Gavras Posted May 27, 2019 Report Share Posted May 27, 2019 On 23/05/2019 at 14:21, Raiden said: What's everyone paying for a minor service? My indie is coming out more expensive than main dealer and they can't work out how VW can do it for £179 Mine pretty much the same, admittedly as they were the supplying dealership, I get discount on servicing and parts. Quote Link to comment Share on other sites More sharing options...
Raiden Posted May 27, 2019 Report Share Posted May 27, 2019 The owner came back to me and they are going to do for £150. He said looking on the VW website there minor service isn't as in-depth as there's but if I clean and sort out the panel filter I have already in the car then they can do it a bit cheaper. I'd rather use them as they did a good job looking after my S3 8P in the pastSent from my Pixel 2 XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
rRRRM Posted May 28, 2019 Report Share Posted May 28, 2019 On 27/05/2019 at 05:53, Aidey said: Just a little tip that has helped me out and cured a problem that was driving me mad, my plastic pilars on the outside of the car made a horrible creaking noise, if you pushed them they creaked, so a bump in the road or bends made them creak, this was annoying, i sorted it by peeling the window rubber away from it, and spraying some lithium grease into the gap between the metal and plastic and rubber, no more creak at all.... 😁 Mention of rubber and grease rang bells with me so I googled and found " Silicone grease is safe on rubber and actually helps to keep it soft. Any other grease with a mineral oil base will degrade natural rubber. "White lithium grease" is a bit of a general term - unless you know its composition I would advise keeping it away from natural rubber. Obviously, oil resistant - CV joint boots are well coated in mineral grease on the inside." Is the "rubber" actually a polymer substitutes for rubber such as neoprene? How can you tell? Does anyone know? I googled but failed to find a definitive answer. Quote Link to comment Share on other sites More sharing options...
rRRRM Posted May 29, 2019 Report Share Posted May 29, 2019 6 months later & I'm still unable to find answers in the dopey Owner manual. In the digital dash instrument view called "Efficiency", the speedo centre graphic shows a car with blue bars on white arcs either side. The blue bars move down if accelerating, up if coasting and way up if braking. They stay in sync at all times even if cornering. The graphic is not intuitive to me. If it is supposed to tell me how I'm driving it seems a superfluous distraction. Quote Link to comment Share on other sites More sharing options...
Ali19 Posted May 31, 2019 Report Share Posted May 31, 2019 Hoping someone could post a pic of the rear disc and pad with wheel on a 7.5 R I have come in this morning and something looks different.👀 Quote Link to comment Share on other sites More sharing options...
rRRRM Posted June 3, 2019 Report Share Posted June 3, 2019 To access the front fins on the intercooler or oil cooler, can the piano-black trims be simply pulled out from the front of the bumper without damage? Any tips appreciated. Quote Link to comment Share on other sites More sharing options...
R-Estate Posted June 3, 2019 Report Share Posted June 3, 2019 To access the front fins on the intercooler or oil cooler, can the piano-black trims be simply pulled out from the front of the bumper without damage? Any tips appreciated. Doubt it as it’s a bumper off job to replace them.Sent from my iPhone using Tapatalk rRRRM 1 Quote Link to comment Share on other sites More sharing options...
Ted Striker Posted June 3, 2019 Report Share Posted June 3, 2019 Has anyone noticed Waze on CarPlay is showing speed now? I’ve got a loan Polo GTI which has the speed showing in Waze, my R, when given to dealer for warranty work (more soon on that thread!) disgrace have it.Seems the speed maybe a little out though. A speedo 83 used to give me 77 GPS, this polo seems a little slower i.e. 80 to give 77 GPS; will need to check with 3rd device. Some chat on reddit about this tooSorry if mentioned elsewhere. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted June 3, 2019 Report Share Posted June 3, 2019 Has anyone noticed Waze on CarPlay is showing speed now? I’ve got a loan Polo GTI which has the speed showing in Waze, my R, when given to dealer for warranty work (more soon on that thread!) disgrace have it.Seems the speed maybe a little out though. A speedo 83 used to give me 77 GPS, this polo seems a little slower i.e. 80 to give 77 GPS; will need to check with 3rd device. Some chat on reddit about this tooSorry if mentioned elsewhere. Sent from my iPhone using TapatalkGoogleMaps is getting the same very soon too apparently Sent from my SM-G950F using Tapatalk Ted Striker 1 Quote Link to comment Share on other sites More sharing options...
1nfinite Posted June 3, 2019 Report Share Posted June 3, 2019 Checked my dip stick a week after service an the oil is pretty black. Anyone else had this? Was from an offical dealer. Quote Link to comment Share on other sites More sharing options...
rRRRM Posted June 3, 2019 Report Share Posted June 3, 2019 15 hours ago, R-Estate said: Doubt it as it’s a bumper off job to replace them. Sent from my iPhone using Tapatalk Thanks. Yes, I have finally found (on a workshop manual) that for the "R" the bumper cover has to come off. For some other models, removal from the front is possible. I reckon it should be a simple thing for all cars to enable removal of bugs, small birds etc. Ditto the plenum chamber by the base of the windscreen. Quote Link to comment Share on other sites More sharing options...
Charles M Posted June 4, 2019 Report Share Posted June 4, 2019 When I have audio in my digital display and the phone rings, is there anyway to get audio to show up again, as it changes the display to phone? 1st World problem, I know, but.... Quote Link to comment Share on other sites More sharing options...
Ted Striker Posted June 17, 2019 Report Share Posted June 17, 2019 Read this somewhere about but can someone pls confirm the ‘welcome ‘driver’’ message isn’t triggered by differing keys but has to be done manually?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
AdeA Posted June 17, 2019 Report Share Posted June 17, 2019 Read this somewhere about but can someone pls confirm the ‘welcome ‘driver’’ message isn’t triggered by differing keys but has to be done manually?Sent from my iPhone using TapatalkI can confirm my key welcomes me and the wife's key welcomes her. I don't remember there being much to setting it up like that. Sent from my SM-G930F using Tapatalk Ted Striker 1 Quote Link to comment Share on other sites More sharing options...
Ted Striker Posted June 17, 2019 Report Share Posted June 17, 2019 I can confirm my key welcomes me and the wife's key welcomes her. I don't remember there being much to setting it up like that. Sent from my SM-G930F using TapatalkThanks, will have a look. Maybe even the manual. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
