Sean28uk Posted January 3, 2024 Report Share Posted January 3, 2024 Has anyone got the Maxton Design spoiler extension on their 7.5R. Been thinking about it because the standard spoiler is very subtle. Thanks Sean Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted January 15, 2024 Report Share Posted January 15, 2024 Had a play with Torque Pro now that it can be added to AndroidAuto. Handy being able to see Oil Temp, DSG Temp and correct coolant Temp G.aero and theskivingscholar 2 Quote Link to comment Share on other sites More sharing options...
V6coop Posted March 24, 2024 Report Share Posted March 24, 2024 Spent this afternoon installing a secondhand boot mounted Helix DSP/Sub. I was a bit underwhelmed by the standard audio set up and had seen good reports of the Helix "Plug & Play" units, including the spare wheel well version, but I wasn't keen on losing the spare. It turns out that the boot version I wanted is not available new from VW anymore so I bought a used one off ebay complete with loom. There was a bit of toing and froing with the vendor when the plug which re-routes the un-pinned cables from the block connector in the back of the glovebox CD unit into the Helix loom was found to be missing, but he came up trumps and posted me the offending article the next day. Otherwise, it was like new bar a few marks on the Helix badge. After viewing a couple of YouTube videos and removing the trim under the doors and up the A pillar on the passenger side to route the loom and changing some of the wiring as mentioned, I had the job done in less than three hours. The vendor (anyone on here?) had a dongle and programmed the box for the Golf 7 four door and the jumper for right-hand drive was in-situ on receipt. Only thing missing was the 'shorting plug' which goes into the boot end of the Molex connector on the Helix loom so you can revert to the basic sound set up should I need to take the sub out to carry bigger loads. I have ordered a new one from a specialist. So, what's the verdict? I have to say I am very impressed, it really makes a massive improvement to the basic set up. The most marked aspect for me was not the much-improved bass from the two modest subs in the box (no need from my perspective to have it pushed up the scale on the mixer anymore) but the much more enveloping soundstage and the undistorted mid and treble audio quality from the DSP. It would seem to me that the standard speakers are more than up to the job. If anyone else buys a second hand one (boot or spare wheel), this is the connector that you need make sure is included to get the power into the Helix loom for the DSP/Amp. The fitted Helix box Quote Link to comment Share on other sites More sharing options...
delboy01 Posted April 1, 2024 Report Share Posted April 1, 2024 Fitted a second boot light. I often have a full boot and having only one light on the right meant I often couldn't see things I was looking for on the left. Quote Link to comment Share on other sites More sharing options...
Aquanaute Posted April 17, 2024 Report Share Posted April 17, 2024 New carbon tips from Tipwerx fitted to standard exhaust. Did a special order as wanted 3.5" in black with the R logo not the 4". Very easy to fit and think they look good. mr3sgte 1 Quote Link to comment Share on other sites More sharing options...
delboy01 Posted April 24, 2024 Report Share Posted April 24, 2024 Added MK8 R Style blindspot indicators. They work well and can be seen much easier than the indicators in the glass. The silver finish appears good quality for an aliexpress special. Wasn't easy to fit as the clips are very fragile but so are the oem so i resorted to removing the front of the wing mirror which was just two screws and that made it much easier. holy_piranha and Booth11 2 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted April 24, 2024 Report Share Posted April 24, 2024 56 minutes ago, delboy01 said: Added MK8 R Style blindspot indicators. They work well and can be seen much easier than the indicators in the glass. The silver finish appears good quality for an aliexpress special. Wasn't easy to fit as the clips are very fragile but so are the oem so i resorted to removing the front of the wing mirror which was just two screws and that made it much easier. Great addition to the mk7/7.5. The side assist is one of the best driver aids on the mk8 imo. Quote Link to comment Share on other sites More sharing options...
rRRRM Posted April 25, 2024 Report Share Posted April 25, 2024 FWIW I posted my blind-spot system a while back. It includes a l.e.d. for Left & Right on the dash hump in front of the steering wheel. Parts cost (from memory) ~ $30 Australian, some simple soldering was required. No cpu settings required to enable. Quote Link to comment Share on other sites More sharing options...
eski Posted May 9, 2024 Report Share Posted May 9, 2024 Got some Oettinger mats , for the summer ,rubber mats can go back in when weather is bad Tripline 1 Quote Link to comment Share on other sites More sharing options...
eski Posted May 24, 2024 Report Share Posted May 24, 2024 Got the subtle maxton diffuser , gonna get it bonded on and filled and painted in , don’t want a join,been to body shop today with the r32 , as I want ed to see if he can match the paint for blue callipers ,which he can as i want the R callipers done in that colour , as I my mind was what they should have been as it was the first R weren’t it , Dry fit only a slight difference, but it’s different just need to book it in now ,will get some pics with the callipers painted r32 blue when done Quote Link to comment Share on other sites More sharing options...
eski Posted June 1, 2024 Report Share Posted June 1, 2024 Put my mats in and got the Lockwood sill protectors, also Oettinger surround on back with gel plates and piston heads sticker Booth11 1 Quote Link to comment Share on other sites More sharing options...
87djames Posted June 14, 2024 Report Share Posted June 14, 2024 On 16/08/2023 at 14:52, Jace said: Took advantage of the Maxton flash sale a couple of weeks ago & bought a rear defuser. Very easy to fit, I used 3m VHB tape along with two flat head torques screws hidden at the back for extra security . It doesn't look to excessive IMO, almost OEM+ , the true OEM+ test is if the wife doesn't notice 😄 OEM With added Maxton Defuser huge difference looks x10 better Jace 1 Quote Link to comment Share on other sites More sharing options...
Jace Posted July 11, 2024 Report Share Posted July 11, 2024 It should go loads faster now 😄 Maybe I could be an influencer & start a new trend, bringing retro pinstripes back 🤔 NRW and HarveyG 2 Quote Link to comment Share on other sites More sharing options...
Midlife Driver Posted August 15, 2024 Report Share Posted August 15, 2024 Just finished reading the first non-performance thread! Excited to see there is a second, will get a litre of coffee and get comfy to read through.I will take some pics of my car and bits, but so far, I have done the following for mine.1) full rebadge (rear, side and front badges)2) body colour wing mirror caps3) silver dial knobs for climate control and radio4) a set of custom fitted leatherette/vinyl mats that completely cover the floor of the car - makes cleaning way easier with two messy kids. Was unsure about this order but it does the job perfectly for me.5) rgm boot lip protector and side sill protectors - black vinyl, doing a mega job of protecting from child vandalism6) front seat back protectors which also have loads of storage7) vw brand double usb charger8) bonnet release tiesSoon to be done:8) roof rail wrap in black9) smoked tint on rear lights (white strips only)10) some silver/aluminium trim bits and bobs for the interior11) Bosch areo wipes12) armrest storage13) steering wheel re-trim14) dsg paddles 15) mudguards front and rear16) 17inch rse05 wheels17) longer length under tray for bit of extra protection of sump and other gubbins underneath (Plus a pedal box, sorry, know I shouldn’t mention that here!)I honestly didn’t give a monkies about any of this stuff on any prior car but reading these forums is dangerous!Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Midlife Driver Posted August 15, 2024 Report Share Posted August 15, 2024 It should go loads faster now http://vwroc.s3.eu-west-2.amazonaws.com/monthly_2024_07/IMG_5097.thumb.jpg.1b4b523832d35735244a915b89a9cf06.jpg Maybe I could be an influencer & start a new trend, bringing retro pinstripes back http://vwroc.s3.eu-west-2.amazonaws.com/monthly_2024_07/IMG_5100.thumb.jpg.9e6979caeed980ec0fc5aa6a18ba313e.jpgLove those wheelsSent from my iPhone using Tapatalk Jace 1 Quote Link to comment Share on other sites More sharing options...
