gtiboy Posted January 16, 2018 Report Share Posted January 16, 2018 Hi all, I am new to tuning and would like some advice. I have placed an order for a Golf R, but interested in doing a few mods. I was looking to change the standard panel Air filter with an after market one? Is ITG any good? Also change the sparks plugs to NGK and fit a TT intake pipe, which seems to be popular on here. Not looking to remap. Just a few simple mods to make the engine pick up better, if it pulls better a lower revs and pulls slightly harder at higher revs, i'll be happy with that. Would any of these mods combined together make any real discernible difference? or would I be wasting my money and keep it stock? Quote Link to comment Share on other sites More sharing options...
ToRnado Posted January 16, 2018 Report Share Posted January 16, 2018 The mods themselves will make little to no difference in power. Msportman 1 Quote Link to comment Share on other sites More sharing options...
VRSNorthampton Posted January 16, 2018 Report Share Posted January 16, 2018 Hi gtiboy, A remap is the way to go if you're looking for a noticeable increase. This alone gives ~70hp and a shed load more torque. Massive difference in power delivery. Quote Link to comment Share on other sites More sharing options...
R-Estate Posted January 16, 2018 Report Share Posted January 16, 2018 Hi gtiboy, A remap is the way to go if you're looking for a noticeable increase. This alone gives ~70hp and a shed load more torque. Massive difference in power delivery.^this. I changed the panel filter and turbo elbow which dyno’d the same as stock so no power increase. Go JB4 if worried about warranty if not go stage 1 software. Jon R306 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 16, 2018 Report Share Posted January 16, 2018 Fit a pedal box. Jon R306 1 Quote Link to comment Share on other sites More sharing options...
Mother Theresa Posted January 16, 2018 Report Share Posted January 16, 2018 Oooh we like spending other people's money for them.... Pedalbox 1st. JB4 or stage 1 tune 2nd, anything else is just playing at it I'm afraid. Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
mp2811 Posted January 16, 2018 Report Share Posted January 16, 2018 Those mods waste of money stock. Obvioisly stage 1 tune biggest improvement but if you're not looking at that due to warranty. Then pedal box best to improve throttle response. Possibly resonator delete? That would get you decent improvement in exhaust note but I'm not sure how that would affect warranty. Msportman and Jon R306 1 1 Quote Link to comment Share on other sites More sharing options...
gtiboy Posted January 17, 2018 Author Report Share Posted January 17, 2018 I may look into Pedal boxs then once I'm used to the throttle response. What are facelift Golf R's in stock form producing on the Dyno's? I heard one person getting 326bhp Quote Link to comment Share on other sites More sharing options...
Jon R306 Posted January 17, 2018 Report Share Posted January 17, 2018 35 minutes ago, gtiboy said: I may look into Pedal boxs then once I'm used to the throttle response. What are facelift Golf R's in stock form producing on the Dyno's? I heard one person getting 326bhp I've seen 322bhp on an accurate Rolling road for the facelift and 350bhp with 50ftlbs of added torque with a JB4 on a standard map 2 which keeps your warranty in check if taken off before dealer visits. I have just the pedal box plus fitted and it transforms the throttle response no end.. fantastic mod . Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted January 17, 2018 Report Share Posted January 17, 2018 Ramair foam replacement panel filters on eBay at £27.99. I think that’s going to be hard to beat although I’ve a K&N one in mine if I was buying now I’d go for that one. Im running the APR single piece cast turbo elbow which improves air flow by 17% coupled to a Racingline inlet hose and JB4 along with the pedal box + (see build thread for pics link in sig) and find this to be a good combo. Spark plugs will be replaced in the next week or two. Quote Link to comment Share on other sites More sharing options...
gtiboy Posted January 17, 2018 Author Report Share Posted January 17, 2018 11 minutes ago, Rob2k68 said: Ramair foam replacement panel filters on eBay at £27.99. I think that’s going to be hard to beat although I’ve a K&N one in mine if I was buying now I’d go for that one. Im running the APR single piece cast turbo elbow which improves air flow by 17% coupled to a Racingline inlet hose and JB4 along with the pedal box + (see build thread for pics link in sig) and find this to be a good combo. Spark plugs will be replaced in the next week or two. What spark plugs come with the Golf R? I see people upgrade them to RS7 ones? Do these make the car feel smoother when accelerating? Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted January 17, 2018 Report Share Posted January 17, 2018 35 minutes ago, gtiboy said: What spark plugs come with the Golf R? I see people upgrade them to RS7 ones? Do these make the car feel smoother when accelerating? Some blurb I found on the RS7 plugs ..... These plugs are typically found in the 4.0T RS cars such as the RS7, S7, S6 & S8. Produced by NGK, these plugs feature an iridium tip for a longer life span. Why Run these plugs? Is your car tuned? If so, you have increased the heat within your cylinders. This increased heat can cause some issues when pushing your car to the limit. The biggest problem is detonation which is caused by excessive heat in the cylinder. What do they do? These plugs are a step colder meaning they will cool off faster than your stock plugs. This is important on tuned vehicles as it helps prevent excessive heat which can cause detonation. Product Features - One heat range colder - Higher change interval (35,000 miles) - Iridium Tip Jon R306 1 Quote Link to comment Share on other sites More sharing options...
tuono Posted January 17, 2018 Report Share Posted January 17, 2018 2 hours ago, Rob2k68 said: Some blurb I found on the RS7 plugs ..... These plugs are typically found in the 4.0T RS cars such as the RS7, S7, S6 & S8. Produced by NGK, these plugs feature an iridium tip for a longer life span. Why Run these plugs? Is your car tuned? If so, you have increased the heat within your cylinders. This increased heat can cause some issues when pushing your car to the limit. The biggest problem is detonation which is caused by excessive heat in the cylinder. What do they do? These plugs are a step colder meaning they will cool off faster than your stock plugs. This is important on tuned vehicles as it helps prevent excessive heat which can cause detonation. Product Features - One heat range colder - Higher change interval (35,000 miles) - Iridium Tip would these be okay on a standard r as I wont to change mine soon Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted January 17, 2018 Report Share Posted January 17, 2018 5 minutes ago, tuono said: would these be okay on a standard r as I wont to change mine soon I would imagine so but maybe somebody with them fitted with no other mods will be along soon to comment. On my stage 2 S3 I was running NGK race plugs (similar to RS7 plugs both NGK with iridium tips and one step cooler but 4x the cost !) which were great. When I ran it around for 6 weeks standard prior to selling it there were no issues at all. Quote Link to comment Share on other sites More sharing options...
BobbyT Posted January 17, 2018 Report Share Posted January 17, 2018 I wouldn't change from the OE plugs if you're running standard. Only worth it if you start to use a map/jb4 Quote Link to comment Share on other sites More sharing options...
