Guy Incognito
2 minutes ago, SpursMadDave said:
Different (newer) mib units, not sure if it's possible to update the software if you are on the older format
Hi mate, thanks for the reply
My unit looks exactly like bottom picture though?
Edited by trancem
Hi guys.. i have another quick question.. i reckon I will be using this thread quite alot as I get to grips with R ownership.. hope you don't mind.
I've tried searching but couldn't find posts related to the actual "issue" I have
In Individual mode... when changing the Engine Sound settings.... Eco/Comfort/Normal/Race all seem to sound exactly the same? i.e. On. Whatever setting I select it sounds the same as when in Race mode? The soundaktor is definitely working as if I change to Eco the cabin noise quietens down.
Am I doing something wrong?
  • 2 weeks later...
Hi peeps,
I know some service there R's beyond the manufactures required advice and can be subjective, but after how many miles should a major service be required on a 7.5R?
And is the Haldex service considered to be part of a major service or is is separate?
Reason i ask is when i bought it, i got the two year services plan and was told the intervals were 1 year or 10k miles.
Its now 2 months away form being 3 years old and has 27.5k on the clock, and the display is telling me it needs an Oil service only.
However, VW have booked me in for a major service and i'm not sure that's correct going by the car display and a couple of links i found online:
https://www.shopdap.com/blog/post/service-schedule-for-mk7-5-golf-r-2018-2019.html
Although Incape say a major years for an R: https://www.inchcape.co.uk/volkswagen/service-and-repair/fixed-price-servicing/#:~:text=The recommended service interval is,miles (whichever comes first).&text=A major service ensures your,miles (whichever comes first).
Advice appreciated please.
20 minutes ago, Ernie McCracken said:
Hi peeps,
My 2017 MK7.5 Estate recently had its 3rd year Service at VW Nuneaton, the car was on 24k miles.
i paid about £220 which included some bits and pieces that needed sorting.
admittedly mine goes back this year.
7 minutes ago, Ernie McCracken said:
£220 would suggest a minor service i'm guessing.
I'm wondering if all i need is a minor service, and as i plan on keeping the car for at least another 2 years, i should get the Haldex changed too?
Sort of a half way house.
i had pollen filter replaced as well.
They also carried out an end of warranty check (moved to extended) to capture any issues or concerns I had.
this makes it easier if anything crops up its been noted before.
if keeping the car, I would get Haldex done etc, preventative maintenance is always best approach.
either go recommended Indie, or use a VW dealer that price matches, get an indie quote and then have dealer do the work.
Make sure you have a list of any concerns etc to get covered while still under warranty.
1 hour ago, Ernie McCracken said:
Hi peeps,
As a guide....
I originally had a 3 year Service Plan (on mk7, now finished) and my 3rd service detailed on the plan was a Major service - oil service and inspection service with extended scope.  Plus Brake fluid change as that’s due at 3 years (then every 2 years after).  And dust and pollen filter.  And vehicle health check.  Below is what was detailed on mine for year 3.
Haldex is due at 3 years too but is separate costed item to a Major service.  Best to try and get the filter cleaned as well as the oil change, the latter being only what is the standard Haldex service but it’s well known that the filter gets blocked. Check out the Filthiest Haldex...thread on the forum. Some main dealerships will do this but many don’t, but an indie can quote you for it if your dealership won’t clean the filter.
If you’re keeping the car I’d be going for a Major Service at 3 years as the original factory warranty is ending.  I’d also think about getting and Extended Warranty.
