Blobby Posted August 21, 2018 Report Share Posted August 21, 2018 Hi All new to the forums but in need of some help, I have a mk7 2016 golf r in manual, and its just thrown a conrod through the engine block so it now has a tennis ball sized hole in it, (went with a very large bang) the car hasn't been mapped or modified in any way, its done 39k has this happed to any one else? also its two months out of warranty. why has this happened Quote Link to comment Share on other sites More sharing options...
slider09 Posted August 21, 2018 Report Share Posted August 21, 2018 Hi All new to the forums but in need of some help, I have a mk7 2016 golf r in manual, and its just thrown a conrod through the engine block so it now has a tennis ball sized hole in it, (went with a very large bang) the car hasn't been mapped or modified in any way, its done 39k has this happed to any one else? also its two months out of warranty. why has this happened Which country are you in?UK cars come with 3 year warranty which would mean if you are UK based it’s covered until 2019. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Blobby Posted August 21, 2018 Author Report Share Posted August 21, 2018 UK car was first registered 29/04/2015 Quote Link to comment Share on other sites More sharing options...
Pinky1959 Posted August 21, 2018 Report Share Posted August 21, 2018 If you have a full VW service record you should get in touch with VW and request some goodwill or a new engine as this should not happen, Go to your dealer and see what they suggest.. Good luck...... camelsac2002 1 Quote Link to comment Share on other sites More sharing options...
Blobby Posted August 21, 2018 Author Report Share Posted August 21, 2018 SO it does have a full VW service it came up with a oil change needed at 39500 so took it in but not to VW but a garage that uses VW genuine parts, oil change was done no issues till yesterday. its just a few miles within its 40k service How much do "goodwill Offer is there a VW rule of thumb used. I wouldn't of minded so much if it was turbo/injectors but a major engine failure no. Quote Link to comment Share on other sites More sharing options...
JRock_247 Posted August 21, 2018 Report Share Posted August 21, 2018 VW will most likely want proof that the parts used were OEM VW parts. Make sure you get the receipt and proof from the garage you used to do the Oil service, otherwise VW will argue and most likely not offer goodwill. Get all the proof you have before going to VW for a goodwill gesture. Mike R and GGSL 1 1 Quote Link to comment Share on other sites More sharing options...
GGSL Posted August 21, 2018 Report Share Posted August 21, 2018 28 minutes ago, Blobby said: SO it does have a full VW service it came up with a oil change needed at 39500 so took it in but not to VW but a garage that uses VW genuine parts, oil change was done no issues till yesterday. its just a few miles within its 40k service How much do "goodwill Offer is there a VW rule of thumb used. I wouldn't of minded so much if it was turbo/injectors but a major engine failure no. I think it's fairly common, especially with major engine failure. They'll definitely go over it with a fine tooth comb, just making sure it's never been modified etc. Also one to look out for with manuals is that it's never been shifted into too low a gear causing the engine to go over max rpm - if it's ever happened the ECU will have a very detailed record of it. Quote Link to comment Share on other sites More sharing options...
Blobby Posted August 21, 2018 Author Report Share Posted August 21, 2018 I remember once putting into third not fourth from 6th it was very late in the night so wasn't with it, but I tried to put my VW van into second and first and you cant actually get the gear to select, its pretty poor at 40k with engine failure especially seen as there are other hot hatches running more BHP, supposing I had done a wrong gear change it was at least 6000 miles ago and supposing this may have caused some damage ie cracked con rod would it of lasted 6000 miles,? I think not. Quote Link to comment Share on other sites More sharing options...
golf7.5r Posted August 21, 2018 Report Share Posted August 21, 2018 If you over-rev the engine (ecu will of logged this, so you could check with vcds before you hand it over to VW to save time and effort) it will most likely bend the valves not the conrod. You may not notice this at first but it could lead to lack of compression and/or bore wear, which may ultimately lead to total engine failure. Did you not hear anything unusual before the engine went i.e. knocking, metallic noises? Did you check your oil level? Do you warm the engine up correctly from cold? For the less experienced drivers out there, the rev limiter built into the car when you accelerate will NOT protect the engine from exceeding max revs if you change down into too low a gear, so you could easily hit 8k rpm (or more), which is not good for the engine as the hydraulic lifters can't keep up at that rpm (which is why race engines use solid lifters). HTH Raiden 1 Quote Link to comment Share on other sites More sharing options...
Blobby Posted August 21, 2018 Author Report Share Posted August 21, 2018 Yes car gets warmed up before its driven hard and I am sure I have read that VW had put something internal on the ECU that doesn't allow all the power until its warm,(but don't quote me on that) and its not really driven hard who can these days without a white van parked at the side of the road clocking your speed all the time. there defiantly hasn't been any noises from the engine. me and the partner drive most of the time without the radio on as we enjoy the noise sad I know. I do understand what your saying but doing this once in 40k kills the engine? surely they are designed with enough brut to take a change down from say 5-3rd. or even 6th to third, as you can drive these in 6th at 30-40mph with ease. Quote Link to comment Share on other sites More sharing options...
Mike R Posted August 21, 2018 Report Share Posted August 21, 2018 I have read on here fairly recently a couple of posts from other people that have had engine failures,id do a search & see if you can find the posts,there has been some on the facebook page as well. Quote Link to comment Share on other sites More sharing options...
jds Posted August 21, 2018 Report Share Posted August 21, 2018 The reason a Conrod comes through the side of the block is because the bearing has totally failed. This is due to no oil pressure, or no, or very little oil in the sump, conrods don’t “just” come off. I would say that there should have been some early indications that this was about to happen, , oil light comes on, definitely a loud knocking and vibration. The inspection to find the cause will be relatively easy, have you checked the oil level, there should still be some in the sump, is there a smell of something getting very hot, even though the engine is now scrap this odour will still be present. Remove the oil filler cap, is there a white residue on the underside of the cap, this would indicate water/oil contamination. Obviously further inspection would be needed to find out what actually failed, ie, bearings, or oil pump etc.. Be warned,, that VW will scrutinise every detail, oil filter brand, etc, to find away of not paying out. All the best anyway, hope you’ve got deep pockets.😩 Quote Link to comment Share on other sites More sharing options...
Blobby Posted August 21, 2018 Author Report Share Posted August 21, 2018 No oil light. Even more worrying that when it was parked at the side of the road with the entire contents on the floor there was still no warning lamp, although a couple of weeks previously I had a oil top up light so I did top up and checked thoroughly, I did check the dipstick but there was no oil on it as it was all under the car. I didn't check the filler wish I had of done though, there was no smell of burning, the only thing I found was chunks of the engine block at the back under the turbo. wouldn't all of what you had said of brought on a dashboard light? all that happened was a loud bang followed by the car saying there was no- acc/loss of tyre pressure/no stop start available that's it, turned the engine off almost straight away. Quote Link to comment Share on other sites More sharing options...
brad7.5REST Posted August 21, 2018 Report Share Posted August 21, 2018 Hi All new to the forums but in need of some help, I have a mk7 2016 golf r in manual, and its just thrown a conrod through the engine block so it now has a tennis ball sized hole in it, (went with a very large bang) the car hasn't been mapped or modified in any way, its done 39k has this happed to any one else? also its two months out of warranty. why has this happened Sorry to hear about this mate... Good luck!Sent from my Lenovo YT-X703L using Tapatalk Quote Link to comment Share on other sites More sharing options...
Sequence Posted August 21, 2018 Report Share Posted August 21, 2018 This is not the first i have seen recently as mentioned, i hope you get this sorted 😕 Quote Link to comment Share on other sites More sharing options...
