Guy Incognito
On 01/05/2018 at 20:44, mark118 said:
I am looking to change from 18" cadiz to 19" replica prets, i have a facelift 2017 golf r and was wondering what will change with the car with the size difference is it just the ride quality (im non dcc) and speedometer(digital dash) or is there anything else that gets affected like the active cruise control/emergency stop stuff. Thanks
Thought 19s had lower profile tyres than 18s, so actual diameter of wheel and tyre was 99.9% the same. If so no changes to speedo or anything, although with less tyre to cushion bumps, fag packets etc. you may find 19s just a little harsher ride...
It's just the ride - lower profile tyres will mean the overall radius of the wheel and tyre is the same.
1 hour ago, Pet0r said:
Is there a way to link the seat/mirror position to a key so that when that key is used they move to the correct position?
I thought if I opened the car with that key, set all that up and then locked the car with that key, it would stick to the key, but this doesn't seem to be the case.  Does this work at all, and if so what is the procedure?  Is it because I'm using keyless entry/exit?
I believe it is possible to link a particular key to specified driver profile (on the Mk7.5 at least), but I haven't done it on mine (yet).  The steps should be in your manual (but whether you can make head nor tail of said instructions is another story).
Here is a youtube video describing the process:
https://www.youtube.com/watch?v=mh7bqDwaaG0
When I switch the driving mode to "Individual" a message comes up in the dash display telling me to check the settings. When I check the settings there is no obvious issue or any sort of warning tag. I do experiment with the settings but recently I have had Steering and Drive in "Race" with the other 5 in "Normal".
Is the car just being sniffy about this combination?
Incidentally, why the heck is Aircon part of this list? I set the H & V according to the ambients and how I'm feeling, not how I plan to drive. It's a trivial point but it irritates because it makes the list too long for one screen so not all of the parameters can be shown at once: I have to scroll down to see Engine Sound.
This is probably going to sound completely stupid but I saw a tweet the other day to say that on hot days we should be checking the water in our radiators.
That's coolant right?
Yes, that's coolant.
For the record, I got this working although the video doesn't show all of the steps. Found the relevant page in the manual after watching the video though, it's under personalisation, nothing to do with the key!
In that menu if you scroll down you can select manual mode and assign a driver profile specifically to a key, then it will move the seats and mirrors etc as they were set while this profile was active.
Sent from my Pixel 2 XL using Tapatalk
Does the R (7.5) have any bulbs which are replaceable by the owner?
I've always carried a set of spare bulbs in my cars but couldn't find a listing in the manual. It does describe changing various bulbs but does not make clear which, if any, are relevant to the R.
Thanks for any help.
On 14/05/2018 at 21:07, George 3G said:
I've noticed that when stationary and flicking the gearbox between D and S, I can hear what sounds like a solenoid or similar? As if the exhaust valves are opening, but I thought these were dependent on driving mode?
When in S all four flaps open at certain times, and as soon as you flock from D to S, you’ll hear the change in exhaust note.
On 18/05/2018 at 08:17, Red201 said:
How can I tell if my entertainment system is Discover Pro Nav?
I was asked the other day and wasn't entirely sure what the differences were!
 on the 7.5 It Will be all touch screen with no knobs sticking out for volume.
