Guy Incognito
On 21/01/2019 at 15:56, FoxyTiger said:
Put it in D then actually drive off. After a few meters the mirror should go back into it’s normal position, without touching the mirror switch.
Perfect seems to work after about 5-10 meters or so!
Two more quick questions:
1. When you put the car into manual is there a way of turning off the proposed gear that you should be in from displaying in the instrument cluster? For example if I am in the right gear it shows a big 2 for example but if 2 is the wrong gear it would show "2 > 4".
2. When moving in slow traffic the front and rear parking sensors start working and come up as a screen inside the main screen that you can hide by hitting the X in the top right. Is there a way from stopping this from happening in normal driving? (Obviously when R has been engaged its needed).
1. Not sure
2. Mine does this too I don't think you can stop it, happens to me sometimes in traffic if it's slow, I guess it thinks you are trying to park...
51 minutes ago, Nugget said:
I just got my first service done and was told I need to top up my engine oil and coolant from time to time. Is this true? I've never owned a car that needed this.
Are you sure they said it needed to be topped up and not just checked regularly ?  I would suggest you should get in the habit of checking oil, coolant and tyre pressures regularly (maybe every second fill-up for fuel)
Some Golfs have a bit of air in the coolant system initially, and after a while it gets bled out so the level goes down slightly.  This is quite normal and nothing to worry about as long as it stops changing. However, there is a fairly common fault with the thermostat housing where it has a slow leak, causing the coolant level to go down and keep on going down.  This is  a fault and needs to be fixed (expensive if not covered by warranty).  If your coolant level continues to go down I suggest you get it looked at.
As far as oil usage, VW suggest that usage as high as 1 litre per 1,000km is acceptable.  I strongly disagree.  Some VWs do need oil added between oil changes, but none of mine have ever needed it.
My ‘Coming Home’ lights seem to have stopped working on my Mk7.5 Estate. They come on when I unlock the car and stay on for the time set in Car Settings.
When I lock the car, no lights at all, but the Digital Dash stays on for the Coming Home time as set in the settings.
Any ideas anyone?
