SpursMadDave Posted August 1, 2019 Report Share Posted August 1, 2019 Mine don't bend, the green lines stay straight all the time, my previous MINIs used to bend. The R also shows a graphic , to one side of the screen,of a car with yellow shaded areas that bend when you move the steering, I haven't got a clue what this is supposed to do, any help welcomed.There is apparently a dynamic rear camera with lines that bend, maybe for the better models like tiguan etc not sure if that can be retrofitted Sent from my SM-G950F using Tapatalk Kevmoz 1 Quote Link to comment Share on other sites More sharing options...
Shug Posted August 1, 2019 Report Share Posted August 1, 2019 1 hour ago, Kevmoz said: I’ve had a search but cant find the answer to this one. I have had the reverse camera retro fitted to my Golf and just wonder, if you had a factory fitted one, when you reverse and the picture with the lines comes up, do the lines bend when you turn the steering wheel or remain straight? Mine stay straight but on the wife’s Evoque they bend to show where the car is heading. Many thanks for any help. Nope, VW cost cutting again. My 2009 Lexus had lines that bent, indicating where the car would end up, but not the 2017 R. Kevmoz 1 Quote Link to comment Share on other sites More sharing options...
Martin2 Posted August 3, 2019 Report Share Posted August 3, 2019 Not very helpful I know, but kind of on topic.... My BMW has lines that move on both front and rear cameras and after having it for a year, I’ve just noticed that the cameras also move left-right when you turn the steering wheel! Probably didn’t notice because it’s got the 360 surround cameras, what a fantastic bit of kit that is. Kevmoz 1 Quote Link to comment Share on other sites More sharing options...
rRRRM Posted August 4, 2019 Report Share Posted August 4, 2019 18 hours ago, Martin2 said: Not very helpful I know, but kind of on topic.... My BMW has lines that move on both front and rear cameras and after having it for a year, I’ve just noticed that the cameras also move left-right when you turn the steering wheel! Probably didn’t notice because it’s got the 360 surround cameras, what a fantastic bit of kit that is. Sounds great, especially (as the cams "look around") they may be narrow angle views and avoid the usual optical distortion. Quote Link to comment Share on other sites More sharing options...
Martin2 Posted August 4, 2019 Report Share Posted August 4, 2019 16 hours ago, rRRRM said: Sounds great, especially (as the cams "look around") they may be narrow angle views and avoid the usual optical distortion. The front and rear cameras can also be put into 180 degree mode which is great for pulling out of blind junctions or reversing out of spaces. In the lakes at the moment and the overhead surround cameras are essential on the narrow lanes and stone walls. Should have brought the Golf, but needed the extra space and the 8 or so round trip motorway miles are much better done mine. Quote Link to comment Share on other sites More sharing options...
rRRRM Posted August 5, 2019 Report Share Posted August 5, 2019 On 03/08/2019 at 16:42, Martin2 said: Not very helpful I know, but kind of on topic.... My BMW has lines that move on both front and rear cameras and after having it for a year, I’ve just noticed that the cameras also move left-right when you turn the steering wheel! Probably didn’t notice because it’s got the 360 surround cameras, what a fantastic bit of kit that is. What model BMW? I'd like to investigate how it is done. Quote Link to comment Share on other sites More sharing options...
Martin2 Posted August 6, 2019 Report Share Posted August 6, 2019 9 hours ago, rRRRM said: What model BMW? I'd like to investigate how it is done. G11 750i Quote Link to comment Share on other sites More sharing options...
FrustratedGolfer Posted August 7, 2019 Report Share Posted August 7, 2019 On 01/08/2019 at 20:51, Dollyman said: Mine don't bend, the green lines stay straight all the time, my previous MINIs used to bend. The R also shows a graphic , to one side of the screen,of a car with yellow shaded areas that bend when you move the steering, I haven't got a clue what this is supposed to do, any help welcomed. From searches, it seems that there are lowline (straight lines) and highline (bending lines) versions. Mine (July 2017 - 7.5) has factory fitted non-bending lines. However, the manual for my car shows bending lines. VW said that is because the manual is generic, and those are only on cars that have park assist where the car does the steering for you. I believe the side graphic is supposed to indicate to you that this will be the area swept by your car if it reverses with the steering wheel at the current angle. I previously had a Volvo, which had bending lines on the rear view camera image, but they did not match completely with the track taken so they weren't actually helpful either. The factory fitted camera also has a red line at the bottom of the image, and if you stop on that line you'll be a foot or two away from the kerb you are reversing up to. It is like the warning buzzers that go solid when you are still a couple of feet away from a wall. People are scared that this sound means they have touched something. Hence cars hanging out over the front of car park bays. Quote Link to comment Share on other sites More sharing options...
Dollyman Posted August 7, 2019 Report Share Posted August 7, 2019 Any idea why the R doesn't have the option of Park Assist like all other Golfs? Other VW AWD cars such as the Toureg have it as an option. Quote Link to comment Share on other sites More sharing options...
Gavras Posted August 7, 2019 Report Share Posted August 7, 2019 27 minutes ago, Dollyman said: Any idea why the R doesn't have the option of Park Assist like all other Golfs? Other VW AWD cars such as the Toureg have it as an option. Erm people buying the Golf R can drive and don't need help to park a rather small hatchback / estate? something like that possibly gregozedobe, Booth11, Ted Striker and 1 other 2 2 Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted August 8, 2019 Report Share Posted August 8, 2019 4 hours ago, Dollyman said: Any idea why the R doesn't have the option of Park Assist like all other Golfs? Other VW AWD cars such as the Toureg have it as an option. I wonder if it is because the R's poor turning circle means Park Assist can't work properly ? Quote Link to comment Share on other sites More sharing options...
Dollyman Posted August 8, 2019 Report Share Posted August 8, 2019 I had it on both my previous Minis for four years and I think I used it once out of curiosity i was was just wondering why as I’ve never seen a technical explanation as why it’s available on Golfs including GTI but not the R. Quote Link to comment Share on other sites More sharing options...
Martin2 Posted August 8, 2019 Report Share Posted August 8, 2019 I’ve got in on the 7 series and used it once just to see how good it was. It is good, but with overhead cameras and 360 degree sensors it’s quicker and easier to park it yourself. Not a pointless feature though seeing how much of a mess some people make of parking and all the cars with kerb rash. Quote Link to comment Share on other sites More sharing options...
NRW Posted August 8, 2019 Report Share Posted August 8, 2019 50 minutes ago, Martin2 said: Not a pointless feature though seeing how much of a mess some people make of parking and all the cars with kerb rash. Maybe This is why VW decline to give Electronic Parking on an R....they don’t want yet More grumbles about kerbed Alloys when they already get enough from Cadiz with alloy worm and bendy Pretorias.🤔 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted August 9, 2019 Report Share Posted August 9, 2019 Erm people buying the Golf R can drive and don't need help to park a rather small hatchback / estate? something like that possibly I know it is to reduce the overall emissions and to boost the mpg figures but I still can't understand a car like this having an eco mode and the ability to coast Sent from my SM-G950F using Tapatalk Gavras 1 Quote Link to comment Share on other sites More sharing options...
