Booth11 Posted August 9, 2019 Report Share Posted August 9, 2019 5 hours ago, SpursMadDave said: I know it is to reduce the overall emissions and to boost the mpg figures but I still can't understand a car like this having an eco mode and the ability to coast Sent from my SM-G950F using Tapatalk I suppose they have to include it, but we can ignore it! In four years I’ve still only intentionally used it once out of curiosity, and a couple times by accident, and with the latter, at the first roundabout I thought the car had died! Shug 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted August 9, 2019 Report Share Posted August 9, 2019 I suppose they have to include it, but we can ignore it! In four years I’ve still only intentionally used it once out of curiosity, and a couple times by accident, and with the latter, at the first roundabout I thought the car had died! Yep all the miles I have done, even 600 motorway miles in the last 48hrs I haven't coasted once! #idontdriveamilkfloat Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
FrustratedGolfer Posted August 14, 2019 Report Share Posted August 14, 2019 On 08/08/2019 at 02:51, gregozedobe said: I wonder if it is because the R's poor turning circle means Park Assist can't work properly ? Only poor with huge 20 inch wheels. Great with standard size. Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted August 15, 2019 Report Share Posted August 15, 2019 8 hours ago, FrustratedGolfer said: Only poor with huge 20 inch wheels. Great with standard size. Mine (with OEM 19" wheels) is considerably less than "great", and I know quite a few other R owners share that opinion. My R has a much larger turning circle than my Octavia (with OEM 225/40R18 wheels) Quote Link to comment Share on other sites More sharing options...
Dollyman Posted August 15, 2019 Report Share Posted August 15, 2019 I may be wrong but I recall reading somewhere that the 18” are ok but there is an extra stop fitted for anything above this which restricts wheel travel I’ve got bog standard Cadiz and the turning circle doesn’t seem any worse than my previous mini Quote Link to comment Share on other sites More sharing options...
ptraynor1 Posted August 15, 2019 Report Share Posted August 15, 2019 Thanks for the cable junction box / cable-ties tip. I have just done mine. Since this weakness has been known for a long time I reckon VW should have fixed it long ago or at the first service it should be done routinely. I am getting a little disillusioned with the brand. Did you locate decent eyelids for your 7.5? Looking for some quality ones. Thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
dopper99 Posted August 16, 2019 Report Share Posted August 16, 2019 On 15/08/2019 at 09:29, Dollyman said: I may be wrong but I recall reading somewhere that the 18” are ok but there is an extra stop fitted for anything above this which restricts wheel travel I’ve got bog standard Cadiz and the turning circle doesn’t seem any worse than my previous mini I yes, I think this is the case. I'm sure I read on here there was a guy who had an R that came with 18's and he said it had a good turning circle. Then he fitted 19's and the turning still was still good, no different. (I think he'd driven or owned an R with 19's previously, so knows what a car with 19's is like) So its nothing to do with the wheels themselves but the fact that there does seem to be mechanical differences (eg extra stops fitted) between cars that are fitted with 18's vs 19's. Would be interesting to understand why these stops are needed with 19's? Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted August 16, 2019 Report Share Posted August 16, 2019 My previous R had 19" prets from factory and suffered from the huge turning circle, my current one came with 18" cadiz and was fine and now with 19"s on it is still absolutely fine so not sure what they do at the factory that is so important? Sent from my SM-G950F using Tapatalk dopper99 1 Quote Link to comment Share on other sites More sharing options...
dopper99 Posted August 16, 2019 Report Share Posted August 16, 2019 This the difference between 18's and 19's with regards the diameter, width etc.... So 19's are nearly half an inch width and nearly half an inch larger in diameter. Yet this fairly small difference and made VW to decide to alter the car fitted with 19's in such a way that makes it have such a NOTICEABLE difference in turning circle. Strange. rRRRM 1 Quote Link to comment Share on other sites More sharing options...
rRRRM Posted August 17, 2019 Report Share Posted August 17, 2019 Yesterday I saw another R with a 10cmX10cm square cut-out in the griile, below the VW badge. About 2cm in was a flatsquare black thing about 2cm thick. Any idea what it is all about? Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted August 17, 2019 Report Share Posted August 17, 2019 1 hour ago, rRRRM said: Yesterday I saw another R with a 10cmX10cm square cut-out in the griile, below the VW badge. About 2cm in was a flatsquare black thing about 2cm thick. Any idea what it is all about? That would have been the front radar sensor for ACC on a Mk7, the Mk7.5 re-located it to behind the VW badge (that's why the Mk7.5 VW badge looks different). Quote Link to comment Share on other sites More sharing options...
Shug Posted August 17, 2019 Report Share Posted August 17, 2019 15 hours ago, dopper99 said: This the difference between 18's and 19's with regards the diameter, width etc.... So 19's are nearly half an inch width and nearly half an inch larger in diameter. Yet this fairly small difference and made VW to decide to alter the car fitted with 19's in such a way that makes it have such a NOTICEABLE difference in turning circle. Strange. Plenty of women would be quite happy with an increase of half an inch in diameter 😁 (Guess mods to move this to after dark thread now?) Quote Link to comment Share on other sites More sharing options...
Dollyman Posted September 6, 2019 Report Share Posted September 6, 2019 Pedal boxInsurance company happy but are there any implications regarding warranty and the car is on a PCHSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 6, 2019 Report Share Posted September 6, 2019 3 hours ago, Dollyman said: Pedal box Insurance company happy but are there any implications regarding warranty and the car is on a PCH Sent from my iPhone using Tapatalk There’s a warranty risk with any modification but I’d say it’s a low risk with a pedal box. They’d have to evidence that any fault was caused by it, or it contributed to it, though of course, we all are aware that some dealerships (not all) might try and pin the blame on an added component even if nothing to do with the fault or failure presented. For me personally it’s worth the risk. The upside is that, barring an immediate emergency occurrence, if you get a fault or issue, and the car has to go in to the garage to be looked at, a pedal box is so quick to remove from the car, you’ve every chance of being able to remove it before the car needs looking at. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 6, 2019 Report Share Posted September 6, 2019 Pedal boxInsurance company happy but are there any implications regarding warranty and the car is on a PCHSent from my iPhone using Tapatalk5 minute job max to remove, I have mine fitted and the controller in the cubby, I don't take it off when it goes in to VW, maybe i would if there was an issue with the pedal itselfSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
