scott-o Posted November 28, 2019 Report Share Posted November 28, 2019 Morning, I was getting ABS faults on the rear left intermittently (which knocked a whole load of other modules out), i replaced the sensor and the faults cleared for 4 days and then after id been driving enthusiastically it sounded like there was a wheel bearing noise from the rear and thinking back i'd been hearing this noise on and off for a few weeks. I got the car up in the air and check the diff oil, nothing came out, massive alarm bells along with all the fault lights coming back as i was pulling the car into the garage. I put around 900ml in and it still didnt reach the fill hole some how, which rang further alarm bells. There was no noises and all was well for around 10 miles and then bad noises started to occur which i knew was definitely the diff. I got the car into my mates garage and no oil came out of the diff when the drain plug was removed and 0 signs of any leaks. The oscilloscope waves for the senor were reading correctly so we knew the sensor wasnt at fault and neither was the reluctor ring on the wheel bearing. I decided to bite the bullet and buy a second hand diff (facelift diff from a 2018 car, revision J) and the haldex pump and ecu were swapped over from my previous diff as we knew the history of those and that they were good. God news is its all swapped over and working better than ever but we decided to strip the old diff to figure out where the oil was going and what sort of damage we could see. Pictures below, enjoy! We got the cups out and the oil flowed out: IMG_20191127_190551 by Scott Osborne, on Flickr The reason the oil wasnt draining out, blocked solid with sludge! IMG_20191127_191623 by Scott Osborne, on Flickr The diff: IMG_20191127_190909 by Scott Osborne, on Flickr Pinion Side: IMG_20191127_190849 by Scott Osborne, on Flickr Now it really doesnt seem like this is a common thing to occur and all the techs i've spoken to havent ever heard of it happening and bearing in mind the diff units are supposed to be 'sealed for life' from VW i.e. dont require the diff oil changing, it looks like a quality fault in the diff. It looks like the crown wheel on the diff just hasnt been treated properly (or at all) and its just ground itself away to the stage where the teeth have broken away completely, which is when i started getting the abs sensor faults as these were skipping over. Has anyone else seen something similar occur? Cheers, Scott slickrick30 and Booth11 2 Quote Link to comment Share on other sites More sharing options...
Norm4n Posted November 28, 2019 Report Share Posted November 28, 2019 Wow, just out of interest have you owned the car from new and if so how has it been used i.e. launches, doughnuts, drift etc? Quote Link to comment Share on other sites More sharing options...
scott-o Posted November 28, 2019 Author Report Share Posted November 28, 2019 4 minutes ago, Norm4n said: Wow, just out of interest have you owned the car from new and if so how has it been used i.e. launches, doughnuts, drift etc? Bought second hand (I'm the third owner) and I've got all the mechanical sympathy in the world but that can never be said for certain for the previous owners as I don't know them, although the car itself is great condition and definitely been looked after by them. You can tell from the crown wheel on the diff it's just ground down over time though and points to it being defective, nothing to do with any mistreatment etc. There's no heat discoloration and all bearings etc were solid enough and not defective. When diffs go due to launches etc they tend to be catastrophic and in big Lumps rather than a thick metal paste, this has been happening for a long time and the car did still drive believe it or not! Quote Link to comment Share on other sites More sharing options...
Norm4n Posted November 28, 2019 Report Share Posted November 28, 2019 Strange how it's worn in one area, maybe a tooth broke and over a long period of time it has put stress on those adjacent Quote Link to comment Share on other sites More sharing options...
scott-o Posted November 28, 2019 Author Report Share Posted November 28, 2019 1 hour ago, Norm4n said: Strange how it's worn in one area, maybe a tooth broke and over a long period of time it has put stress on those adjacent It's worn all the teeth if you zoom in, then they've started to break off as they've got too thin. No doubt the rest were shortly to follow, about half were fully gone. Quote Link to comment Share on other sites More sharing options...
Indium Posted November 28, 2019 Report Share Posted November 28, 2019 I'd be very tempted to send it to VW UK for their opinion on the cause. Would be interesting to see what they say. NRW, dougaberdeen and Booth11 2 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted November 28, 2019 Report Share Posted November 28, 2019 13 minutes ago, Indium said: I'd be very tempted to send it to VW UK for their opinion on the cause. Would be interesting to see what they say. I would too. Be very interested in what response they come up with. Quote Link to comment Share on other sites More sharing options...
goodbadboy Posted November 29, 2019 Report Share Posted November 29, 2019 9 hours ago, Booth11 said: I would too. Be very interested in what response they come up with. What Rebecca and Indium said.... Shug 1 Quote Link to comment Share on other sites More sharing options...
scott-o Posted November 29, 2019 Author Report Share Posted November 29, 2019 How would i go about doing that? I was going to email them with pictures just for their info but i've always found VW useless with correspondence and the like! I've scrapped the casings and haldex transfer side and just kept the diff as a memento (the bit thats actually failed i guess) Quote Link to comment Share on other sites More sharing options...
Maplesyrup Posted November 29, 2019 Report Share Posted November 29, 2019 I can’t imagine that VW would be at all interested in looking at any failed component that’s out of warranty, you’d probably need to pay them for their time to inspect it 🙄 Quote Link to comment Share on other sites More sharing options...
scott-o Posted November 29, 2019 Author Report Share Posted November 29, 2019 45 minutes ago, Maplesyrup said: I can’t imagine that VW would be at all interested in looking at any failed component that’s out of warranty, you’d probably need to pay them for their time to inspect it 🙄 Well they are my thoughts as well, i cant imagine they could care less. I've emailed them anyway with pictures etc. but again feel its a waste of time and i dont think its likely ill get any response. Quote Link to comment Share on other sites More sharing options...
EcosseGolfR Posted November 29, 2019 Report Share Posted November 29, 2019 I believe the rear diff oil change is not part of VW’s service schedule, I priced it yesterday from an independent garage, £95 so I’ll probably have it done in the new year. Quote Link to comment Share on other sites More sharing options...
scott-o Posted November 29, 2019 Author Report Share Posted November 29, 2019 1 hour ago, EcosseGolfR said: I believe the rear diff oil change is not part of VW’s service schedule, I priced it yesterday from an independent garage, £95 so I’ll probably have it done in the new year. Good idea and the front one can be changed too. I'll be getting mine done next time it's in. Seems quite expensive for your quote though? Haldex service at my indy is £90 Inc taking the pump out and doing the filter. The haldex fluid is about 2.5x the price of the gear oil. Quote Link to comment Share on other sites More sharing options...
EcosseGolfR Posted November 29, 2019 Report Share Posted November 29, 2019 Yeah I think the haldex was £120 with pump removed and cleaned, so the rear diff at £95 was expected. Things are expensive up here Aberdeen unfortunately. Quote Link to comment Share on other sites More sharing options...
scott-o Posted November 29, 2019 Author Report Share Posted November 29, 2019 32 minutes ago, EcosseGolfR said: Yeah I think the haldex was £120 with pump removed and cleaned, so the rear diff at £95 was expected. Things are expensive up here Aberdeen unfortunately. That's fair, I did think after I asked that you might be somewhere more expensive than where I am (the north east, nice and cheap haha) Quote Link to comment Share on other sites More sharing options...
