rRRRM Posted February 6, 2019 Report Share Posted February 6, 2019 Thanks for the cable junction box / cable-ties tip. I have just done mine. Since this weakness has been known for a long time I reckon VW should have fixed it long ago or at the first service it should be done routinely. I am getting a little disillusioned with the brand. Quote Link to comment Share on other sites More sharing options...
rRRRM Posted February 6, 2019 Report Share Posted February 6, 2019 Blower said " It's funny I see this question come up once a year on various forums....VW (and many car manufacturers) have been putting acoustic damping on the inner parts of wings and other cavity area's for years, some cover them in plastic bags like VW when they are in area's that could get wet. Inside the bag is a foam like material, it's purpose is to stop noise (be it from wind and/or panel resonance). Do not remove this. The engineer logic is that a cavity can resonate, so to stop that you fill it with something, foam is best, but foam can hold water and promote rusting - so put a bag around the foam " On my car I just noticed the plastic is all crinkled up on the coolant bottle side, BUT it IS there on the corresponding passenger side but it is not scrunched there so it looks like it belongs. Because it was smooth it looked black rubber. My bad. As a somewhat anal personality I am into noise suppression etc. so I'd like to inspect the material used but it is a bit tricky to get at or at which to get or whatever. Where are my meds? blower 1 Quote Link to comment Share on other sites More sharing options...
blower Posted February 6, 2019 Report Share Posted February 6, 2019 6 minutes ago, rRRRM said: Blower said " It's funny I see this question come up once a year on various forums....VW (and many car manufacturers) have been putting acoustic damping on the inner parts of wings and other cavity area's for years, some cover them in plastic bags like VW when they are in area's that could get wet. Inside the bag is a foam like material, it's purpose is to stop noise (be it from wind and/or panel resonance). Do not remove this. The engineer logic is that a cavity can resonate, so to stop that you fill it with something, foam is best, but foam can hold water and promote rusting - so put a bag around the foam " On my car I just noticed the plastic is all crinkled up on the coolant bottle side, BUT it IS there on the corresponding passenger side but it is not scrunched there so it looks like it belongs. Because it was smooth it looked black rubber. My bad. As a somewhat anal personality I am into noise suppression etc. so I'd like to inspect the material used but it is a bit tricky to get at or at which to get or whatever. Where are my meds? Having seen these 'packets' out of the car, It's just some foam in a bag. I believe its purpose is more to fill the cavity and stop any wind borne resonance (like blowing into a bottle), rather than do any other form of damping such as reducing panel vibration etc. rRRRM 1 Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted February 7, 2019 Report Share Posted February 7, 2019 On 06/02/2019 at 00:05, gregozedobe said: Hmmm, after looking at both photos I feel a reminder is needed. VW's have a tendency for the junction box for the bonnet release cable to separate and leave you unable to open your bonnet. The fix is quick, easy and cheap, so get to it you slackers that haven't done it yet. No excuses will be accepted, and large doses of "I told you so" will be meted out ( with inordinate smug satisfaction) if you don't do it and your cable fails as described below ! Well, this is a bit embarrassing .... after taking such a high and mighty attitude to people who haven't done this I must 'fess up and admit that while I had fixed both my R and Transporter (different issue but similar result), I hadn't rectified my Octavia. Fix now done and possible major embarrassment avoided ... Quote Link to comment Share on other sites More sharing options...
rRRRM Posted February 9, 2019 Report Share Posted February 9, 2019 Today I made two cutouts on the lip of the dipstick tube, opposite each other and about 30 degrees anti-clockwise from where the clips lock under the lip. Beforehand I moistened a tissue with oil and put it in the dipstick hole to catch filings. I also packed rag below the worksite to catch anything I dropped. The clips still caught a little in the cutouts so I filed downwards on the cutout to make it flush with the tube outer surface and the clips no longer catch there. They will not break now. Surprisingly, twisting the stick so the clips going up via the cutouts the dipstick was still very hard to pull out .. it came out all of a sudden and required quite a pull. If you had your head over the stick handle you would smack yourself in the face. Then I tried engine oil on the o-ring and that made very little difference. I even smeared oil down the hole and no difference. I had to conclude that the o-ring is a VERY tight fit in the tube and was removing the oil as it slipped up the tube. Next I tried rubbing graphite on the ring and inside the tube and BINGO, HOORAY and YOU LITTLE BEAUT .. it pulls out smoothly and I had fun wanking it in and out several times. As the graphite is now integrated into the rubber of the o-ring and the plastic of the tube I expect it to be a permanent fix. What a bloody saga . Quote Link to comment Share on other sites More sharing options...
GaryP Posted February 10, 2019 Report Share Posted February 10, 2019 Coming Home lights not working. When you park up and lock the car at night I thought the headlights were meant to stay on for a period of time as set in Light settings in car menu?? They come on when unlocking, and when locking the digital dash stays illuminated for the amount of time Coming Home is set to. I’ll be taking JB1 and Pedal Box off in next few days so will see if it’s those causing it, but putting out here now in case anyone else experienced this. Mk7.5 Estate. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
blower Posted February 10, 2019 Report Share Posted February 10, 2019 4 hours ago, GaryP said: Coming Home lights not working. When you park up and lock the car at night I thought the headlights were meant to stay on for a period of time as set in Light settings in car menu?? They come on when unlocking, and when locking the digital dash stays illuminated for the amount of time Coming Home is set to. I’ll be taking JB1 and Pedal Box off in next few days so will see if it’s those causing it, but putting out here now in case anyone else experienced this. Mk7.5 Estate. Sent from my iPhone using Tapatalk I have the exact same issue, not looked into it yet but as you say head lights don't stay on when I lock the car, but dash does for a short while (probably length of time coming home is set to) GaryP 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 10, 2019 Report Share Posted February 10, 2019 4 hours ago, GaryP said: Coming Home lights not working. When you park up and lock the car at night I thought the headlights were meant to stay on for a period of time as set in Light settings in car menu?? They come on when unlocking, and when locking the digital dash stays illuminated for the amount of time Coming Home is set to. I’ll be taking JB1 and Pedal Box off in next few days so will see if it’s those causing it, but putting out here now in case anyone else experienced this. Mk7.5 Estate. Sent from my iPhone using Tapatalk 31 minutes ago, blower said: I have the exact same issue, not looked into it yet but as you say head lights don't stay on when I lock the car, but dash does for a short while (probably length of time coming home is set to) On the 7R, you need to first make sure you have Leaving Home and Coming Home lights enabled in the CAR - Lights settings on infotainment unit, set at 20 seconds or so. Then to get the coming home lights to activate on exiting the car, the lights need to be on the Auto switch setting, then on parking up you have to switch the ignition off completely (remove keys if not keyless), flash the headlight stalk once, open the door and the headlights will come on and stay on (after locking) for whatever period of time you’ve set in the menu e.g 10, 20, 30 secs. You have to do this every time! If you have vcds or obdeleven you can code it so it does it automatically minus the stupid headlight stalk faff. blower 1 Quote Link to comment Share on other sites More sharing options...
blower Posted February 10, 2019 Report Share Posted February 10, 2019 35 minutes ago, Booth11 said: On the 7R, you need to first make sure you have Leaving Home and Coming Home lights enabled in the CAR - Lights settings on infotainment unit, set at 20 seconds or so. Then to get the coming home lights to activate on exiting the car, the lights need to be on the Auto switch setting, then on parking up you have to switch the ignition off completely (remove keys if not keyless), flash the headlight stalk once, open the door and the headlights will come on and stay on (after locking) for whatever period of time you’ve set in the menu e.g 10, 20, 30 secs. You have to do this every time! If you have vcds or obdeleven you can code it so it does it automatically minus the stupid headlight stalk faff. Thanks for that, i'll code it with VCDS so it's the same it has always been since the mk5! (which prat thought it was a good idea to now have to flash the headlights for it to work!) Quote Link to comment Share on other sites More sharing options...
GaryP Posted February 11, 2019 Report Share Posted February 11, 2019 20 hours ago, Booth11 said: On the 7R, you need to first make sure you have Leaving Home and Coming Home lights enabled in the CAR - Lights settings on infotainment unit, set at 20 seconds or so. Then to get the coming home lights to activate on exiting the car, the lights need to be on the Auto switch setting, then on parking up you have to switch the ignition off completely (remove keys if not keyless), flash the headlight stalk once, open the door and the headlights will come on and stay on (after locking) for whatever period of time you’ve set in the menu e.g 10, 20, 30 secs. You have to do this every time! If you have vcds or obdeleven you can code it so it does it automatically minus the stupid headlight stalk faff. Thanks for that Becs. I would never of thought of having to do that, nor to look in the Owners Manual, would have just expected it to happen when in Auto Lights mode. Tried it out earlier this evening and all is good. Can't believe you have to flash the Headlight stalk!! I'll stop blaming the Pedal Box and JB1 now. One less thing to ask the Dealership to look at when it goes in for its 1st service shortly. I have the dreaded Sticking Fuel Flap issue, so will be asking them to fix that on Warranty. Booth11 1 Quote Link to comment Share on other sites More sharing options...
Ali19 Posted February 13, 2019 Report Share Posted February 13, 2019 Does anyone know when the first of the new 300 BHP 7.5 were built by VW? Apparently my car is waiting to Ship and I was wondering how long it could have been waiting. Quote Link to comment Share on other sites More sharing options...
Hugh Posted February 14, 2019 Report Share Posted February 14, 2019 23 hours ago, Ali19 said: Does anyone know when the first of the new 300 BHP 7.5 were built by VW? Apparently my car is waiting to Ship and I was wondering how long it could have been waiting. Mine was built on the 16th October, FWIW. Quote Link to comment Share on other sites More sharing options...
Ali19 Posted February 14, 2019 Report Share Posted February 14, 2019 Thanks Hugh. Quote Link to comment Share on other sites More sharing options...
Hugh Posted February 15, 2019 Report Share Posted February 15, 2019 Anyone able to tell me what the button to the right of ‘SET’ and above the volume up button does? Quote Link to comment Share on other sites More sharing options...
Charles M Posted February 15, 2019 Report Share Posted February 15, 2019 Mine doesn't have that, but has a "Mode" button in its place. Looks like something to do with the monitoring/safety system. Quote Link to comment Share on other sites More sharing options...
