Lemar Posted June 21, 2017 Report Share Posted June 21, 2017 Hello what fuel do you all use my misses put normal petrol in i think it was 95 Ron will this affect the car Quote Link to comment Share on other sites More sharing options...
reynmolds Posted June 21, 2017 Report Share Posted June 21, 2017 It will effect performance but wont damage the car long term, if you dont use it frequently. Quote Link to comment Share on other sites More sharing options...
maccas99 Posted June 21, 2017 Report Share Posted June 21, 2017 vPower FTW! As Reynmolds has said, it can run on either. If you do a search you will find this has been discussed many times before.... Quote Link to comment Share on other sites More sharing options...
mickR Posted June 21, 2017 Report Share Posted June 21, 2017 There are quite a few threads on this subject already on here if you use the 'search' tool. Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Novus Posted June 21, 2017 Report Share Posted June 21, 2017 Tesco Momentum, as the garage is across the road from home Quote Link to comment Share on other sites More sharing options...
Booth11 Posted June 21, 2017 Report Share Posted June 21, 2017 Shell V Power. As said by mickR, there are many many comprehensive threads in this divisive subject, it's always a hot topic! Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted June 21, 2017 Report Share Posted June 21, 2017 Shell V Power. Failing that, other 97 or 98 RON brands are acceptable Quote Link to comment Share on other sites More sharing options...
Worzel Posted June 21, 2017 Report Share Posted June 21, 2017 Tesco Momentum for me TuftyR 1 Quote Link to comment Share on other sites More sharing options...
Lemar Posted June 21, 2017 Author Report Share Posted June 21, 2017 Thanks for the info my old Mazda 3 mps had to run in 98 Ron Quote Link to comment Share on other sites More sharing options...
xPETEZx Posted June 21, 2017 Report Share Posted June 21, 2017 Look no further than your fuel cap. Reads 98(95) Meaning: 98 is the recommend fuel, 95 is the minimum. So your car will be 100% fine. Even if you fed it nothing but 95. Fruitloop and LARRSON58 2 Quote Link to comment Share on other sites More sharing options...
paulm781 Posted June 21, 2017 Report Share Posted June 21, 2017 I had a MKv R32 for 5 years before my Mk7 R. I've always switched between V Power, Momentum and ordinary 95 (depending on funds and location) I have to say, the performance and MPG difference was a lot more noticeable in the R32 when using Momentum/Vpowe over '95. In fact I would probably have been able to tell what fuel was in just from driving! With the R I can't tell the difference if I'm honest so I normally just put 95 in now. arthouse 1 Quote Link to comment Share on other sites More sharing options...
Harry8052 Posted June 21, 2017 Report Share Posted June 21, 2017 Does anyone put additives in with their fuel?? There seem be quite a few on the market that promise to clean the plugs etc and only need to be added every few thousand miles or so. mickR 1 Quote Link to comment Share on other sites More sharing options...
Ignition1 Posted June 21, 2017 Report Share Posted June 21, 2017 To save you time in searching forums: Standard fuel will ruin your car, spark plugs will rust, it'll cause back-firing, severe damage to every single part of the engine, affect your marital performance and you'll be considered an illogical peasant by everyone you meet. Premium fuel, on the other hand, is a glorious golden nectar that hugs your car's engine like a pure cashmere blanket on a cold day. invisiblekid, Microbe, shandyman and 10 others 13 Quote Link to comment Share on other sites More sharing options...
Naz7r Posted June 21, 2017 Report Share Posted June 21, 2017 Hello what fuel do you all use my misses put normal petrol in i think it was 95 Ron will this affect the car I use Tesco momentum or shell vpower, I'd just top it up with Either one of the above.. it'll effect the performance by putting 95 but 99 is recommended on these cars if I'm correct. Regarding the misses, go easy on her as your still lucky she never put diesel in gfarmer and Lemar 2 Quote Link to comment Share on other sites More sharing options...
gfarmer Posted June 21, 2017 Report Share Posted June 21, 2017 V power or Tesco momentum which ever is closest to ya Sent from my iPhone using Tapatalk Naz7r 1 Quote Link to comment Share on other sites More sharing options...
