSI or +6PSI based on the difference when cold? OR is it a little more complicated than that and I should spend out on a pump for home?
I checked and amended my tyre pressures today to 41 but the tyres were warm so I'm concerned that they're not technically 41PSI, more likely less when the tyres get cold.
I think you are over complicating matters here. The recommended pressure for your tyres is when COLD. Buy yourself a compressor and check at home when COLD.
but after 3 years, I will have only done 7500 miles - so its still required?
As said DSG oil and filter change is every 40k miles, but if you are going to be low mileage and still some way below that,, then for peace of mind and health of the car, I'd be inclined to get it done at the 4 year point (as if you were doing average £10k a year).
Gave the car a quick check today for fluids and stuff. Everything was fine except the oil. Back down near the bottom end of the dipstick extremely close to being dangerously low.
We topped it up on October 17 when it was below the minimum and since then it's done over 1000 miles. I put just under 2L in it today to bring it back to 3/4 full.
I know that VW say about a litre every 1000 miles but that seems quite excessive. Should I be worried that it's burning or just keep checking it and topping it up?
In the nearly 2yrs of ownership I've put in less than a 1L so to me that does sound excessive.
If the engine drank oil like I drink beer the Dealer would still say that it was perfectly acceptable and within VW's tolerance.
If you have to keep topping it up I think it needs investigating, especially as you had to put nearly 2 litres in.  I haven't had to put anything at all in mine.  Right up to the point it went in for first service (around 7k miles) the oil was still only a little below half way mark on dipstick.
