Guy Incognito
On 10/05/2019 at 18:35, Hugh said:
image.thumb.png.3e65e8a9323bc845bcba89cfb429e75a.png When I see other Rs driving around in the dark, their inner headlights seem to be working, as shown in this picture on the VW website. My headlights only seem to ever light up the outer two bulbs, and the inner ones only function as main beam. What's up with this?
If all the lights are working they the car has high beam assist as far as I know.
Short press for VW voice activation, long press for SIRI.
Thanks again. I’m getting Siri with the long push when connected to car play but not when merely connected to Bluetooth; nothing with the long push. I’m guessing there’s no Siri activation when not physically connected.
I’m personally just outers on dim, all 4 on full beam. That’s in the daylight this morning.
Thats right.  Use of Siri and CarPlay requires the wired connection.
On 15/02/2019 at 02:07, Hugh said:
Anyone able to tell me what the button to the right of ‘SET’ and above the volume up button does?
If someone hasn't answered yet, it calls up a menu on the main dash screen (where speedo is) and gives you choice of what you want to view on that display. For example, fuel economy, or trip info. Use the up/down buttons on the right spoke of the steering wheel, and push the button that's between them (sorry not looking at mine now) to Select the display you want. Adjustable on the fly. Push it! Seeing is worth 100's of words...  :)
Nope left hand side is all driver assist, such as ACC, speed limit and as mentioned possibly lane assist.
the right hand side controls the MFD views, gives various options, changes channel or music track.
3 hours ago, rRRRM said:
In the Owner manual, the button in question ( 4 curved lines around a car symbol ) is referred to as  the "button for driving assist systems"
You are absolutely correct! My bad for answering w/o verifying. Thanks!!
Just a little tip that has helped me out and cured a problem that was driving me mad, my plastic pilars on the outside of the car made a horrible creaking noise, if you pushed them they creaked, so a bump in the road or bends made them creak, this was annoying, i sorted it by peeling the window rubber away from it, and spraying some lithium grease into the gap between the metal and plastic and rubber, no more creak at all.... 😁
