Shug Posted January 26, 2019 Report Share Posted January 26, 2019 17 hours ago, Nugget said: Yeah he suggested I buy a bottle of oil to top it up and told me which coolant they use. Basic weekly checks? Check oil level, fluid levels, windscreen washers, tyres pressures... Shouldnt need much ever other than the occasional couple of psi in tyres, washer fluid and maybe a bit of oil depending if you’re engine uses any.. Much easier than the old days. My first car (mk1 Escort) needed tyres pumping up weekly they lost so much air, drank oil like petrol, and battery charging every few weeks in winter...or the dreaded push start... Quote Link to comment Share on other sites More sharing options...
rRRRM Posted January 28, 2019 Report Share Posted January 28, 2019 On 03/10/2016 at 01:08, Booth11 said: If you go into driver profile modes, in addition to Eco, Normal, Race and Individual, it will have Comfort profile. Also has DCC in the description on the mode screen. See below: Sent from my iPhone using Tapatalk Hmm. For Comfort mode on my Golf R 7.5 ACC is Comfort not Eco. Everything else is the same as yours. Also I am struggling to know exactly what a lot of the terms in the modes really mean as the Owner manual is often vague. e.g. what the heck is "Drive"?? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 28, 2019 Report Share Posted January 28, 2019 3 hours ago, rRRRM said: Hmm. For Comfort mode on my Golf R 7.5 ACC is Comfort not Eco. Everything else is the same as yours. Also I am struggling to know exactly what a lot of the terms in the modes really mean as the Owner manual is often vague. e.g. what the heck is "Drive"?? With the 7.5 sounds like they simply changed the name of the setting within Comfort mode from Eco to Comfort, which kinda makes sense. “Drive” is the gearbox setting on a 7R DSG car (can also use the DSG gearstick to change) . I think on the 7.5 the setting name may have been changed to Engine. On a 7R manual on iirc it’s refered to as Engine. Not sure if it’s called that on a manual 7.5. rRRRM 1 Quote Link to comment Share on other sites More sharing options...
rRRRM Posted January 28, 2019 Report Share Posted January 28, 2019 Thanks especially for explaining "Drive" Rebecca. FYI, for Individual mode profile settings, "Drive's" options in our car screen are Race (also known as Sport in the Owner's manual), Normal and Eco. I have played with selecting "S" with the gearstick but it felt way too aggressive / frantic considering the huge amount of power and torque already on tap in ordinary "D". Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 28, 2019 Report Share Posted January 28, 2019 1 minute ago, rRRRM said: Thanks especially for explaining "Drive" Rebecca. FYI, for Individual mode profile settings, "Drive's" options in our car screen are Race (also known as Sport in the Owner's manual), Normal and Eco. I have played with selecting "S" with the gearstick but it felt way too aggressive / frantic considering the huge amount of power and torque already on tap in ordinary "D". The changes they’ve made to the settings makes do make more sense and appear consistent with the actual driver modes. Finally VW make a good decision! S changes up too late, D too early. S manual is the way to go. rRRRM 1 Quote Link to comment Share on other sites More sharing options...
Ernie McCracken Posted January 29, 2019 Report Share Posted January 29, 2019 Moring peeps. Whilst I was waiting for the climate screen to clear the ice this morning, I noticed the rear lights flickering/strobing. It was only the lowest 2 blocks and the corner section not on the tailgate and only when the lights were on. Is this normal? Quote Link to comment Share on other sites More sharing options...
blower Posted January 29, 2019 Report Share Posted January 29, 2019 2 hours ago, Ernie McCracken said: Moring peeps. Whilst I was waiting for the climate screen to clear the ice this morning, I noticed the rear lights flickering/strobing. It was only the lowest 2 blocks and the corner section not on the tailgate and only when the lights were on. Is this normal? Did it only do this when the climate screen was on? - if so it's possible you have an alternator issue, as the climate windscreen draws a lot of power. Quote Link to comment Share on other sites More sharing options...
rRRRM Posted January 31, 2019 Report Share Posted January 31, 2019 What's up with the dipstick? I went to check the oil and a) a ridiculous effort is needed to pull out the stick " b) there are two plastic clips at the top, one of which was broken (barely hanging on) I could understand the clips IF you had to turn the stick to engage/disengage at the lip at the top of the tube but the flange is too wide all round. Two bits are narrower but nowhere near narrow enough. Now I have pulled off the busted bit there's a bit of a hole that will let grit in. Luckily there's an o-ring to catch the grit and I need to remember to wipe the grit off. I can't see anything about correct dipstick removal procedure in the manual and besides, it is something that anyone should be able to do easily. While I'm banging on, why is the stick BLACK meaning it is hard to see the oil level? Quote Link to comment Share on other sites More sharing options...
rRRRM Posted January 31, 2019 Report Share Posted January 31, 2019 I am posting the occasional trivia to get my posts up to 25 so I can add my signature. Where, in relationship to the VW badge is the radar thing? Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted January 31, 2019 Report Share Posted January 31, 2019 I am posting the occasional trivia to get my posts up to 25 so I can add my signature. Where, in relationship to the VW badge is the radar thing?On the 7.5 right behind the badge, on a 7 in the lower bumperI'm on tappatalk so won't see your signature anyway Sent from my SM-G950F using Tapatalk rRRRM 1 Quote Link to comment Share on other sites More sharing options...
rRRRM Posted February 1, 2019 Report Share Posted February 1, 2019 I called into the service department and asked for a tutorial on dipstick removal and insertion in case I was doing something stupid. It turns out I wasn't but they said I would have to buy a new one as I was the one who broke the catch. I watched while the dude struggled to pull it out. As one clip/catch was already broken off he had less trouble than I did originally but he still had to pull hard. Then he said you have to twist it a bit as you pull and you need some oil on the o-ring to help. Getting a bit browned off I didn't think to say the Owner's manual doesn't say that, OR, how the heck can I put oil on it before I pull it out. Just to describe the design. The tube has a lip on the top that stick out about 2mm all round. The lip is flat on the top and bottom i.e. not chamfered on the underside. The stick has two clips with a ramp on the inside so as you push the stick down full the clips spread and the clips snap in 2 mm under the lip making a strong hold. The clips do not have a ramp to spread them over the lip when you pull the lever up, and as I said the the lip is not chamfered on the underside. Twisting the stick does nothing to spread the clips. Bending the handle will release one clip partially but who would know to do that without close inspection or help from Owner's manual instruction? Googling shows the actual tube can break or be pulled out as well, possibly because people have to use so much force . I urge others to be aware of my arrangement and check your own. I am going to chamfer the underside on the lip and trim off a small amount around the edge so the clips do not have to spread to their limit. A couple of cut-outs to take the clips then twist to lock would be ideal but that's not intuitive. Quote Link to comment Share on other sites More sharing options...
blower Posted February 1, 2019 Report Share Posted February 1, 2019 I had trouble getting the stick out on mine too - i thought surely this is just pull and its out. Checked the manual and tried to google if there a specific way to remove it, in the end i just yanked on it and it came out........(now where is that guy who's avatar is Kenneth Williams) Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted February 1, 2019 Report Share Posted February 1, 2019 I had trouble getting the stick out on mine too - i thought surely this is just pull and its out. Checked the manual and tried to google if there a specific way to remove it, in the end i just yanked on it and it came out........(now where is that guy who's avatar is Kenneth Williams)Oooh matron!Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
steeve Posted February 2, 2019 Report Share Posted February 2, 2019 They are a bit stiff, perhaps a smear of oil around the clip might help, but a replacement should be warranty> Quote Link to comment Share on other sites More sharing options...
rRRRM Posted February 3, 2019 Report Share Posted February 3, 2019 12 hours ago, steeve said: They are a bit stiff, perhaps a smear of oil around the clip might help, but a replacement should be warranty> Yes oil on the CLIPS would help a little. Oil on the o-ring (as the service dude said) would not solve the issue. That would only help once the clips were above the lip. While awaiting comments to peter out, my latest thinking is to trim the lip to just leave two tabs (180 degrees opposite each other, aligned with one towards the radiator), twist the stick while pushing it down where the clips are clear of the tabs then let the stick twist back so the tabs go under the lip and lock it down. Quote Link to comment Share on other sites More sharing options...
