xSCYTHERx Posted February 3, 2019 Report Share Posted February 3, 2019 This might seem like a stupid question but what is the quickest way to launch a DSG off the line without using launch control? This is my first DSG car so trying to understand if simply flooring it is the quickest method or if there is a way of building the revs without using launch control (like you would in a manual) before setting off? Quote Link to comment Share on other sites More sharing options...
Hugh Posted February 3, 2019 Report Share Posted February 3, 2019 1 hour ago, xSCYTHERx said: This might seem like a stupid question but what is the quickest way to launch a DSG off the line without using launch control? This is my first DSG car so trying to understand if simply flooring it is the quickest method or if there is a way of building the revs without using launch control (like you would in a manual) before setting off? Not sure why you’d want to avoid launching if you’re looking for the fastest off the line? Quote Link to comment Share on other sites More sharing options...
Parky-SPP Posted February 3, 2019 Report Share Posted February 3, 2019 4 hours ago, xSCYTHERx said: This might seem like a stupid question but what is the quickest way to launch a DSG off the line without using launch control? This is my first DSG car so trying to understand if simply flooring it is the quickest method or if there is a way of building the revs without using launch control (like you would in a manual) before setting off? Select S and floor it. Shug and gregozedobe 2 Quote Link to comment Share on other sites More sharing options...
JagVwR Posted February 3, 2019 Report Share Posted February 3, 2019 (edited) 5 hours ago, xSCYTHERx said: This might seem like a stupid question but what is the quickest way to launch a DSG off the line without using launch control? This is my first DSG car so trying to understand if simply flooring it is the quickest method or if there is a way of building the revs without using launch control (like you would in a manual) before setting off? You can hold the foot brake down, build the revs up to your desired range, say 2500 - 3000rpm, let go and launch that way. The other way is to simply floor it with traction off from rest. However, leaving it in S mode won't build speed the quickest way. Better to use manual changes between 5500 and 6200rpm as the full auto S mode holds on to the revs too long, and in my opinion over revs it. The above method's work. Longevity of your clutch/drivetrain will be reduced as a consequence. So use sparingly. Edited February 3, 2019 by JagVwR Quote Link to comment Share on other sites More sharing options...
rRRRM Posted February 3, 2019 Report Share Posted February 3, 2019 On my 7.5 R, which is right-hand drive, in the body, close to the coolant bottle, close to the black plastic disc on which the bonnet stop rests there looks like there is clear plastic like a plastic bag crinkled up and stuffed in. It doesn't look like it belongs there. Has an assembler put their lunch bag there? As the car is only 7 weeks old and not due for a service I am not going to touch it until someone can tell me if it is correct. The corresponding place on the passenger side has black rubber. Quote Link to comment Share on other sites More sharing options...
Shug Posted February 4, 2019 Report Share Posted February 4, 2019 8 hours ago, rRRRM said: On my 7.5 R, which is right-hand drive, in the body, close to the coolant bottle, close to the black plastic disc on which the bonnet stop rests there looks like there is clear plastic like a plastic bag crinkled up and stuffed in. It doesn't look like it belongs there. Has an assembler put their lunch bag there? As the car is only 7 weeks old and not due for a service I am not going to touch it until someone can tell me if it is correct. The corresponding place on the passenger side has black rubber. Will pop out and have a look at mine when it stops raining, unless someone beats me to it with a reply.. rRRRM 1 Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted February 4, 2019 Report Share Posted February 4, 2019 11 hours ago, rRRRM said: On my 7.5 R, which is right-hand drive, in the body, close to the coolant bottle, close to the black plastic disc on which the bonnet stop rests there looks like there is clear plastic like a plastic bag crinkled up and stuffed in. It doesn't look like it belongs there. Has an assembler put their lunch bag there? As the car is only 7 weeks old and not due for a service I am not going to touch it until someone can tell me if it is correct. The corresponding place on the passenger side has black rubber. The rain has stopped here, so I popped down to my garage. No sign of a clear plastic bag anywhere near the coolant bottle on my RHD Mk7.5 R (or anywhere else in the engine compartment for that matter). rRRRM 1 Quote Link to comment Share on other sites More sharing options...
Shug Posted February 4, 2019 Report Share Posted February 4, 2019 16 minutes ago, gregozedobe said: The rain has stopped here, so I popped down to my garage. No sign of a clear plastic bag anywhere near the coolant bottle on my RHD Mk7.5 R (or anywhere else in the engine compartment for that matter). No plastic bag in mine either anywhere in engine bay. Pull it out you may may have found the mechanics drug stash 🤣 Photo below: Quote Link to comment Share on other sites More sharing options...
rRRRM Posted February 5, 2019 Report Share Posted February 5, 2019 16 hours ago, gregozedobe said: The rain has stopped here, so I popped down to my garage. No sign of a clear plastic bag anywhere near the coolant bottle on my RHD Mk7.5 R (or anywhere else in the engine compartment for that matter). Thanks greg and Shug. I should have included this photo. My wrist is over the coolant bottle and finger is pointing to under a bit of mudguard. There's a white painted bolt. Straight below it is a hole in the metalwork and the clear plastic is visible under that hole. There's a black cable in the way which makes it hard to pull the plastic out, and, depending on whether it is standard equipment feedback I might leave it as it is to show the service people. If I discover a drug stash and tell the authorities will I have uncovered a drug ring and get a reward? Quote Link to comment Share on other sites More sharing options...
blower Posted February 5, 2019 Report Share Posted February 5, 2019 1 hour ago, rRRRM said: Thanks greg and Shug. I should have included this photo. My wrist is over the coolant bottle and finger is pointing to under a bit of mudguard. There's a white painted bolt. Straight below it is a hole in the metalwork and the clear plastic is visible under that hole. There's a black cable in the way which makes it hard to pull the plastic out, and, depending on whether it is standard equipment feedback I might leave it as it is to show the service people. If I discover a drug stash and tell the authorities will I have uncovered a drug ring and get a reward? It's funny I see this question come up once a year on various forums....VW (and many car manufacturers) have been putting acoustic damping on the inner parts of wings and other cavity area's for years, some cover them in plastic bags like VW when they are in area's that could get wet. Inside the bag is a foam like material, it's purpose is to stop noise (beit from wind and/or panel resonance). Do not remove this. The engineer logic is that a cavity can resonate, so to stop that you fill it with something, foam is best, but foam can hold water and promote rusting - so put a bag around the foam Booth11 and gregozedobe 1 1 Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted February 5, 2019 Report Share Posted February 5, 2019 On 04/02/2019 at 22:15, Shug said: Photo below: Hmmm, after looking at both photos I feel a reminder is needed. VW's have a tendency for the junction box for the bonnet release cable to separate and leave you unable to open your bonnet. The fix is quick, easy and cheap, so get to it you slackers that haven't done it yet. No excuses will be accepted, and large doses of "I told you so" will be meted out ( with inordinate smug satisfaction) if you don't do it and your cable fails as described below ! Cdj3.2, Shane-Ireland, blower and 1 other 4 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted February 5, 2019 Report Share Posted February 5, 2019 Hmmm, after looking at both photos I feel a reminder is needed. VW's have a tendency for the junction box for the bonnet release cable to separate and leave you unable to open your bonnet. The fix is quick, easy and cheap, so get to it you slackers that haven't done it yet. No excuses will be accepted, and large doses of "I told you so" will be meted out ( with inordinate smug satisfaction) if you don't do it and your cable fails as described below ! I keep meaning to do this, thanks for the reminder Greg!Sent from my SM-G950F using Tapatalk gregozedobe 1 Quote Link to comment Share on other sites More sharing options...
Shug Posted February 5, 2019 Report Share Posted February 5, 2019 4 hours ago, gregozedobe said: Hmmm, after looking at both photos I feel a reminder is needed. VW's have a tendency for the junction box for the bonnet release cable to separate and leave you unable to open your bonnet. The fix is quick, easy and cheap, so get to it you slackers that haven't done it yet. No excuses will be accepted, and large doses of "I told you so" will be meted out ( with inordinate smug satisfaction) if you don't do it and your cable fails as described below ! Cheers i’ll sort some cable ties on it at the weekend Quote Link to comment Share on other sites More sharing options...
Shane-Ireland Posted February 5, 2019 Report Share Posted February 5, 2019 5 hours ago, gregozedobe said: Hmmm, after looking at both photos I feel a reminder is needed. VW's have a tendency for the junction box for the bonnet release cable to separate and leave you unable to open your bonnet. The fix is quick, easy and cheap, so get to it you slackers that haven't done it yet. No excuses will be accepted, and large doses of "I told you so" will be meted out ( with inordinate smug satisfaction) if you don't do it and your cable fails as described below ! Top tip - thanks Quote Link to comment Share on other sites More sharing options...
RyanB Posted February 5, 2019 Report Share Posted February 5, 2019 Anyone know where I can acquire some gloss black headlight eyebrows/eyelids for a 7.5? Found millions for the mk7 but apart from Ali express can’t find anything for the 7.5 and apparently the mk7’s won’t fit 🤔 cheers Quote Link to comment Share on other sites More sharing options...
