Knock/Rattle/Clunk
T80VWR
Evening, I'm new to the forum, so please excuse this post if it's been addressed before.
I have mk7.5 R with the most annoying knock/rattle /clunk from what appears to be coming from the drivers side front end. If I gently press the brakes it disappears. It's not pad rattle as they have been replaced around 50 miles ago and I've also done the following mods noise was present before mods) kw street coilovers, racingline drop links, new top mounts fully polly bushed adjustable caster and h&r roll bars...oh and racingline big brake kit. Any help would be greatly appreciated.
@T80VWR: Matt - Hi.
Of course there could be a gazillion different reasons for this problem - so the suggestions below are complete guesses!!
maybe check the tightness of bolt on the coupling-rod  -1- on the driver-side strut.
And perhaps the top suspension-strut bolts under the plenum cover on the driver-side
Can you describe the circumstances in which it makes the noise? i.e. Over speed bumps, potholes low speed manoeuvring etc.? Is it any worse or better in hot, cold, wet, dry? What year and mileage? How long have you had the car? Did you do the upgrades yourself or did a VW specialist garage do them? Are you in the UK (RHD)?
If you work on the assumption that the parts that have been changed are not responsible, and having checked the things that Don has mentioned above which should have been tightened correctly when the new parts were fitted. The fact that the noise goes when you brake (the brake pads would be the most obvious thing here but you have changed them to a different make of pad?) then it might suggest lower wishbone bushes or ball joint. My theory being that as you brake it puts the bushes and joint under tension which is stopping them from rattling momentarily. It could also be the track rod end ball joint (though less likely).
It happens when the road surface is bumpy, it never happens over speed bumps, but is evident over potholes too.
All the work has been done by qualified mechanics, who specialise in suspension upgrades.
Everything is torqued as should be. I've also changed the front subframe for the S3  aluminium set-up and used the 034 alignment kit. I haven't changed the track rod ends. It's driving me insane, not being able to cure the damn noise.
Has anyone else experienced anything like this?
Yes, I have hence the questions. Mine was left hand side (near side) of the car though. I changed lower control arm, droplinks, lower ball joint and gearbox top link on the near side one after the other to no avail, before changing the top mount and bearing (there are two parts which make up the complete top mount) which cured my creaking/ rattle on uneven surfaces. It was more pronounced in hot weather and with a passenger. If you haven’t changed both parts of the top mount then that might be it. I understand the most common failure is the metal sleeve that the strut nut sits in moves in the rubber mount causing the noise. The whole saga is here. If you search in the Tuning and Modifying Mk7 section there is more cases in there. Hope you get it sorted.
Hello mate, I’m currently looking in to doing this S3 Aluminium subframe swap what parts did you need to fully swap it?
I’ve got my eyes on new control arms with ball joints, Racingline aluminium dogbone mount, front arb, new track rod ends and potentially the subframe alignment kit along with new bolts.
any info/ help would be appreciated
Hello mate.
I swapped out the arb for the H&R front and rear kit, 034 motor sport subframe alignment kit, racingline aluminium dog bone mount (fairly harsh vibrations in the cab with this mount but eliminated the wheel hop), replaced all bushes for poly units and adjustable caster mount too  and racingline adjustable droplinks. It handles so much better, just the annoying rattle to diagnose. Hope this helps.
  • 5 months later...
@T80VWR
Hey Matt
Did you have a win on this front?
I've been going through the same saga, I've done strut mount & bears, struts, link rods, lower control arms & ball joint.
Myself and 2 mechanics have had a look and can't figure it out.
I'm thinking of pulling the trigger on engine mounts as I'm fresh out of ideas, if you've got any feedback that'd be great.
Cheers
