Guy Incognito
Annoying auto stop habit, that does not happen in my Amarok. If I am braking gently to a halt, the auto stop will cut in and turn the engine off before I have come to a stop. Makes the steering very heavy etc and is a bit disconcerting sometimes. Is this really normal???
Seems to be on 7.5's, and yes, it is annoying to many people.  So much so that I have resorted to pressing the Stop/Start button as soon as I've started the engine to lock it out fo rthe rest of the journey.  If I know I am going to be stopped for a long time I can press the Stop/Start button again to let the engine stop until I'm ready to move off.
I understand that on 7's if you only press lightly on the brake pedal then you can stop without invoking auto stop, but that doesn't work on my 7.5  (unfortunately).  :(
I’ll be disabling start/stop using Carista this weekend. The constant start/stop in traffic is awful, as is the stop n coast issue above, especially when approaching a roundabout at low speed!
Probably a really dumb question, but I’ve looked everywhere, where do I find the Overall Mileage reading? All I can find is Long Term, Since Start, Since Refuel - all of which can be reset.
There’s the Trip counter with the reset button also, but again, can be reset.
Hopefully someone knows.
Thanks.
Thanks.
Turn off the ACC and it displays there.
I do the same - when I remember, which isn't every time.  One of the most annoying things for me is pulling up to park.  The Stop/Start kicks in immediately and stops the engine; then I turn the steering wheel slightly to put it in the correct position to engage the steering lock and the engine starts again just as I'm about to pull the key out!
2 hours ago, Charles M said:
Turbo whistle... I have had (diesel) turbos for 25 years, but none are as loud as the R. I am presuming that they do make a lot of noise.....
I had not noticed it in mine tbh, although i have the exhaust flaps open so may mask it a bit..  Have you had any mods?
