What fuel do you use
Lemar
It's pretty simple, the car should run on 98 minimum to obtain maximum power, it can however safely run on 95 and the ECU will pull some igntion timing, so you'll lose a bit of power, but no damage will occur.
Personally I use either Tesco Momentum (most of the time) or Shell V Power, as I'm running JB1 so want the higher octane as boost pressure is higher.
37 minutes ago, Harry8052 said:
Does anyone put additives in with their fuel??
There seem be quite a few on the market that promise to clean the plugs etc and only need to be added every few thousand miles or so.
No need if you run Shell V Power
28 minutes ago, Ignition1 said:
To save you time in searching forums:
Standard fuel will ruin your car, spark plugs will rust, it'll cause back-firing, severe damage to every single part of the engine, affect your marital performance and you'll be considered an illogical peasant by everyone you meet.
Premium fuel, on the other hand, is a glorious golden nectar that hugs your car's engine like a pure cashmere blanket on a cold day.
LOL'd 😂
5 hours ago, Naz7r said:
I use Tesco momentum or shell vpower, I'd just top it up with Either one of the above.. it'll effect the performance by putting 95 but 99 is recommended on these cars if I'm correct.
Regarding the misses, go easy on her as your still lucky she never put diesel in emoji51.png
I bet she's tried
Post of the week award please admin 😂
Standard BP Unleaded for me. There's BP Ultimate if I fancy something higher octane, but other than that, nothing else in Northern Ireland. No Shell petrol stations at all and no Tesco Momentum. We're all tight over here. Drive diesels and the red variant at that 😂
21 June 2017
I use Mobil Super+ Synergy 93 octane almost exclusively.  In reference to a previous question, yes, you can use a lower octane fuel only on a temporary basis.  The engine will automatically adjust to a lower octane, but performance will be lost.
On 2017-6-21 at 19:04, JoeyJoeJo said:
Did a search with no results - anyone using Costco 99 premium?
Do very well with other kirkland products so would be open to trying it.
Interesting to mention Costco because there's one not a million miles from me and the 99 is very cheap, I did call the branch (Thurrock) and they couldn't give me any details. I haven't filled up there yet but will when i'm next over that way and see if I can feel any difference.
