Guy Incognito
1 hour ago, GaryP said:
I take it this is not the delivery plastic inserts we’ve heard about being left in place when taking customer delivery? Spotted it whilst I had the car jacked up this evening.
They don’t look removable, nor did I try by the way. These look part of the suspension system.
The pictures I've seen of the removable transportation pucks show a C shaped plastic spacer with a large slot to enable removal from the strut shaft.
See pics in this link for what transport pucks look like.  They are sometimes pink or blue.
https://forums.vwvortex.com/showthread.php?6978296-Quick-Guide-to-Remove-Strut-Pucks
My auto stop-start seems to be playing up. It’ll stop the engine when I come to a stop, but then INSTANTLY start it again, without any throttle, break or steering input. A little icon appears at the top of the screen with the auto stop start symbol crossed out. It does the same when I park up. I come to a stop, put the car in park, the engine stops and then starts up again, just for me to then turn off the ignition.
Anyone know why she might be doing this?
Mine works perfectly, never comes on at all, ever
Most likely your Battery Control Module (BCM) thinks the battery is low on charge, so the car is starting the engine up so you don't get stuck with a flat battery and engine not running.
Common causes are:  lots of short runs with lights on, running lights and/or infotainment when stopped (engine not running), cold weather, or battery is on the way out (lots of recent reports of 3 yr old VAG cars with stop/start needing new batteries)
How old is your car ?  Have you totally flattened the battery recently (that will damage a battery beyond recovery).
Like SMDave, I always disable stop/start as soon as I start the engine, I find it annoying (but I rarely drive in heavy traffic with lots of long stops, so it doesn't provide much benefit in my usual driving conditions)
Car was registered 5 days ago. I doubt there's anything wrong with the battery. I don't do short runs, 35 miles each way twice per day.
Hmmm.  If your car has only just been registered for the first time 5 days ago there is a very strong possibility that it is a "WLTP banked" car that has been sitting around unused for some time (possibly months).  If that is the case then the battery may have gone flat while it was sitting unused, and this may have damaged the battery so it can't hold a full charge.
Do you know when your car was actually built ?  Not the fake build date of 2? Jan 2019 that VW has been pretending applies to all the "WLTP banked" cars.  If it has been sitting unused  along time I would be suspicious of the battery.
Have you had any non-oem electrical stuff fitted ?  Things like alarms and dash cams can drain batteries, often not directly but by causing the various ECUs to stay awake (using power) rather than going to sleep after a few minutes of not being used.
If your car is completely stock (electrically speaking) then from what you said you are driving long enough to have charged up the battery.  The logical next step is to take it in to a VW dealer to get the problem investigated and fixed under warranty.  It might be a faulty charging system, not the battery.
If you have a multi-meter and wanted to investigate yourself you could check the voltage at the battery, both after the engine has been running for at least 5 minutes,  after you have been driving for 20 minutes, and also after the car has been stopped for at least 5 hours.
11 hours ago, bigknd said:
This is perfectly normal, the stop start system is intelligent, so when the car in front starts to move your car will start up in preparation to move too!.
It did take me a while to work out what was happening though ;)
Not what’s happening. This is the error. I suspect the post above may be accurate, as it was built in November.
Only had mine 4 days but I've noticed when coming to a standstill, if you take your foot of the brake briskly then the brake pedal/mechanism makes quite a "clonk" noise in the foot well.
Not really noticed this in other cars. is this normal, anyone else noticed this?
I’ve noticed that the ‘auto’ mode seems to always use the air conditioning, even to heat. I presume this is to dehumidify. Assuming the compressor isnt working hard for this, what impact will this have on fuel consumption in comparison to turning AC off and not running on auto?
I have this too, like an inch or 2 of travel which results in the pedal clunking back to rest position.
