Dollyman Posted March 29, 2019 Report Share Posted March 29, 2019 Stupid question and life's too short to read the manual How can you have the sat nav on without having the radio playing? Quote Link to comment Share on other sites More sharing options...
keano Posted March 29, 2019 Report Share Posted March 29, 2019 Bmw have a website called realoem.com that is a parts website for BMW’s minis etc. Drill down menus etc so you can find part numbers for all parts including accessories. Quick question: is there a VW equivalent website to search parts for my golf??Ta. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
GaryP Posted March 29, 2019 Report Share Posted March 29, 2019 Stupid question and life's too short to read the manual How can you have the sat nav on without having the radio playing?Tested this today. Just turn your radio volume down, the Nav instructions still play, they have a separate volume setting that you can adjust whilst the directions are actually being spoken or from the Announce menu item that you see on the Nav screen when you move your hands towards it.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dollyman Posted March 29, 2019 Report Share Posted March 29, 2019 21 minutes ago, GaryP said: Tested this today. Just turn your radio volume down, the Nav instructions still play, they have a separate volume setting that you can adjust whilst the directions are actually being spoken or from the Announce menu item that you see on the Nav screen when you move your hands towards it. Sent from my iPhone using Tapatalk Thanks Gary for your help. Quote Link to comment Share on other sites More sharing options...
Charles M Posted March 29, 2019 Report Share Posted March 29, 2019 Turn the radio all the way down, and the track on your SD card pauses. Quote Link to comment Share on other sites More sharing options...
Boothy Posted April 2, 2019 Report Share Posted April 2, 2019 Hi just a quickie; about Race Mode features being saved after turning the car off and on. Ive had a manual R for 2 years and going to swap to a DSG next week, loving the car.. However one thing I hate is after turning the car back on I have to swap the driver profile out of Race (into normal/eco) and then back into Race to re-open all 4 exhausts EVERYTIME I start up. Are there any other features to Race Mode which default to normal on start up? Or can this be fixed by coding all 4 exhaust flaps to open? Im basically in Race Mode 24/7 and ideally id like to select Race and not have to touch it again. Thanks, Dan Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted April 3, 2019 Report Share Posted April 3, 2019 2 hours ago, Boothy said: Are there any other features to Race Mode which default to normal on start up? Or can this be fixed by coding all 4 exhaust flaps to open? IIRC a few people have complained about needing to reselect S mode on the gearbox. Not sure about auto stop/start (suspect you have to disable it every time you switch on unless you have it coded out). Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 3, 2019 Report Share Posted April 3, 2019 Hi just a quickie; about Race Mode features being saved after turning the car off and on. Ive had a manual R for 2 years and going to swap to a DSG next week, loving the car.. However one thing I hate is after turning the car back on I have to swap the driver profile out of Race (into normal/eco) and then back into Race to re-open all 4 exhausts EVERYTIME I start up. Are there any other features to Race Mode which default to normal on start up? Or can this be fixed by coding all 4 exhaust flaps to open? Im basically in Race Mode 24/7 and ideally id like to select Race and not have to touch it again. Thanks, DanIs it a 7 or 7.5, if it's a 7 you can code the flaps to stay open permanently but not sure its possible with a 7.5Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted April 3, 2019 Report Share Posted April 3, 2019 9 hours ago, Boothy said: Are there any other features to Race Mode which default to normal on start up? Or can this be fixed by coding all 4 exhaust flaps to open? No, it’s only the gearbox which reverts to D as default each startup (so only 2 exhaust flaps). All other Race settings stay the same. Coding all 4 flaps to be open would get round the flaps issue and give you the better sound, but you’d still need to select S (via stick is quickest) to have the different shift points and higher revs. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 3, 2019 Report Share Posted April 3, 2019 Get everything set up in individual, or if you like race then fair enough. All you need to do when you get in the car is pull the selector back to change to S and you have what I think you want. I guess the car reverts to D mode for start up to reduce revs maybe from cold? I usually don't put it in to S until its warmed up at the revs shopt up pretty quickly to 4/5k as soon as the oil is warm enough then I stick it in to SSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Boothy Posted April 3, 2019 Report Share Posted April 3, 2019 Ok thanks all! thats perfect 👍 Quote Link to comment Share on other sites More sharing options...
JammyHamster Posted April 6, 2019 Report Share Posted April 6, 2019 (edited) On 22/03/2019 at 00:12, JammyHamster said: Can I copy a driver profile? I'm the proud new owner of 2017 7.5 DSG estate 😁 and set up a driver profile... I was thinking one setting for commuting and another for "fun". Is there any way to copy the 1st rather than starting again and having to retune/save all of my radio stations and replicate the other settings? I've found you can copy a profile. Set up the first one, store your radio stations, and customise the "individual" mode etc. Then main menu, car, settings, driver profile, there is a copy button. I set one up called Night that is identical to my usual setting but with the dashboard lighting etc set to 10% rather than 100%. As VW don't give you a brightness knob this is a lot safer than fiddling with head unit options while driving at night. Edited April 6, 2019 by JammyHamster Typo slider09 and rRRRM 1 1 Quote Link to comment Share on other sites More sharing options...
slider09 Posted April 6, 2019 Report Share Posted April 6, 2019 I've found you can copy a profile. Set up the first one, store your radio stations, and customise the "individual" mode etc. Then main menu, car, settings, driver profile, there is a copy button. I set one up called Night that is identical to my usual setting but with the dashboard lighting etc set to 10% rather than 100%. As VW don't give you a brightness knob this is a lot safer than fiddling with head unit options while driving at night.Good idea, one of my pet hates is the inability to dim the dashboard lights quickly and easily on both the mk7 / 7.5’sSent from my iPhone using Tapatalk JammyHamster 1 Quote Link to comment Share on other sites More sharing options...
GaryP Posted April 8, 2019 Report Share Posted April 8, 2019 What’s this on my Cadiz alloy? Is this Whiteworm I’ve heard people mention? There are quite a few spots of this on this wheel. None on the others. Can I do a warranty claim for it? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted April 8, 2019 Report Share Posted April 8, 2019 What’s this on my Cadiz alloy? Is this Whiteworm I’ve heard people mention? There are quite a few spots of this on this wheel. None on the others. Can I do a warranty claim for it? Sent from my iPhone using Tapatalk You can definitely try but stone chips can cause that so they may say it's not covered. It's a big disadvantage of diamond cut wheels unfortunately and it's expensive to fix, well more expensive than a standard alloy anywaySent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
