G.aero Posted September 9, 2020 Report Share Posted September 9, 2020 (edited) any chance ,i get the part number for spark plugs Golf R mk 7.5 ? 17 plate Edited September 9, 2020 by G.aero Quote Link to comment Share on other sites More sharing options...
NRW Posted September 9, 2020 Report Share Posted September 9, 2020 4 hours ago, Kneel said: A quick question regarding DSG paddles. Can the right hand paddle be used on the left and vice versa, the left paddle be used on the right? I guess I should just remove them and try but it`s dark out there now 🥕 Would you trust another driver in your R with wrongly labelled paddle shifters?🤔 Apart from me...only Lovely Wife and Dealership staff have driven mine😂 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 10, 2020 Report Share Posted September 10, 2020 A quick question regarding DSG paddles. Can the right hand paddle be used on the left and vice versa, the left paddle be used on the right? I guess I should just remove them and try but it`s dark out there now Nope they are different so not swappable Sent from my VOG-L09 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Kneel Posted September 10, 2020 Report Share Posted September 10, 2020 17 hours ago, SpursMadDave said: Nope they are different so not swappable Thanks for the confirmation Dave 👍 I want to change the dsg paddles but all the ones I`ve seen are far too big for what I want. I want paddles that are just a bit bigger than OEM, perhaps and inch or so. My idea was to find some I could modify myself but if they`re not swappable from each side I`ll have to think of another plan. Quote Link to comment Share on other sites More sharing options...
Kneel Posted September 10, 2020 Report Share Posted September 10, 2020 21 hours ago, NRW said: Would you trust another driver in your R with wrongly labelled paddle shifters? Some of the aftermarket ones I`ve seen are not even labelled. There`s drivers and there`s screwdrivers. NRW 1 Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted September 11, 2020 Report Share Posted September 11, 2020 20 hours ago, Kneel said: Thanks for the confirmation Dave 👍 I want to change the dsg paddles but all the ones I`ve seen are far too big for what I want. I want paddles that are just a bit bigger than OEM, perhaps and inch or so. My idea was to find some I could modify myself but if they`re not swappable from each side I`ll have to think of another plan. Maybe this could work for you, as you could trim off the top bit, especially with the silver ones where it wouldn't be obvious. At the price it's probably worth a try. Just don't go for stick-on extensions; that looks like a potential safety hazard. https://www.aliexpress.com/item/4000427108434.html?spm=a2g0s.12269583.0.0.496b2df05I9EGQ Kneel 1 Quote Link to comment Share on other sites More sharing options...
Kneel Posted September 11, 2020 Report Share Posted September 11, 2020 Thanks @Chris7.5R, I bought some cheapo ones earlier today with the plan to do just that 👍 Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted September 15, 2020 Report Share Posted September 15, 2020 On 11/09/2020 at 20:45, Kneel said: Thanks @Chris7.5R, I bought some cheapo ones earlier today with the plan to do just that 👍 My black ones arrived from that supplier today (£12.64 and 8 days from China) and they fit and work just fine. Only complaint is the little 'prong' at the bottom that has absolutely no function, as the paddle won't move if you press just there. When I can be bothered I'll remove the paddles and trim them. SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 15, 2020 Report Share Posted September 15, 2020 My black ones arrived from that supplier today (£12.64 and 8 days from China) and they fit and work just fine. Only complaint is the little 'prong' at the bottom that has absolutely no function, as the paddle won't move if you press just there. When I can be bothered I'll remove the paddles and trim them.Yeah they just copied the racingline ones, had my cheapo ones on 2 Rs now and many many 1,000s of miles and no issues at all, mine needed a tiny bit of modifying as I must have been one of the first batch that they did and they didn't hollow out the bit that holds them on to the wheel, I got a full refund, another set that were perfect and drilled out the originals so 2 sets for nothing Sold the spare set for £30 Sent from my VOG-L09 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted September 15, 2020 Report Share Posted September 15, 2020 1 hour ago, SpursMadDave said: Yeah they just copied the racingline ones, had my cheapo ones on 2 Rs now and many many 1,000s of miles and no issues at all, mine needed a tiny bit of modifying as I must have been one of the first batch that they did and they didn't hollow out the bit that holds them on to the wheel, I got a full refund, another set that were perfect and drilled out the originals so 2 sets for nothing Sold the spare set for £30 Sent from my VOG-L09 using Tapatalk How on earth do RL attempt to justify nearly £200 for an almost identical item? Solid unobtanium, hand-crafted during a total solar eclipse by Swiss elves, perhaps. Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 15, 2020 Report Share Posted September 15, 2020 How on earth do RL attempt to justify nearly £200 for an almost identical item? Solid unobtanium, hand-crafted during a total solar eclipse by Swiss elves, perhaps.Yeah and apparently the other expensive ones have plastic parts on the back, not even solid metal... I think RL just priced them alongside the only other real option... Sent from my VOG-L09 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted September 17, 2020 Report Share Posted September 17, 2020 On 15/09/2020 at 16:39, SpursMadDave said: Yeah and apparently the other expensive ones have plastic parts on the back, not even solid metal... I think RL just priced them alongside the only other real option... Trimming the lower 'tabs' improved the appearance, then I realised that the +/- tabs don't do anything useful. I know which is which and the only other driver of my car wouldn't even think about using them. Next is a pair of the silver paddles (only £10.28 now), which I will top and tail when they arrive. SpursMadDave and Kneel 2 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted September 17, 2020 Report Share Posted September 17, 2020 Trimming the lower 'tabs' improved the appearance, then I realised that the +/- tabs don't do anything useful. I know which is which and the only other driver of my car wouldn't even think about using them. Next is a pair of the silver paddles (only £10.28 now), which I will top and tail when they arrive.I've ordered a couple of different ones off AliExpress to see if I prefer them Sent from my VOG-L09 using Tapatalk Quote Link to comment Share on other sites More sharing options...
razzle Posted September 22, 2020 Report Share Posted September 22, 2020 Can someone explain "spacers" to me please? Is it that they alter the stance to improve handling? Would adding them affect warranty? Quote Link to comment Share on other sites More sharing options...
NRW Posted September 22, 2020 Report Share Posted September 22, 2020 (edited) 45 minutes ago, razzle said: Can someone explain "spacers" to me please? Is it that they alter the stance to improve handling? Would adding them affect warranty? The answer you’re not hoping for is the one you’ll get, imho. Any Non factory kit mods will provide grounds For a Dealer to refute a claim in the connected area. otherwise everybody in an R would be running round with Stage 1 or above. Makes sense really. 😀 Edited September 22, 2020 by NRW Imho Quote Link to comment Share on other sites More sharing options...
