Guy Incognito
  • 2 weeks later...
5 hours ago, Squish said:
I’ve seen a few vague answers on this but is there a definitive answer to:
How do you clean the soot from the exhaust tips??
Elbow grease, perseverance, autosol / mothers.
the most important thing is a regular wash cycle, out of phase with main car wash, this means you can spend enough time to get them clean and sealed each time.
hard to remove deposits, more elbow grease, more perseverance, fairy liquid and a rough scouring pad.
just remember using anything harder than the chrome can mark it, such as course Brillo pad.
I just give mine a regular wipe-over with a wet-strength damp paper towel.  It takes about 30 seconds to wipe the very ends, so it isn't too much of an imposition to do it whenever they look dirty (yes, that means often).  If you don't let the crud build-up and go hard they clean up quite easily.
  • 3 weeks later...
6 months later & I'm still unable to find answers in the dopey Owner manual.    In the digital dash instrument view called "Efficiency", the speedo centre graphic shows a car with blue bars on white arcs either side. The blue bars move down if accelerating, up if coasting and way up if braking.  They stay in sync at all times even if cornering.  The graphic is not intuitive to me. If it is supposed to tell me how I'm driving it seems a superfluous distraction.
I wondered about this one too, not sure it has much to do with efficiency, I think it’s a sort of front and rear G meter to demonstrate how hard you are braking or accelerating . My guess is you’re driving more efficiently if you keep the blue bits in the centre. Alternatively it’s fun to try and make them disappear entirely...
The R has an efficiency thingy?
Not found that yet, doubt ever will 🤣
  • 2 weeks later...
I need to top up the oil in my VW California which is a T5 2015 model.  Looking it up on castrol's website and Opie it uses the same oil as my Golf R?
I thought with it being a TDI engine it would be different?  I have a bottle of Fuchs in my cupboard which apparently safe to use.  Didn't want to f*** up the van.  Shall I just crack on
VW approved 504/507 is what I use in my R, my T5 and my Octavia.  It keeps life simple.
IIRC in the US they are supposed to use a different standard oil (possibly thinner to make a slight improvement to fuel economy ?  )
I’ve had a search but cant find the answer to this one.  I have had the reverse camera retro fitted to my Golf and just wonder, if you had a factory fitted one, when you reverse and the picture with the lines comes up, do the lines bend when you turn the steering wheel or remain straight?
Mine stay straight but on the wife’s Evoque they bend to show where the car is heading.
Many thanks for any help.
Mine don't bend, the green lines stay straight all the time, my previous MINIs used to bend.
The R also shows a graphic , to one side of the screen,of a car with yellow shaded areas that bend when you move the steering, I haven't got a clue what this is supposed to do, any help welcomed.
Cheers Len, so the same as mine. Good to know its all working as it should!
