What fuel do you use
Lemar
Tac1 - is there really that much difference just from fuel? 14bhp? Ive not heard that before.
Hugh amount of bull available on this subject.  Some claim a 10% differential, but I do not believe this.  A reasonable guide would be to compare VW declared data in other markets, say US or somewhere where 98/99 is not available - that's where my figure is taken from.
However, others may say different, have a look at https://www.pistonheads.com/gassing/topic.asp?t=302977 .
Theoretically, there should be a slight improvement in consumption as well.
Just to correct you. 98 RON IS available in the US. They use an average of MON and RON to get their POM (Pump Octane Number). 93 Gas pump in the USA is equivalent to our 98RON.
That link is 11 years old!
There was a more recent test done by Fifth Gear using a Golf GTi Ed35.
You need look no further than the small jump over to the republic of Ireland. They have the same quoted 300bhp car, but no 98 available.
Interesting comparison that from 5th gear I know its a few years old but cant see much change in fuels since then.
The other point though is the manufacturers claim that their "super" fuels keep the fuel sytems cleaner and are better for the engine and certain components long term? That is so much harder to test and compare as you would need 2 of the exact same car with same milage etc... being driven with the same driving style, over the same miles preferably on the same routes/roads for a substantial time. Then a full inspection of certain internals and componants which is way to much and in depth for most to contemplate trying. So i guess we will never truely know on the side of it?
Date of tests make little difference to results, both Fifth Gear and earlier tests are valid, even if both have different conclusions :)
You are entirely correct re. fuel additive packs and claims made for such.
The only such strip-down test I am aware was conducted so long ago as to be irrelevant, when Tesco first started selling petrol.  The AA ran two similar engines for a relatively short period and then fully stripped them; sample ran on 'normal' fuel was clean and unmarked, that using new, cheaper, Tesco offering was absolutely filthy, black, everything covered in soot, horrible.  Until then, Tesco fuel had no cleaning detergents added, it did thereafter!  Historical note of no current relevance.
Possibly, a plethora of detergents is no longer quite as important as in years gone by, the worst component of earlier fuels being lead.
The fifth gear test was undertaken at R-Tech who are VW specialist tuner (mk4-6 models). They see 15-20bhp difference at stage 1 with the K04 turbo TFSI engine (mk6 R, GTI Ed30/35) when using v-power over 95RON.
I'm a good friend of the guy in the video (Niki), and he absolutely hates 95RON as it massively affects the figures of tuned vehicles, and sees the impact on standard cars.
That has been done by one of the motoring magazines a while ago, they did before & after comparisions with a borescope, performance tests, etc... comparing Shell (possibly Optimax at the time) to regular fuel and it was pretty conclusive that it did keep internals clean and would improve dirty internals.
Indeed.
As soon as you start tuning then 95 RON is a big no, no :)
First thing to remember is all fuel must meet British standards, so it's not like any fuel you buy in the UK is going wreck your motor. However, some of it certainly doesn't treat the engine well.
My brother is one of those guys that fixes petrol pumps, you'll probably have seen them when you fill up. He has a pretty good 'insider' view of the whole thing. The stations he would absolutely avoid at all costs would be Morrisons (the absolute worst), Tesco, Asda and Sainsbury's. These pumps have their filters changed multiple times more than a 'premium' brand owing to how 'dirty' it is. It doesn't have any of the same detergents or additives, and those it does have aren't the same quality. The fuel that the supermarkets buy is basically from the same refinery (of course, there is only so many places you can get the raw product). However, it is the processes after that which makes the additional premium seem more reasonable. All UK fuel needs to have bioethanol content. Momentum has more of this than V-Power and Ultimate. The actual OCTANE is the same. Forced induction cars seem to enjoy the benefits of a greater alcohol mix, hence why most of us are finding Momentum our preferred fuel. And it's cheaper.
5 hours ago, ReapSTAR said:
So are you saying Momentum is good or bad??
Momentum is the same Greenergy 95RON but with the bioethanol mix increased to nearer 10% (maximum allowed) instead of the 'up to 5%' in the regular 95RON. The chances are it will have additional additives/detergents etc but I'm not sure. V-Power doesn't get its higher RON through a bioethanol increase above 5%, but presumably through either another additive or a difference in the refining process.
What is often not considered by many of us is if we fill up at a station that doesn't see its premium pumps used as often it can increase the chance of getting dirty fuel. However, the pumps have filters so that this doesn't happen. I believe my brother changes more of the premium lines owing to deterioration through relative lack of use. Top tip is to buy from a station in an area where others are likely using premium fuel...
