Guy Incognito
When I drive along, and need to do a quick 3 point turn, engaging reverse takes an awful long time (as well as giving a satisfying burble). Is it normal that the DSG take a second or two to go from D into R? Its quite annoying when you want to do a quick 3 point turn
My old M3 with a DCT 'box was the same, took a couple of seconds to engage reverse and can be very annoying at times. I reverse onto the drive and can end up holding up the traffic if they are belting towards me.
In contrast the ZF 8 speed in BMW goes into reverse pretty quick so it must be a dual clutch 'box issue.
I reverse on to my drive and yes a pause but it wouldn't say a second or two just feels like it I guess...
I just tried on my R (DQ381 7 speed) and the delay would have been around 0.5 second to start moving again (going from R to D and back to R).
While discussing the driver assist package, is there an easy way of disabling the overtaking on the left restriction. This is legal in Australia and the assist should not try to prevent it by slowing the car down. Also a problem when turning left into a slip lane with a slow car continuing straight.
AFAIK there is no way to do it via normal menu settings, but I think I've read somewhere that it can be switched off with coding software eg VCDS, OBDII etc
I have just experienced the avoid passing on the left programming this week, annoying but not insurmountable with a quick prod of the accelerator.
Be nice to find out how to get around it with VCDS!
OBDEleven has a very simple way to turn that off.
Can you post the instruction string please? I have VCDS so hopefully would be a able to find it there.
Edit: Actually, don't worry, found it on VWWatercooled. I'll give it a tweak when I get home.
Edit2: Done via coding in Module 13, Byte 2, 67 changes to 47 using the Long Coding helper after ticking the box under.
Thx.
Edited by GolfRWag
Updates
  • 2 weeks later...
Quick question in regards to the mirror dipping when putting the car in reverse.
I have the mirror dial set on L and when I pop the car into reverse the mirror drops so I can see the kerb - excellent feature. However if I then put the car back into N or D to drive away again the mirror doesnt return to its normal position?
If I flip the mirror dial back to the centre then it does come back up, or if I turn the car off and on.
Any thoughts? What am I missing here?
