Splats Posted October 6, 2016 Report Share Posted October 6, 2016 Also, with regards to DSG, having now had my first DSG car for 48-hours and taken the time to learn as much as possible about it and how the technology works I'm going to make the following claim..... "in my view, 90%+ of the people that don't like DSG a) don't understand how the gearbox works and/or don't understand how to use it and all the modes/functions it has." The most simple example is I've heard people say, "even in manual mode it will drop a gear if you floor it". Not if you press the accelerator to the first stop it won't and, while I have yet to verify it, I'm 99.9% certain that the first pre-kick down throttle position = 100% throttle opening and 100% engine effort. In other words, pressing further only gives you kick down, not more throttle application. Otherwise, the only reason it will change gear is if it's going to stall or going to hit off the limiter. If I could make one change (without wrecking warranty) I'd want the upshift to be taken out so I can hit the limiter. It would no advantage at all, I just like the fact that it would be up to me to time the upshift correctly. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted October 6, 2016 Report Share Posted October 6, 2016 On each door frame there is a couple of holes on the top of each , on the front two there is a black plug or something on one of holes on each of the front doors , but on the back doors both holes are uncovered ... is this normal ? Actually on closer inspection the fronts have 3 holes and the middle one is covered .. ill load pics if needed Yes, that's normal. 2 uncovered holes in the rear doors and 3 holes in the front doors, the one in the middle with a plastic plug in. The hole with the plastic plug, I believe is the hole for locating roof bars and the plastic plug is simply a dust cover. All normal. Lustral 1 Quote Link to comment Share on other sites More sharing options...
Lustral Posted October 6, 2016 Report Share Posted October 6, 2016 Yes, that's normal. 2 uncovered holes in the rear doors and 3 holes in the front doors, the one in the middle with a plastic plug in. The hole with the plastic plug, I believe is the hole for locating roof bars and the plastic plug is simply a dust cover. All normal. Thanks Rebecca ! Sorry another question Basically someone rang me in the car for the 1st time and damn the ringtone was loudly piped into the cars audio , scared the hell out of me ... Is there a way to turn down the volume of the ringtone. I had it connected to Car Play via the USB if that makes any difference. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Booth11 Posted October 6, 2016 Report Share Posted October 6, 2016 Thanks Rebecca ! Sorry another question Basically someone rang me in the car for the 1st time and damn the ringtone was loudly piped into the cars audio , scared the hell out of me ... Is there a way to turn down the volume of the ringtone. I had it connected to Car Play via the USB if that makes any difference. Thanks in advance If using the phone via CarPlay, I could be wrong, but I don't think you can turn the ringtone down independently of everything else, think it's just the normal MIB volume button that controls all CarPlay volume functions, music, calls etc. Turning the ringtone volume down in the phone settings has no effect, I've tried that. I wish you could have the phone ringer set t a quieter volume though, as I get the same thing. I have my music playing via CarPlay pretty loud and when the phone rings it comes through at the same volume level. I had it the other day when I was parked up (all car windows and doors were shut) and the phone rang and several bystanders looked around so it must have been loud, lol. Quote Link to comment Share on other sites More sharing options...
Lustral Posted October 6, 2016 Report Share Posted October 6, 2016 If using the phone via CarPlay, I could be wrong, but I don't think you can turn the ringtone down independently of everything else, think it's just the normal MIB volume button that controls all CarPlay volume functions, music, calls etc. Turning the ringtone volume down in the phone settings has no effect, I've tried that. I wish you could have the phone ringer set t a quieter volume though, as I get the same thing. I have my music playing via CarPlay pretty loud and when the phone rings it comes through at the same volume level. I had it the other day when I was parked up (all car windows and doors were shut) and the phone rang and several bystanders looked around so it must have been loud, lol. Mine seems to be a lot louder than my CarPlay music to be honest .... I think you can adjust the volume when it rings , but it doesn't seem to 'set' for the next time you are called ... ill test some more laters Quote Link to comment Share on other sites More sharing options...
Booth11 Posted October 6, 2016 Report Share Posted October 6, 2016 Mine seems to be a lot louder than my CarPlay music to be honest .... I think you can adjust the volume when it rings , but it doesn't seem to 'set' for the next time you are called ... ill test some more laters Mine's roughly the same volume as the whatever the music is playing at but I have to quickly whack it down with the volume button as soon as it starts ringing. Let me know if you find a way to have it lower. Quote Link to comment Share on other sites More sharing options...
Loconinja Posted October 6, 2016 Report Share Posted October 6, 2016 I've noticed when in manual/tiptronic mode with the DSG, that the box will still kickdown if I press the accelerator past the "whoosh button". Is that normal? If I press the accelerator to the max, but before the button, will it give me maximum acceleration in the selected gear? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted October 6, 2016 Report Share Posted October 6, 2016 Yes, it will, and yes, that's normal. You eventually learn to stop just short of hitting that last little bit of the throttle to avoid the kickdown, and dropping down the gears. Quote Link to comment Share on other sites More sharing options...
erbsjo Posted October 6, 2016 Report Share Posted October 6, 2016 The closest analogy I can think of is that this is like insisting the lights are turned off and that you double bag when you are about the nail the biggest hottie of your life. It makes zero sense I'm glad you like it! And I've tried it: it works brilliantly of course. I'm not technophobic, I just don't like paying for machines to do stuff you didn't tell them to do when you're perfectly capable of doing them yourself. In the long term, I suspect it makes *some* people lazy, complacent and inattentive and it's potentially dangerous. And don't get me started on "Lane Assist" :-) Let me try a different analogy: ACC is like "nailing", as you say, the biggest hottie of your life while wearing a full-body condom, sitting in the corner watching someone else (whom you've paid) performing said activity. Or something. Actually, some people… oh never mind. It's probably good in general for safety in the short term. It's when people start unlearning skills, or never learning them in the first place, that technology can be counterproductive IMHO. To each his own. I'll definitely be trying it more. And surely will use it as a "game" and remain attentive. I just don't think non car/driving-interested people are all going to see it like that, but perhaps that's condescending to non-car-people? Does that make sense? Booth11 1 Quote Link to comment Share on other sites More sharing options...
erbsjo Posted October 6, 2016 Report Share Posted October 6, 2016 Also, with regards to DSG, having now had my first DSG car for 48-hours and taken the time to learn as much as possible about it and how the technology works I'm going to make the following claim..... "in my view, 90%+ of the people that don't like DSG a) don't understand how the gearbox works and/or don't understand how to use it and all the modes/functions it has." I agree. Amazing stuff, and has loads of advantages. I'm just nostalgic about the manual. Will be sad to see it go and wish one could retain the "feel" of clutch + manual. Left foot action.* In any case, I think it should remain an option even in the R Estate. *Oh, maybe left foot braking is the way to go? Quote Link to comment Share on other sites More sharing options...
Lawrie Posted October 6, 2016 Report Share Posted October 6, 2016 The most simple example is I've heard people say, "even in manual mode it will drop a gear if you floor it". Not if you press the accelerator to the first stop it won't and, while I have yet to verify it, I'm 99.9% certain that the first pre-kick down throttle position = 100% throttle opening and 100% engine effort. In other words, pressing further only gives you kick down, not more throttle application. Otherwise, the only reason it will change gear is if it's going to stall or going to hit off the limiter. If I could make one change (without wrecking warranty) I'd want the upshift to be taken out so I can hit the limiter. It would no advantage at all, I just like the fact that it would be up to me to time the upshift correctly. I have a DSG on order and am concerned about this as I don't believe you are correct. I currently have a manual 2015 R and the only way to stop the soundaktor noise without VCDS is to put the engine in Eco mode. On the motorway to stop the fake noise I put the car in individual mode and have it set so everything is in sport/race except for the engine which is in Eco. There is a big difference in power between foot down up to the kick down switch and foot down past the kick down switch. I would honestly say it feels like you get about 50bhp more when you push the accelerator to the floor, and I guess the outer exhaust flaps open too when you do that. When I have a DSG I guess the car will drop a couple of cogs when I floor it, even though I don't want it too as there is plenty of torque throughout the rev range in the R... Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted October 6, 2016 Report Share Posted October 6, 2016 Not related to Mk7's at all but, who's the guy that has a 7R and also got a McLaren recently?? I'm looking to work on some personal photography projects for my portfolio over winter. I wanted to speak to the owner to find out if we could organise a time to shoot some pictures. Soz if someone else already posted, skimmed and couldn't see a reply. bishbosh Revealing pic Quote Link to comment Share on other sites More sharing options...
ashleyman Posted October 6, 2016 Report Share Posted October 6, 2016 Soz if someone else already posted, skimmed and couldn't see a reply. bishboshRevealing pic That's the one. Thanks mate! Quote Link to comment Share on other sites More sharing options...
Rich_D Posted October 7, 2016 Report Share Posted October 7, 2016 Answer after test drive: Disable Front Assist. A warning light shows up... No ACC but cruise control available. At least I can do that if I insist. So I'll leave it. My last VW was the first R32: no bloody anything in that - pure pleasure;-) Well, I tested this last night and can confirm that it does not work, even with front assist turned off (I left the menu screen showing to confirm it was still off, there is also a yellow exclamation mark on the dash), the cruise control still works as ACC and maintains a distance from the car in front, I turned the sped up to 90 and it still sat there doing 75 following the car in front, so it does not work like 'normal' cruise control, this is in my 65 plate DSG R at least. Quote Link to comment Share on other sites More sharing options...
Rich_D Posted October 7, 2016 Report Share Posted October 7, 2016 I've noticed when in manual/tiptronic mode with the DSG, that the box will still kickdown if I press the accelerator past the "whoosh button". Is that normal? If I press the accelerator to the max, but before the button, will it give me maximum acceleration in the selected gear? Don't mash the pedal to the floor, learn where the soft stop is before you hit the kickdown switch at the end of the pedal travel and it will not change down automatically in manual mode, so you can ride the torque and let the car pull through the revs. Test it with the engine off parked up, you'll soon get a feel for it. Quote Link to comment Share on other sites More sharing options...
