Reverting Pace Car indicators to standard
LouCyffer
My 15 plate 7R has pace car indicators enabled; I noticed this not long after I took delivery in May. After some consideration I've decided that I'm not a fan of the look, nor the potential for MOT fail (next March). However, I've no idea what the 'standard' settings are.
Can some kind soul enlighten me so I can plug in my VCDS cable and sort this?
12 minutes ago, ashleyman said:
Really good thread here.
Can you follow the steps backwards? I'd say be careful. I managed to totally mess mine up going from pace car to standard. Eventually got it fixed and found I'd got a channel wrong.
If there's potential to mess it up, I'll find it Ash 😂
I'll take a look, thanks.
2 hours ago, goRt said:
There's only 2 values to change :banghead;
Yep, ''twas pretty easy. As long as you know your 'links' from your 'rechts'. At one point I had three of the rear four flashing left and one to the right 😂
But each side simply needs changing from 'Dunkelphase' to 'Hellphase'. No other changes necessary. 5 minute job.
8 minutes ago, LouCyffer said:
Yep, ''twas pretty easy. As long as you know your 'links' from your 'rechts'. At one point I had three of the rear four flashing left and one to the right 1f602.png
That's what I ended up with, tried to correct it and ended up with a whole other problem! At least you didn't take 2 wrong turns like I did!
Just the one, Ash. But the spectacular swearing I managed sure made up for it!
Thanks again for the link.
Honest Lou's Pace Car Indicator service is now open for business😄
