Sparky-R Posted January 19, 2017 Report Share Posted January 19, 2017 Good evening all! Are there any 'avid' users of engine auto stop / start? If so, has long term use of auto stop / start had any negative effects on your battery or any other negative effects? I use mine from time to time but 99% of the time I deactivate it. Quote Link to comment Share on other sites More sharing options...
KashR Posted January 19, 2017 Report Share Posted January 19, 2017 I dont think I like it - When I find someone who will disable it for me then i'll be happier! ninja_geezer and Sparky-R 2 Quote Link to comment Share on other sites More sharing options...
camelsac2002 Posted January 19, 2017 Report Share Posted January 19, 2017 Good evening all! Are there any 'avid' users of engine auto stop / start? If so, has long term use of auto stop / start had any negative effects on your battery or any other negative effects? I use mine from time to time but 99% of the time I deactivate it. Had mine nearly a year, 11,000 miles and no problems. Don't use it religiously - maybe 75% and its been fine. I think if you're sat in traffic with lights etc on it will fire up automatically if it detects the power draining. Sent from my HTC One using Tapatalk Sparky-R 1 Quote Link to comment Share on other sites More sharing options...
75Type2 Posted January 19, 2017 Report Share Posted January 19, 2017 It only kicks in when the battery has reached a certain percentage level. The auto stop on mine usual kicks in after about half an hour of driving, because the car is tucked up in the garage most of the time. Also the cold weather is also putting a strain on the battery, as the dashcam is set to turn off when the voltage drops below 12V when in parking mode, it's lasting about 2 hours currently. In the warmth the dashcam remains on for about 2 days. I think the ancillary systems also help prevent any adverse effects from stop / start i.e. cooling the turbo etc. Sparky-R and camelsac2002 2 Quote Link to comment Share on other sites More sharing options...
AlanR Posted January 19, 2017 Report Share Posted January 19, 2017 First thing I do getting in the car is switch it off ,can't be doing with it thanksabunch, R13DYB, ninja_geezer and 3 others 6 Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted January 19, 2017 Report Share Posted January 19, 2017 turned mine off completely with OBdEleven on first day i had car ,bad for just about everything ,battery starter motor to name a couple ,its ok if you are on a longish journey i suppose but nearly all my work is stop start ......Kill it i say :grin: Sparky-R and Russellj 2 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 19, 2017 Report Share Posted January 19, 2017 Stop/Start is not for me, hate it. Switch it off every trip, integral part of startup routine now - seat belt on, ignition on, stop/start OFF! If I ever get around to getting OBDEleven or VCDS, I'll disable it completely. Sent from my iPhone using Tapatalk R4mbo and Sparky-R 2 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 19, 2017 Report Share Posted January 19, 2017 Mine is disabled permanently with VCDS. Hate it. Quote Link to comment Share on other sites More sharing options...
Mainframe Posted January 19, 2017 Report Share Posted January 19, 2017 I leave it on all the time in mine. Have done since Sep 14. But I mainly do long runs, so cutting and restarting a warm engine with a fully charged battery, is little or no overhead on systems. A tickle of the throttle is all that's needed to stop it cutting out prematurely: Likewise a firm press on the brakes is all that's needed to cut out engine sooner. In traffic ACC fires up engine as soon as car in front moves, and that's clever. Sparky-R 1 Quote Link to comment Share on other sites More sharing options...
LordR Posted January 19, 2017 Report Share Posted January 19, 2017 I'm not keen on it really. I should hope it won't do damage keep turning on and off if it's enabled for a long time. Quote Link to comment Share on other sites More sharing options...
Sparky-R Posted January 19, 2017 Author Report Share Posted January 19, 2017 First thing I do getting in the car is switch it off ,can't be doing with it That's exactly what I do, but if I realise I'm going to be standing at a traffic light for some time I first of all switch off the air con before activating it. But this is only once in a while...and when I pull off I switch the air con back on and then deactivate it. Sent from mTalk Quote Link to comment Share on other sites More sharing options...
Mr 60 Posted January 20, 2017 Report Share Posted January 20, 2017 Most my driving is inner London so I tend to have it on 60% of the time. I just don't see the point of the car being on when I know i'm going to be sitting at a light for a good 2 minutes. The only time I switch it off is when it starts to get annoying or I'm doing some spirited driving. rbel5553 1 Quote Link to comment Share on other sites More sharing options...
ColinC2 Posted January 20, 2017 Report Share Posted January 20, 2017 Its annoying as there is a small delay in re-starting if , for example, pulling out of a junction having been stationary. I will get around to disabling when have access to VCDS or OBDEleven. Quote Link to comment Share on other sites More sharing options...
jez-R Posted January 20, 2017 Report Share Posted January 20, 2017 It annoys me, I have mine disabled via VCDS - no more pressing the button Sparky-R 1 Quote Link to comment Share on other sites More sharing options...
P-P-P-PirateGolf_ARRR! Posted January 20, 2017 Report Share Posted January 20, 2017 I manually switch it off every time, it's now an automatic muscle memory when switching on the car. I don't like that small delay in restarting and the math just doesn't add up for me, when you look at the longer picture. All from a personal knowledge quest so I accept there maybe some incorrect information and some conjecture that will only be proved or dismissed over time but for now, it gives me a semi rational reason as to why I don't like it rather than it's just annoying. Main points I settled on: Avg 10-12% fuel saving in congested cities - Bothered by £6 - 8 a tank? Not me. When used over 10 years or so, you will stop and start the engine 10 times more (500k over 50k) but up-rated components are at absolute best 50% stronger and more often the case, only 25% stronger or less. So long term owners may see costly failure negating a substantial amount of those £££'s saved in fuel, or as it will possibly happen later in the cars life, maybe write it off years earlier. Wouldn't be the first time a system marketed as a way to save actually costs more in the long run. Re-Starting a hot engine although not as stressful as cold, still can be a potential for wear as the majority of the oil quickly drains to the sump when hot and viscosity is low, so those initial 3min traffic light startups are not exactly optimum. Emissions, same savings as fuel there or there abouts, completely negated if the system causes parts and or new cars to be ordered earlier than they are already, nearly half of all emissions during the entire life of your car are simply from it being built in the first place. There is greater detail behind those points that I have posted in other threads and have found since, but, no one cares too much because most won't keep their car long enough for it to affect them...which again shows that it really is just a lip service system that actually long term benefits the automotive industry in a possible increased demand cycle. Assuming the evidence and conjecture is correct of course. For me, when I get older and have to start moving back to secondhand motors, I will be looking for those that have had the system disabled unless this all turns out to be unfounded guff lukeh92 and Sparky-R 2 Quote Link to comment Share on other sites More sharing options...
